1 mile is the minimum, but if you had to fly to the fix,
possibly an NDB or VOR on or very near the airport and then fly a procedure turn, you are adding 10-15 minutes to the flight. A contact approach saves time and time is money for a freight pilot's company. Company loose money, pilot loose job. On a contact approach you do not follow anybody, you are the only airplane and you navigate to the airport directly. A visual approach may be instigated by the controller if the weather is good VFR. When the controller asks, "Cessna 123XB, do you have traffic in sight? or "Report the airport insight" the next words you'll hear will probably be "Cessna 123XB cleared for the visual." Pilots request a contact approach and a controller may approve. ATC may issue a visual approach and pilots may reject it. In any case, the pilot doing a contact approach must maintain a flight visibility of 1 sm while the controller can't issue the clearance unless the visibility is reported as 1 sm. At airports without official weather reporting, the pilot can report to ATC that visibility is such and such and he can maintain VMC and request a contact approach, the pilot become the weather observer. The advantage is that the IFR clearance is still in the system and the pilot has the "out." It keeps an active flight plan, which is nice er than canceling IFR and then nobody will look for you. "Dan" wrote in message ups.com... | Since a contact approach requires the airport to have an IFR approach, | I fail to see the advantage of a contact approach. If visibility is at | 1 mile, I think I would rather just fly the approach than pick around | for the airport in those conditions - too risky. Where is the | advantage? Following other traffic visually? | | --Dan | | | wrote: | Newps wrote: | So you're saying that the controllers are the weather observers there? | That would put it in a gray area. The book states that weather must be | available. If you received the clearance before the tower closed that | would be OK. | | Yes the controllers are the weather observers. Why does that make it a | gray area? | | I'm pretty sure the clearance came after the tower closed. I've also | noticed that the approach controllers occasionally loose track of time | and they don't always realize the tower has closed. Maybe that's what | happened. Or the controller wasn't fresh on contact approaches, since | I think its used relatively rarely around here. By the way, this is a | small satellite airport under Class B and C airspace, if that makes a | difference. | |
![]() Jim Macklin wrote: At airports without official weather reporting, the pilot can report to ATC that visibility is such and such and he can maintain VMC and request a contact approach, the pilot become the weather observer. Can you really do that? A pilot's guess of ground visibility from aloft is good enough for the FAA? The advantage is that the IFR clearance is still in the system and the pilot has the "out." It keeps an active flight plan, which is nice er than canceling IFR and then nobody will look for you. I wouldn't consider search-and-rescue an "out." The only thing I can think of is that staying IFR keeps other IFR traffic out of your hair. Is there another advantage? |
The OUT is that you are in the system and can resume IFR.
S&R is a function of a flight plan. Commercial flights are required to be "on a flight plan" and canceling IFR even for the last few minutes of a charter flight puts you in violation. Flight visibility is solely judged by the pilot on an IFR approach, once the first step is passed. ATC will clear any airplane to make any approach the pilot requests. The pilot is not supposed to request or begin an approach if the weather is below visibility minimums. But any pilot, Part 91,121, 125, or 135 is the only person who can judge flight visibility and that is the controlling visibility on an IFR approach. How do you judge visibility? Standard approach lights are of a certain size as are the runway lights. You learn how to judge, 91.175 (c)(2) The flight visibility is not less than the visibility prescribed in the standard instrument approach being used; and 1.1 Flight visibility means the average forward horizontal distance, from the cockpit of an aircraft in flight, at which prominent unlighted objects may be seen and identified by day and prominent lighted objects may be seen and identified by night. wrote in message oups.com... | | Jim Macklin wrote: | | At airports without official weather reporting, | the pilot can report to ATC that visibility is such and such | and he can maintain VMC and request a contact approach, the | pilot become the weather observer. | | Can you really do that? A pilot's guess of ground visibility from | aloft is good enough for the FAA? | | The advantage is that | the IFR clearance is still in the system and the pilot has | the "out." It keeps an active flight plan, which is nice er | than canceling IFR and then nobody will look for you. | | I wouldn't consider search-and-rescue an "out." The only thing I can | think of is that staying IFR keeps other IFR traffic out of your hair. | Is there another advantage? | |
