#21
Greg Farris schrieb:
accident was classic pilot error, no fault was found with the FBW system... The computer was not only not at fault, but it even prevented a catastrophe. The automatic wing leveller kept the wings levelled, even at full stall. It did this so perfectly that when the airplane descended into the trees, both wings were ripped off simultaneously, and the fuselage "landed" straight ahead and perfectly aligned. From the 120 or so passengers, *no* one was killed or even severely injured at the impact! This is a plain miracle. The three deaths of that accident were not killed at impact, but very tragically later: There were two passengers in wheelchairs who couldn't leave the airplane by themselves after the impact. One flight attendant got aware of this after she had left the plane and returned back into the plane to help the two to get out. Tragically, at that moment, the developing fire reached the fuselage and the three were trapped and burnt. Stefan |
"Kev" wrote in message oups.com... Danny Dot wrote: In about 1990 Airbus did low pass at the Paris airshow and lost the plane. I recall it had something to do with the throttle software thinking the pilots were in landing mode and "refused" to go to high power for the go-around. Yes, the computers did think the pilot was landing, but the crash was caused by his being too low and slow. (See other posts for more info on the latter.) The Airbus software has modes where its flight control computer laws are quite different. Some of those computer laws are divided into Ground, Flight and Landing (Flare) phases. One claim is that he was trying to demonstrate that the airplane was unstallable. He had reportedly done this demonstration several times before at a slightly higher altitude, and it had always worked. Why? Because the Airbus has what's known as Alpha Protection (pitch related) and Alpha Floor (thrust related). Too little thrust, at too high an angle of attack (AOA), and its computers automatically kick in and override the pilot. The reason the automatic protection didn't work this time was because he went below 100', so the computers switched to Landing Mode. That doesn't mean they do an autoland. It means they think the pilot is landing the plane and their rules change. The Alpha Floor is disabled so that a landing is possible at all. By the time the pilot advanced the throttles himself, it was too late. In addition, another Landing Mode kicks in when the Bus passes below 50' going down to 30', as he did. The computer starts changing the stick reference for landing, so that if you have the stick pulled back', that position soon becomes the neutral spot. This is supposed to force the pilot to pull back more for flaring. Regards, Kev ---------links snipped---------- That was not the first or last time that a flight crew got into trouble with a new control system that they only partially understood; and I am sure that there will be more to come. Just as an example, Eastern Airlines lost one of the early Lockheed L-1011 aircraft in the Florida Everglades due to a chain of events which began with a failed indicator lamp for the nose wheel. The new feature, in the experience of the crew, was that the autopilot could be dissengaged by a sharp pull of push on either yoke--and would remain dissengaged until either pilot engaged it again. That was both a safety feature and a convenience feature, since it did not require a crew member to continue to forcibly override a rachetting capstan until the autopilot could be dissengaged. But the crew did not fully understand the feature, or all of its implications, at the time. Further, autopilots do operate the trim, but not perfectly, and they happened to be trimmed very slightly nose down; with the result that the aircraft gradually drifted down until the wheels contacted the vegetation and water--and dug in. There were no outside visual referenced at that place and time--and they still believed that they were on autopilot at a constant altitude. That's just one more relatively famous accident. Peter |
Stefan wrote: From the 120 or so passengers, *no* one was killed or even severely injured at the impact! There were pax aboard that flight? I thought it was a mfr test hop? |
Kingfish schrieb:
There were pax aboard that flight? I thought it was a mfr test hop? It was a demonstration flight on an airshow. This was the last such flight in Europe with passengers aboard. Stefan |
"Stefan" wrote in message
. .. Kingfish schrieb: There were pax aboard that flight? I thought it was a mfr test hop? It was a demonstration flight on an airshow. This was the last such flight in Europe with passengers aboard. Stefan It used to be fairly common for an airline with a nearby base to have one of their aircraft make a low pass over the runway at an airshow--sometimes slow and dirty (as this was planned to be), other times clean and fast, and occasionally one of each. It was a way to showcase their presence, and also provided an interesting contrast of sizes and characteristics... Peter |
