Flight Following question
Old December 11th 06, 12:37 AM posted to rec.aviation.ifr
Newps
Default Flight Following question
Jim Carter wrote:
That's pretty cool. So if I understand correctly now, I can file an IFR
flight plan, but specify the enroute altitude as VFR/065 (6500') and
that will generate a strip. Can I then call CD and pick up an IFR
clearance to VFR enroute with flight following?
Just file a regular IFR and pick it up how you normally do. When you
get to the point you want to be VFR tell the controller you want to
cancel and receive FF.
Old December 11th 06, 02:45 AM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Sunday, December 10, 2006 6:37 PM
Posted To: rec.aviation.ifr
Conversation: Flight Following question
Subject: Flight Following question
Duh!! That makes perfect sense; I don't know why I was following the VFR
altitude for IFR plan thread. Of course that prompts another question:
if its that easy to get FF then why bother with the IFR / VFR finagle to
start with? Why not just do as you suggest and file IFR with the
intention of cancelling over to FF after departure?
It can't be that we've got non-instrument rated pilots filing IFR plans
can it?
Old December 11th 06, 02:58 AM posted to rec.aviation.ifr
Newps
You have to be an instrument pilot to start out IFR.
can it?
It's OK to file, not OK to accept an IFR flight plan.
Old December 11th 06, 03:22 PM posted to rec.aviation.ifr
Mark Hansen
can it?
Consider also that departing IFR may mean delays and departure routes contrary
to what you may be able to get if you depart VFR.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old December 12th 06, 01:20 AM posted to rec.aviation.ifr
Jim Carter[_1_]
Posted At: Monday, December 11, 2006 9:22 AM
contrary
Sacramento, CA
Very true Mark. In the case of KLIT however, the IFR departures seem to
get the routes they want and the VFR departures all get R or L turn to
270, maintain 2000' or lower until further advised. Seeing you're from
SAC I suspect things are quite a bit different on that side of the hill.
Old December 12th 06, 03:44 PM posted to rec.aviation.ifr
Mark Hansen
contrary
I dunno, really ;-) My only IFR departures so far have been training or
local practice flights, most of which head straight for the local VOR
station before going on course anyway.
However, I was speaking in generalities. I'm sure there are some airports
where this won't be an issue, but I thought it was worth consideration
while planning what type of departure is appropriate for the flight.
Best,
Sacramento, CA
Old December 11th 06, 03:58 AM posted to rec.aviation.ifr
Stan Prevost
"Newps" wrote in message
Just file a regular IFR and pick it up how you normally do. When you get
to the point you want to be VFR tell the controller you want to cancel and
receive FF.
When I make my initial call to the departure facility, they usually just ask
me to confirm that I want VFR flight following, and then just say something
like "maintain VFR at all times, proceed on course, climb to requested VFR
altitude". They have all the other information already. At most, I have to
tell them that I want VFR flight following to destination, and that there
should be a proposal strip on me. Never any IFR clearance involved.
Old December 11th 06, 04:07 AM posted to rec.aviation.ifr
Newps
altitude".
That's a little overboard. A simple "maintain VFR" is all that's needed.
IFR use of handheld GPS [email protected] Instrument Flight Rules 251 May 19th 06 02:04 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