I didn't ask about flight visibility. The rules clearly state that ATC
can only authorize a contact approach if GROUND visibility is reported to be at least one statute mile. So, let me ask again. Can you report GROUND visibility from thousands of feet above the airport? How about if you're still 10 miles out? And, further, is that report something a pilot can do anyway, or does it have to be an official weather report? Jim Macklin wrote: The OUT is that you are in the system and can resume IFR. S&R is a function of a flight plan. Commercial flights are required to be "on a flight plan" and canceling IFR even for the last few minutes of a charter flight puts you in violation. Flight visibility is solely judged by the pilot on an IFR approach, once the first step is passed. ATC will clear any airplane to make any approach the pilot requests. The pilot is not supposed to request or begin an approach if the weather is below visibility minimums. But any pilot, Part 91,121, 125, or 135 is the only person who can judge flight visibility and that is the controlling visibility on an IFR approach. How do you judge visibility? Standard approach lights are of a certain size as are the runway lights. You learn how to judge, 91.175 (c)(2) The flight visibility is not less than the visibility prescribed in the standard instrument approach being used; and 1.1 Flight visibility means the average forward horizontal distance, from the cockpit of an aircraft in flight, at which prominent unlighted objects may be seen and identified by day and prominent lighted objects may be seen and identified by night. wrote in message oups.com... | | Jim Macklin wrote: | | At airports without official weather reporting, | the pilot can report to ATC that visibility is such and such | and he can maintain VMC and request a contact approach, the | pilot become the weather observer. | | Can you really do that? A pilot's guess of ground visibility from | aloft is good enough for the FAA? | | The advantage is that | the IFR clearance is still in the system and the pilot has | the "out." It keeps an active flight plan, which is nice er | than canceling IFR and then nobody will look for you. | | I wouldn't consider search-and-rescue an "out." The only thing I can | think of is that staying IFR keeps other IFR traffic out of your hair. | Is there another advantage? | |
Gee, there sure are a lot of contact approaches made to
airports. Section 5. Pilot/Controller Roles and Responsibilities 5-5-1. General a. The roles and responsibilities of the pilot and controller for effective participation in the ATC system are contained in several documents. Pilot responsibilities are in the CFRs and the air traffic controllers' are in the FAA Order 7110.65, Air Traffic Control, and supplemental FAA directives. Additional and supplemental information for pilots can be found in the current Aeronautical Information Manual (AIM), Notices to Airmen, Advisory Circulars and aeronautical charts. Since there are many other excellent publications produced by nongovernment organizations, as well as other government organizations, with various updating cycles, questions concerning the latest or most current material can be resolved by cross-checking with the above mentioned documents. b. The pilot-in-command of an aircraft is directly responsible for, and is the final authority as to the safe operation of that aircraft. In an emergency requiring immediate action, the pilot-in-command may deviate from any rule in the General Subpart A and Flight Rules Subpart B in accordance with 14 CFR Section 91.3. c. The air traffic controller is responsible to give first priority to the separation of aircraft and to the issuance of radar safety alerts, second priority to other services that are required, but do not involve separation of aircraft and third priority to additional services to the extent possible. d. In order to maintain a safe and efficient air traffic system, it is necessary that each party fulfill their responsibilities to the fullest. e. The