Kev writes:
The Airbus software has modes where its flight control computer laws are quite different. Some of those computer laws are divided into Ground, Flight and Landing (Flare) phases. One claim is that he was trying to demonstrate that the airplane was unstallable. He had reportedly done this demonstration several times before at a slightly higher altitude, and it had always worked. Why? Because the Airbus has what's known as Alpha Protection (pitch related) and Alpha Floor (thrust related). Too little thrust, at too high an angle of attack (AOA), and its computers automatically kick in and override the pilot. The reason the automatic protection didn't work this time was because he went below 100', so the computers switched to Landing Mode. That doesn't mean they do an autoland. It means they think the pilot is landing the plane and their rules change. The Alpha Floor is disabled so that a landing is possible at all. By the time the pilot advanced the throttles himself, it was too late. In addition, another Landing Mode kicks in when the Bus passes below 50' going down to 30', as he did. The computer starts changing the stick reference for landing, so that if you have the stick pulled back', that position soon becomes the neutral spot. This is supposed to force the pilot to pull back more for flaring. These are all examples of poor design. It's extremely dangerous to put such features into FBW software unless you can be certain that all pilots will know as much about the software as the designers did, so that they'll know all the modes and all the combinations and permutations of possibilities. If you aren't going to let the pilot control the plane, why have a pilot at all? And if the computers are going to second-guess the pilot's intentions every step of the way without the pilot knowing it, having a pilot is worse than not having one. This is a good example of poor human-machine interactions, created by poor and inadequate design. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Danny Dot wrote: In about 1990 Airbus did low pass at the Paris airshow and lost the plane. I recall it had something to do with the throttle software thinking the pilots were in landing mode and "refused" to go to high power for the go-around. Anyone remember the details??? Danny Dot This really comes down to a simple difference between the way the autothrottle operates in Boeing airplanes vs. Airbus. In the Boeing model, if you shove the throttle handles forward, the engines respond to the throttle setting. If autothrottle is engaged, it will start to retard the throttles back to the commanded setting and the pilot will see the throttles moving, realize that autothrottle is engaged and trying to do something different than what he wants, and he will grab the throttle handles, shove them back forward and push the autothrottle disengage button on the side of the throttle handle. This takes only a second or two to resolve. In an Airbus model, if you shove the throttle handles foward, the engines do not respond to the throttle setting (when autothrottle is engaged), and the throttle handles will just sit there in a position that differs from what the autothrottle is doing. In the meantime, it can take a while for the pilot to realize what is going on and the push the TOGA button to disengage the landing mode and get the computer to respond to the throttle handle position. This is what happened to the pilot involved in this accident. By the time he realized what was going on and pushed the TOGA button, there wasn't time for the engines to spool up enough to miss the trees. This is why the difference between a chainsaw and an A320 is 100 trees a minute. Dean |
#28
Mxsmanic wrote: These are all examples of poor design. It's extremely dangerous to put such features into FBW software unless you can be certain that all pilots will know as much about the software as the designers did, so that they'll know all the modes and all the combinations and permutations of possibilities. For once, I don't see how anyone could disagree. The FAA commissioned a study of these issues. Check out the site map and the Find All Issues section. http://www.flightdeckautomation.com If you aren't going to let the pilot control the plane, why have a pilot at all? Boeing thinks along those lines. They have soft limits vs. Airbus' hard limits. And if the computers are going to second-guess the pilot's intentions every step of the way without the pilot knowing it, having a pilot is worse than not having one. Well, not really of course. Interestingly, it seems that a lot of pilots love the Airbus overrides. They can flick the handles and not worry too much. Others seem to want to rely more on the usual stick and rudder skills. You could argue both ways. Computers aren't all bad. Consider all the traction control etc computers in cars these days. (I actually don't like them second-guessing me sometimes, but for the majority of drivers they're a good thing.) This is a good example of poor human-machine interactions, created by poor and inadequate design. I agree that letting programmers decide how things work is often a Bad Idea. Kev |
