IFR Cancellation Question
Old December 12th 06, 03:33 AM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default IFR Cancellation Question
Mike Adams wrote:
Well since this is my home base, I would terminate flight following and request a frequency change when
about 10 miles from the airport, so I could give the tower a call. That is, if approach hadn't dropped me
before that.
What about the report of the field in sight? Isn't safety compromised
if you terminate flight following before reporting the field in sight?
  #112
Old December 12th 06, 03:43 AM posted to rec.aviation.ifr
A Lieberma wrote:
This was based on MY eperiences, quite frankly spelled out in another post.
I never said that somebody told me the above.
I must have missed that post. In the message where you declared a
visual approach shuts down an uncontrolled field until the aircraft
cancels IFR you spoke of an unrelated experience when you arrived in
IMC. So what was the experience that led to your erroneous conclusion?
  #113
Old December 12th 06, 03:46 AM posted to rec.aviation.ifr
Mike Adams[_2_]
"Steven P. McNicoll" wrote:
and request a frequency change when about 10 miles from the airport,
me before that.
How so? I can find the airport without ATC's help.
At this particular airport, radar coverage is pretty crummy, so approach is more likely to terminate me
before the 10 mile point anyway, and visibility is usually not an issue.
Mike
  #114
Old December 12th 06, 03:54 AM posted to rec.aviation.ifr
A Lieberma
"Steven P. McNicoll" wrote in
ps.com:
post.
conclusion?
It was probably my mixing apples with oranges, thinking that the IMC
approaches where I couldn't get a SVFR clearance back to MBO (2 times I
tried this) so I could do a visual approach.
Controller said he was unable because the preceding traffic did not cancel
IFR.
Allen
  #115
Old December 12th 06, 12:17 PM posted to rec.aviation.ifr
IFR.
SVFR to MBO? SVFR isn't available to MBO as MBO lacks a surface area.
  #116
Old December 12th 06, 10:19 PM posted to rec.aviation.ifr
A Lieberma
ps.com:
I guess I should have requested a contact approach instead, but SVFR came
to my head at the time :-)
Allen
  #117
Old December 12th 06, 11:37 PM posted to rec.aviation.ifr
Milen Lazarov
Allen
You need 1 SM reported visibility at the airport. With no controlled airspace
down to the surface, you probably won't have that either, so you won't be
able to get clearance for a contact approach.
-Milen
  #118
Old December 13th 06, 01:33 AM posted to rec.aviation.ifr
A Lieberma
Milen Lazarov wrote in
airspace down to the surface, you probably won't have that either, so
you won't be able to get clearance for a contact approach.
In both approaches, viz wasn't the problem so much as the 900 foot
ceilings.
Had the viz been bad, it wouldn't have even crossed my mind to request a
SVFR.
Allen
  #119
Old December 13th 06, 01:48 AM posted to rec.aviation.ifr
Where's the advantage in that? You'd still have to wait for the
previous aircraft.
  #120
Old December 13th 06, 01:55 AM posted to rec.aviation.ifr
Weather reporting is a requirement for a surface area, but the absence
of a surface area does not mean the absence of weather reporting. MBO
has an AWOS.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