responsibilities of the pilot and the controller intentionally overlap in many areas providing a degree of redundancy. Should one or the other fail in any manner, this overlapping responsibility is expected to compensate, in many cases, for failures that may affect safety. f. The following, while not intended to be all inclusive, is a brief listing of pilot and controller responsibilities for some commonly used procedures or phases of flight. More detailed explanations are contained in other portions of this publication, the appropriate CFRs, ACs and similar publications. The information provided is an overview of the principles involved and is not meant as an interpretation of the rules nor is it intended to extend or diminish responsibilities. 5-5-2. Air Traffic Clearance a. Pilot. 1. Acknowledges receipt and understanding of an ATC clearance. 2. Reads back any hold short of runway instructions issued by ATC. 3. Requests clarification or amendment, as appropriate, any time a clearance is not fully understood or considered unacceptable from a safety standpoint. 4. Promptly complies with an air traffic clearance upon receipt except as necessary to cope with an emergency. Advises ATC as soon as possible and obtains an amended clearance, if deviation is necessary. NOTE- A clearance to land means that appropriate separation on the landing runway will be ensured. A landing clearance does not relieve the pilot from compliance with any previously issued altitude crossing restriction. b. Controller. 1. Issues appropriate clearances for the operation to be conducted, or being conducted, in accordance with established criteria. 2. Assigns altitudes in IFR clearances that are at or above the minimum IFR altitudes in controlled airspace. 3. Ensures acknowledgement by the pilot for issued information, clearances, or instructions. 4. Ensures that readbacks by the pilot of altitude, heading, or other items are correct. If incorrect, distorted, or incomplete, makes corrections as appropriate. 5-5-3. Contact Approach a. Pilot. 1. Must request a contact approach and makes it in lieu of a standard or special instrument approach. 2. By requesting the contact approach, indicates that the flight is operating clear of clouds, has at least one mile flight visibility, and reasonably expects to continue to the destination airport in those conditions. 3. Assumes responsibility for obstruction clearance while conducting a contact approach. 4. Advises ATC immediately if unable to continue the contact approach or if encounters less than 1 mile flight visibility. 5. Is aware that if radar service is being received, it may be automatically terminated when told to contact the tower. REFERENCE- Pilot/Controller Glossary Term- Radar Service Terminated. b. Controller. 1. Issues clearance for a contact approach only when requested by the pilot. Does not solicit the use of this procedure. 2. Before issuing the clearance, ascertains that reported ground visibility at destination airport is at least 1 mile. 3. Provides approved separation between the aircraft cleared for a contact approach and other IFR or special VFR aircraft. When using vertical separation, does not assign a fixed altitude, but clears the aircraft at or below an altitude which is at least 1,000 feet below any IFR traffic but not below Minimum Safe Altitudes prescribed in 14 CFR Section 91.119. 4. Issues alternative instructions if, in their judgment, weather conditions may make completion of the approach impracticable. 5-5-4. Instrument Approach a. Pilot. 1. Be aware that the controller issues clearance for approach based only on known traffic. 2. Follows the procedure as shown on the IAP, including all restrictive notations, such as: (a) Procedure not authorized at night; (b) Approach not authorized when local area altimeter not available; (c) Procedure not authorized when control tower not in operation; (d) Procedure not authorized when glide slope not used; (e) Straight-in minimums not authorized at night; etc. (f) Radar required; or (g) The circling minimums published on the instrument approach chart provide adequate obstruction clearance and pilots should not descend below the circling altitude until the aircraft is in a position to make final descent for landing. Sound judgment and knowledge of the pilot's and the aircraft's capabilities are the criteria for determining the exact maneuver in each instance since airport design and the aircraft position, altitude and airspeed must all be considered. REFERENCE- AIM, Approach and Landing Minimums, Paragraph 5-4-20. 