#29
Kev writes:
Boeing thinks along those lines. They have soft limits vs. Airbus' hard limits. I agree strongly with Boeing. The whole justification for a pilot is to have a human being aboard for unexpected emergencies. Computers are superior to human beings for handling _foreseen_ emergencies, so pilots aren't needed in those cases. They are also superior for controlling normal flight. The real advantage of a human pilot in cockpit, though, is that human beings are extremely good at dealing with completely off-the-wall situations for which computers haven't been programmed in advance. If an aircraft finds itself in an unusual attitude that the programmers of the on-board computers have not foreseen, the computers will probably make catastrophically poor decisions, or they will just fault or reboot. A human being, on the other hand, will adapt and make decisions that are at least moderately appropriate to the situation, no matter how bizarre. Given this, not allowing the pilot to override the computer makes no sense at all. Why bother with the pilot, if all he can do in a situation that the computer doesn't understand is watch himself and his aircraft plummet towards the ground? To make a pilot useful, you need a button that says "I have the controls," and turns the computer completely off. The pilot is then on his own, but in some situations, that may be what saves the day. Computers aren't all bad. Consider all the traction control etc computers in cars these days. (I actually don't like them second-guessing me sometimes, but for the majority of drivers they're a good thing.) Computers aren't bad at all. Look at the widespread use of autopilots, which are simply a type of computer. But you need to be able to switch off the computer, just as you can disengage the autopilot, otherwise the time may come when you'll watch helplessly as your computer kills you and destroys your aircraft with poor decisions. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
Greg Farris writes:
Well - we are getting much closer to a defensible response here. We can accept then that the plane crashed because the pilot flew too low and advanced the throttles too late. Contributing factors include the pilot's incomplete comprehension of the aircraft's systems. What the investigation had to determine then, was whether the pilot's poor comprehension was due to poor application of his training, or whether the training itself was inadequate. There's another possibility: The designers of the FBW system had no clue as to how real pilots react in different situations, and failed to anticipate what a pilot would do and expect in those situations. If they had done their job correctly, the FBW would do exactly what a pilot would expect it to do, and there would be no "modes" for a pilot to memorize over and above everything else that he already has to know. Flying isn't a video game, even if some desk-bound geeks at Airbus might like to pretend that it is. If a pilot, faced with an unexpected situation does something other than what his training suggests, and the result is positive, then nothing is said. But if the pilot does not act in accordance with his training and the result is negative, then it is fair play to attribute it to pilot error. What happens if the aircraft is designed to do something counterintuitive, such as having the movements of the yoke reversed, and the pilot forgets this (or is never trained about it) and makes a mistake that leads to an accident? Is it the pilot's fault because the aircraft behaved like no other that he has ever flown, or the manufacturer's fault because it designed in features that were in direct contradiction of a pilot's normal base training? But then, all of the above is moot when one considers, as resident experts have explained to us, that Airbus aircraft are not controllable through pilot input ... They are not controllable outside an envelope that is enforced by the computers. In this case, you have to wonder just exactly why pilots are needed at all. If all flying situations are covered by the computers, the computers can fly the aircraft from start to finish, and you can dispense with pilots. This will probably actually happen one day for commercial airliners, although that day is still quite far away. Pilots of airliners are increasingly just skilled attendants, not people who actually fly the plane. -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Thread Tools | |
| Display Modes | |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Paris Airshow - Helimat | HELIMAT | Rotorcraft | 0 | June 14th 05 07:42 AM |
| paris airshow 2003 / Le bourget / photo album | hugo36 | Aerobatics | 0 | July 9th 03 12:01 AM |