3. Upon receipt of an approach clearance while on an unpublished route or being radar vectored: (a) Complies with the minimum altitude for IFR; and (b) Maintains the last assigned altitude until established on a segment of a published route or IAP, at which time published altitudes apply. b. Controller. 1. Issues an approach clearance based on known traffic. 2. Issues an IFR approach clearance only after the aircraft is established on a segment of published route or IAP, or assigns an appropriate altitude for the aircraft to maintain until so established. 5-5-5. Missed Approach a. Pilot. 1. Executes a missed approach when one of the following conditions exist: (a) Arrival at the Missed Approach Point (MAP) or the Decision Height (DH) and visual reference to the runway environment is insufficient to complete the landing. (b) Determines that a safe approach or landing is not possible (see subparagraph 5-4-21g). (c) Instructed to do so by ATC. 2. Advises ATC that a missed approach will be made. Include the reason for the missed approach unless the missed approach is initiated by ATC. 3. Complies with the missed approach instructions for the IAP being executed from the MAP, unless other missed approach instructions are specified by ATC. 4. If executing a missed approach prior to reaching the MAP, fly the lateral navigation path of the instrument procedure to the MAP. Climb to the altitude specified in the missed approach procedure, except when a maximum altitude is specified between the final approach fix (FAF) and the MAP. In that case, comply with the maximum altitude restriction. Note, this may require a continued descent on the final approach. 5. Following a missed approach, requests clearance for specific action; i.e., another approach, hold for improved conditions, proceed to an alternate airport, etc. b. Controller. 1. Issues an approved alternate missed approach procedure if it is desired that the pilot execute a procedure other than as depicted on the instrument approach chart. 2. May vector a radar identified aircraft executing a missed approach when operationally advantageous to the pilot or the controller. 3. In response to the pilot's stated intentions, issues a clearance to an alternate airport, to a holding fix, or for reentry into the approach sequence, as traffic conditions permit. 5-5-6. Radar Vectors a. Pilot. 1. Promptly complies with headings and altitudes assigned to you by the controller. 2. Questions any assigned heading or altitude believed to be incorrect. 3. If operating VFR and compliance with any radar vector or altitude would cause a violation of any CFR, advises ATC and obtains a revised clearance or instructions. b. Controller. 1. Vectors aircraft in Class A, Class B, Class C, Class D, and Class E airspace: (a) For separation. (b) For noise abatement. (c) To obtain an operational advantage for the pilot or controller. 2. Vectors aircraft in Class A, Class B, Class C, Class D, Class E, and Class G airspace when requested by the pilot. 3. Vectors IFR aircraft at or above minimum vectoring altitudes. 4. May vector VFR aircraft, not at an ATC assigned altitude, at any altitude. In these cases, terrain separation is the pilot's responsibility. 5-5-7. Safety Alert a. Pilot. 1. Initiates appropriate action if a safety alert is received from ATC. 2. Be aware that this service is not always available and that many factors affect the ability of the controller to be aware of a situation in which unsafe proximity to terrain, obstructions, or another aircraft may be developing. b. Controller. 1. Issues a safety alert if aware an aircraft under their control is at an altitude which, in the controller's judgment, places the aircraft in unsafe proximity to terrain, obstructions or another aircraft. Types of safety alerts a (a) Terrain or Obstruction Alert. Immediately issued to an aircraft under their control if aware the aircraft is at an altitude believed to place the aircraft in unsafe proximity to terrain or obstructions. (b) Aircraft Conflict Alert. Immediately issued to an aircraft under their control if aware of an aircraft not under their control at an altitude believed to place the aircraft in unsafe proximity to each other. With the alert, they offer the pilot an alternative, if feasible. 2. Discontinue further alerts if informed by the pilot action is being taken to correct the situation or that the other aircraft is in sight. 5-5-8. See and Avoid a. Pilot. When meteorological conditions permit, regardless of type of flight plan or whether or not under control of a radar facility, the pilot is responsible to see and avoid other traffic, terrain, or obstacles. b. Controller. 1. Provides radar traffic information to radar identified aircraft operating outside positive control airspace on a workload permitting basis. 2. Issues safety alerts to aircraft under their control if aware the aircraft is at an altitude believed to place the aircraft in unsafe proximity to terrain, obstructions, or other aircraft. 5-5-9. Speed Adjustments a. Pilot. 1. Advises ATC any time cruising airspeed varies plus or minus 5 percent or 10 knots, whichever is greater, from that given in the flight plan. 2. Complies with speed adjustments from ATC unless: (a) The minimum or maximum safe airspeed for any particular operation is greater or less than the requested airspeed. In such cases, advises ATC. NOTE- It is the pilot's responsibility and prerogative to refuse speed adjustments considered excessive or contrary to the aircraft's operating specifications. (b) Operating at or above 10,000 feet MSL on an ATC assigned SPEED ADJUSTMENT of more than 250 knots IAS and subsequent clearance is received for descent below 10,000 feet MSL. In such cases, pilots are expected to comply with 14 CFR Section 91.117(a). 3. When complying with speed adjustment assignments, maintains an indicated airspeed within plus or minus 10 knots or 0.02 Mach number of the specified speed. b. Controller. 1. Assigns speed adjustments to aircraft when necessary but not as a substitute for good vectoring technique. 2. Adheres to the restrictions published in the FAA Order 7110.65, Air Traffic Control, as to when speed adjustment procedures may be applied. 3. Avoids speed adjustments requiring alternate decreases and increases. 4. Assigns speed adjustments to a specified IAS (KNOTS)/Mach number or to increase or decrease speed using increments of 10 knots or multiples thereof. 5. Advises pilots to resume normal speed when speed adjustments are no longer required. 6. Gives due consideration to aircraft capabilities to reduce speed while descending. 7. Does not assign speed adjustments to aircraft at or above FL 390 without pilot consent. 5-5-10. Traffic Advisories (Traffic Information) a. Pilot. 1. Acknowledges receipt of traffic advisories. 2. Informs controller if traffic in sight. 3. Advises ATC if a vector to avoid traffic is desired. 4. Does not expect to receive radar traffic advisories on all traffic. Some aircraft may not appear on the radar display. Be aware that the controller may be occupied with higher priority duties and unable to issue traffic information for a variety of reasons. 5. Advises controller if service is not desired. b. Controller. 1. Issues radar traffic to the maximum extent consistent with higher priority duties except in Class A airspace. 2. Provides vectors to assist aircraft to avoid observed traffic when requested by the pilot. 3. Issues traffic information to aircraft in the Class B, Class C, and Class D surface areas for sequencing purposes. 5-5-11. Visual Approach a. Pilot. 1. If a visual approach is not desired, advises ATC. 2. Complies with controller's instructions for vectors toward the airport of intended landing or to a visual position behind a preceding aircraft. 3. The pilot must, at all times, have either the airport or the preceding aircraft in sight. After being cleared for a visual approach, proceed to the airport in a normal manner or follow the preceding aircraft. Remain clear of clouds while conducting a visual approach. 4. If the pilot accepts a visual approach clearance to visually follow a preceding aircraft, you are required to establish a safe landing interval behind the aircraft you were instructed to follow. You are responsible for wake turbulence separation. 5. Advise ATC immediately if the pilot is unable to continue following the preceding aircraft, cannot remain clear of clouds, or lose sight of the airport. 6. Be aware that radar service is automatically terminated, without being advised by ATC, when the pilot is instructed to change to advisory frequency. 7. Be aware that there may be other traffic in the traffic pattern and the landing sequence may differ from the traffic sequence assigned by approach control or ARTCC. b. Controller. 1. Do not clear an aircraft for a visual approach unless reported weather at the airport is ceiling at or above 1,000 feet and visibility is 3 miles or greater. When weather is not available for the destination airport, inform the pilot and do not initiate a visual approach to that airport unless there is reasonable assurance that descent and flight to the airport can be made visually. 2. Issue visual approach clearance when the pilot reports sighting either the airport or a preceding aircraft which is to be followed. 3. Provide separation except when visual separation is being applied by the pilot. 4. Continue flight following and traffic information until the aircraft has landed or has been instructed to change to advisory frequency. 5. Inform the pilot when the preceding aircraft is a heavy. 6. When weather is available for the destination airport, do not initiate a vector for a visual approach unless the reported ceiling at the airport is 500 feet or more above the MVA and visibility is 3 miles or more. If vectoring weather minima are not available but weather at the airport is ceiling at or above 1,000 feet and visibility of 3 miles or greater, visual approaches may still be conducted. 7. Informs the pilot conducting the visual approach of the aircraft class when pertinent traffic is known to be a heavy aircraft. 5-5-12. Visual Separation a. Pilot. 1. Acceptance of instructions to follow another aircraft or to provide visual separation from it is an acknowledgment that the pilot will maneuver the aircraft as necessary to avoid the other aircraft or to maintain in-trail separation. Pilots are responsible to maintain visual separation until flight paths (altitudes and/or courses) diverge. 2. If instructed by ATC to follow another aircraft or to provide visual separation from it, promptly notify the controller if you lose sight of that aircraft, are unable to maintain continued visual contact with it, or cannot accept the responsibility for your own separation for any reason. 3. The pilot also accepts responsibility for wake turbulence separation under these conditions. b. Controller. Applies visual separation only: 1. Within the terminal area when a controller has both aircraft in sight or by instructing a pilot who sees the other aircraft to maintain visual separation from it. 2. Pilots are responsible to maintain visual separation until flight paths (altitudes and/or courses) diverge. 3. Within en route airspace when aircraft are on opposite courses and one pilot reports having seen the other aircraft and that the aircraft have passed each other. 5-5-13. VFR-on-top a. Pilot. 1. This clearance must be requested by the pilot on an IFR flight plan, and if approved, allows the pilot the choice (subject to any ATC restrictions) to select an altitude or flight level in lieu of an assigned altitude. NOTE- VFR-on-top is not permitted in certain airspace areas, such as Class A airspace, certain restricted areas, etc. Consequently, IFR flights operating VFR-on-top will avoid such airspace. REFERENCE- AIM, IFR Clearance VFR-on-top, Paragraph 4-4-7. AIM, IFR Separation Standards, Paragraph 4-4-10. AIM, Position Reporting, Paragraph 5-3-2. AIM, Additional Reports, Paragraph 5-3-3. 2. By requesting a VFR-on-top clearance, the pilot assumes the sole responsibility to be vigilant so as to see and avoid other aircraft and to: (a) Fly at the appropriate VFR altitude as prescribed in 14 CFR Section 91.159. (b) Comply with the VFR visibility and distance from clouds criteria in 14 CFR Section 91.155, Basic VFR weather minimums. (c) Comply with instrument flight rules that are applicable to this flight; i.e., minimum IFR altitudes, position reporting, radio communications, course to be flown, adherence to ATC clearance, etc. 3. Should advise ATC prior to any altitude change to ensure the exchange of accurate traffic information. b. Controller. 1. May clear an aircraft to maintain VFR-on-top if the pilot of an aircraft on an IFR flight plan requests the clearance. 2. Informs the pilot of an aircraft cleared to climb to VFR-on-top the reported height of the tops or that no top report is available; issues an alternate clearance if necessary; and once the aircraft reports reaching VFR-on-top, reclears the aircraft to maintain VFR-on-top. 3. Before issuing clearance, ascertain that the aircraft is not in or will not enter Class A airspace. 5-5-14. Instrument Departures a. Pilot. 1. Prior to departure considers the type of terrain and other obstructions on or in the vicinity of the departure airport. 2. Determines if obstruction avoidance can be maintained visually or that the departure procedure should be followed. 3. Determines whether a departure procedure and/or DP is available for obstruction avoidance. 4. At airports where IAPs have not been published, hence no published departure procedure, determines what action will be necessary and takes such action that will assure a safe departure. b. Controller. 1. At locations with airport traffic control service, when necessary, specifies direction of takeoff, turn, or initial heading to be flown after takeoff. 2. At locations without airport traffic control service but within Class E surface area when necessary to specify direction of takeoff, turn, or initial heading to be flown, obtains pilot's concurrence that the procedure will allow the pilot to comply with local traffic patterns, terrain, and obstruction avoidance. 3. Includes established departure procedures as part of the ATC clearance when pilot compliance is necessary to ensure separation. 5-5-15. Minimum Fuel Advisory a. Pilot. 1. Advise ATC of your minimum fuel status when your fuel supply has reached a state where, upon reaching destination, you cannot accept any undue delay. 2. Be aware this is not an emergency situation, but merely an advisory that indicates an emergency situation is possible should any undue delay occur. 3. On initial contact the term "minimum fuel" should be used after stating call sign. EXAMPLE- Salt Lake Approach, United 621, "minimum fuel." 4. Be aware a minimum fuel advisory does not imply a need for traffic priority. 5. If the remaining usable fuel supply suggests the need for traffic priority to ensure a safe landing, you should declare an emergency due to low fuel and report fuel remaining in minutes. REFERENCE- Pilot/Controller Glossary Item- Fuel Remaining. b. Controller. 1. When an aircraft declares a state of minimum fuel, relay this information to the facility to whom control jurisdiction is transferred. 2. Be alert for any occurrence which might delay the aircraft. 5-5-16. RNAV and RNP Operations a. Pilot. 1. If unable to comply with the requirements of an RNAV or RNP procedure, pilots shall advise air traffic control as soon as possible. For example, ". . . N1234, failure of GPS system, unable RNAV, request amended clearance." 2. Pilots are not authorized to fly a published RNAV or RNP procedure unless it is retrievable by the procedure name from the aircraft navigation database and conforms to the charted procedure. 3. Pilots shall not change any database waypoint type from a fly-by to fly-over, or vice versa. No other modification of database waypoints or the creation of user-defined waypoints on published RNAV or RNP procedures is permitted, except to: (a) Change altitude and/or airspeed waypoint constraints to comply with an ATC clearance/instruction. (b) Insert a waypoint along the published route to assist in complying with ATC instruction, example, "Descend via the WILMS arrival except cross 30 north of BRUCE at/or below FL 210." This is limited only to systems that allow along-track waypoint construction. 4. Pilots of aircraft utilizing DME/DME for primary radio updating shall ensure any published required DME stations are in service as determined by NOTAM, ATIS, or ATC advisory. No pilot monitoring of FMS navigation source(s) is required. 5. Pilots of FMS-equipped aircraft, who are assigned an RNAV DP or STAR procedure and subsequently receive a change of runway, transition or procedure, shall verify that the appropriate changes are loaded and available for navigation. 6. While operating on RNAV segments, pilots are encouraged to use flight director, in lateral navigation mode. 7. For Type B RNAV DPs and STARs, pilots must use a CDI/flight director and/or autopilot, in lateral navigation mode. For Type A RNAV DPs and STARs, these procedures are recommended. Other methods providing an equivalent level of performance may also be acceptable. 8. For Type B RNAV DPs and STARs, pilots of aircraft without GPS, using DME/DME/IRU, must ensure the aircraft navigation system position is confirmed, within 1,000 feet, at the start point of take-off roll. The use of an automatic or manual runway update is an acceptable means of compliance with this requirement. Other methods providing an equivalent level of performance may also be acceptable. 9. RNAV terminal procedures may be amended by ATC issuing radar vectors and/or clearances direct to a waypoint. Pilots should avoid premature manual deletion of waypoints from their active "legs" page to allow for rejoining procedures. 10. While operating on RNAV segments, pilots operating /R aircraft shall adhere to any flight manual limitation or operating procedure required to maintain the RNP value specified for the procedure. wrote in message ups.com... |I didn't ask about flight visibility. The rules clearly state that ATC | can only authorize a contact approach if GROUND visibility is reported | to be at least one statute mile. | | So, let me ask again. Can you report GROUND visibility from thousands | of feet above the airport? How about if you're still 10 miles out? | And, further, is that report something a pilot can do anyway, or does | it have to be an official weather report? | | Jim Macklin wrote: | The OUT is that you are in the system and can resume IFR. | S&R is a function of a flight plan. Commercial flights are | required to be "on a flight plan" and canceling IFR even for | the last few minutes of a charter flight puts you in | violation. | | | Flight visibility is solely judged by the pilot on an IFR | approach, once the first step is passed. ATC will clear any | airplane to make any approach the pilot requests. The pilot | is not supposed to request or begin an approach if the | weather is below visibility minimums. But any pilot, Part | 91,121, 125, or 135 is the only person who can judge flight | visibility and that is the controlling visibility on an IFR | approach. | | How do you judge visibility? Standard approach lights are | of a certain size as are the runway lights. You learn how | to judge, 91.175 (c)(2) The flight visibility is not less | than the visibility prescribed in the standard instrument | approach being used; and | 1.1 | Flight visibility means the average forward horizontal | distance, from the cockpit of an aircraft in flight, at | which prominent unlighted objects may be seen and identified | by day and prominent lighted objects may be seen and | identified by night. | | | | | | | wrote in message | oups.com... | | | | Jim Macklin wrote: | | | | At airports without official weather reporting, | | the pilot can report to ATC that visibility is such and | such | | and he can maintain VMC and request a contact approach, | the | | pilot become the weather observer. | | | | Can you really do that? A pilot's guess of ground | visibility from | | aloft is good enough for the FAA? | | | | The advantage is that | | the IFR clearance is still in the system and the pilot | has | | the "out." It keeps an active flight plan, which is | nice er | | than canceling IFR and then nobody will look for you. | | | | I wouldn't consider search-and-rescue an "out." The only | thing I can | | think of is that staying IFR keeps other IFR traffic out | of your hair. | | Is there another advantage? | | | |
![]() Jim Macklin wrote: Gee, there sure are a lot of contact approaches made to airports. It would do you well to actually read what you copy and paste. |
![]() Jim Macklin wrote: Flight visibility is solely judged by the pilot on an IFR approach, once the first step is passed. ATC will clear any airplane to make any approach the pilot requests. The pilot is not supposed to request or begin an approach if the weather is below visibility minimums. But any pilot, Part 91,121, 125, or 135 is the only person who can judge flight visibility and that is the controlling visibility on an IFR approach. You can't get a contact approach without a reported ground visibility of at least one statute mile. |
![]() Jim Macklin wrote: Commercial flights are required to be "on a flight plan" and canceling IFR even for the last few minutes of a charter flight puts you in violation. Rubbish. Many commercial flights go VFR. What matters is how their ops specs are written. Some allow VFR, some don't. Flight visibility is solely judged by the pilot on an IFR approach, once the first step is passed. And the first step on a contact approach is reported ground viz of a mile. ATC will clear any airplane to make any approach the pilot requests. Uh, maybe. What's the traffic picture? Go into ORD and request a VOR approach with a procedure turn and see where that gets you. The pilot is not supposed to request or begin an approach if the weather is below visibility minimums. But any pilot, Part 91,121, 125, or 135 is the only person who can judge flight visibility and that is the controlling visibility on an IFR approach. Wrong. 121 and 135 pilots are not allowed to even start the approach when the reported ground viz is below the airlines minimums. Flight viz isn't even a question that's asked. |
The pilot
is not supposed to request or begin an approach if the weather is below visibility minimums. Actually, that's 135 only, no? Part 91 pilots may begin an approach irrespective of the weather. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
VFR position reporting | Mxsmanic | Piloting | 154 | November 26th 06 04:45 PM |
OLV GPS 36 approach question | A Lieberma | Instrument Flight Rules | 59 | August 15th 06 12:32 AM |
Trust those Instruments.... Trust those Instruments..... | A Lieberman | Instrument Flight Rules | 1 | May 2nd 06 03:54 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
