Looking for a math wiz!
Old December 16th 06, 09:34 PM posted to rec.aviation.piloting,rec.aviation.ifr
d&tm
Default Looking for a math wiz!
"Chad Speer" wrote in message
Okay, I know I've seen a lot of engineers and technical folks on here.
I have a complex math problem relating to the classic wind triangle
that I posted on sci.math and received little response. I don't know
if they're stumped or just not interested. :-)
Here is a copy of my original post and the only useful response I
received. Anyone have a solution?
(For the controllers here, this is an enhancement we are trying to add
to the Falcon program that centers will see next year, which was
developed by a controller here at ZKC.)
Chad Speer
PP-ASEL, IA
ATCS, Kansas City ARTCC
My original post:
I am helping someone with a program that estimates wind speed and
direction using radar data from aircraft. I need help finding a
formula that can determine the wind speed and direction when given the
following information for multiple aircraft:
direction of travel
speed across the ground
speed through the air
The direction of travel and the speed across the ground are taken from
the radar data. The speed through the air is taken from the pilot's
flight plan. We're air traffic controllers trying to improve our
training tools, so we get access to all the goodies.
I know that with information from just one aircraft, the possibilities
are endless for the wind speed and direction. I think it is possible
to use the same data from two or more aircraft to determine the wind
I thought I could come up with a formula to solve this, but the need to
reference everything to north in order to achieve actual directions
instead of just angles took it way above my head.
snip
Chad
if you know HDG ( ie where you are pointing), GS and TAS then there is only
1 possibility for the wind speed and direction. these can be calculated
from the cosine rule. If you know the cosine rule and the sine rule for
triangles you can calculate a lot of things.
to apply both of these rules draw yourself a little triangle and mark the
sides small a,b and c.
then mark the angles capital A,B and C where angle A is opposite side a
and angle B is opposite side b.
cosine rule a^2 = b^2 +c^2 - 2bc cos( A)
sine rule a/sin A = b/sin B = c /sin C
in the case of the NAV triangle
WS= SQRT( GS^2+TAS^2 =2*GS*TAS*cos(HDG-TR))
where WS= windspeed
GS = ground speed
TAS = airspeed
HDG = heading(where you are pointing)
TR = track ( where you are going)
If you want I can email you an excel spreadsheet that has this already
coded. you just enter your TAS, GS and HDG and it will give you the WS and
Wind direction.
Terry
PPL
Old December 16th 06, 10:13 PM posted to rec.aviation.piloting,rec.aviation.ifr
Stefan
Actually, there are two.
But the question was a different one. It has already been answered
pretty well, all what remains is to do the dirty work and shuffling some
formulas.
Stefan
Old December 17th 06, 03:46 AM posted to rec.aviation.ifr
Chad Speer
Terry - thanks for the reply, but heading is not known.
Stefan - we need to be able to plug these known values into a formula
and kick out a result. Assuming the original responder was on the
right track, I still don't know what to do with his suggestion. Any
ideas on that? I'm not lazy, this just went over my head a long time
ago. :-)
Chad Speer
PP-ASEL, IA
On Dec 16, 4:13 pm, Stefan wrote:
1 possibility for the wind speed and direction.Actually, there are two.
formulas.
Stefan
Old December 17th 06, 06:18 AM posted to rec.aviation.piloting,rec.aviation.ifr
Kev
Eh? Not to sidetrack the thread too much, but how could there be two
wind answers?
For example on the E-6B, to solve this, you'd set TRACK up, grommet
over GS, and then look for where your TAS arc meets your drift
correction angle (HDG-TRACK). The vector back to the grommet is the
single direction and speed for the wind.
Thanks, Kev
Old December 17th 06, 01:58 PM posted to rec.aviation.piloting,rec.aviation.ifr
Stefan
wind answers?
Mathematically: There are always two square roots which solve the
equation: A positive and a negative.
Physically: If you only know GS, TAS and HDG, then you don't know
whether the wind blows from the let or from the right. (If you also know
the track, then of course there's only one solution.)
Stefan
Old December 17th 06, 07:46 PM posted to rec.aviation.piloting,rec.aviation.ifr
d&tm
"Stefan" wrote in message
wind answers?
Of course you are correct, I meant to include Track in the knowns, (
afterall if you dont know the track whether you are the pilot or the ATC you
are really in trouble.)
terry
Old December 19th 06, 12:51 AM posted to rec.aviation.piloting,rec.aviation.ifr
Kev
While that statement is true, it doesn't cover all the possibilities.
We're talking about the case of a single aircraft? We know its HDG,
GS, TAS, but nothing else? That's only three of the six wind triangle
variables. We must know at least four to get an exact answer. With
only three knowns, there are a whole range of possible answers, since
we don't know what the wind correction angle is without knowing a CRS.
For example, for the following HDG, TAS and GS:
HDG 0
TAS 120
GS 100
All the following CRS, WD an WS are valid solutions, plus many more
in-between:
CRS WD WS
310 054 095
330 056 060
350 039 028
000 000 020 CRS=HDG
010 321 028
030 304 060
050 306 095
I think you were visualizing a triangle, and thought of the two obvious
solutions. But there are a lot more. Again, use the E6B method and
you'll see that any drift angle along the TAS arc contains a valid WS
and WD answer.
Regards, Kev
Old December 19th 06, 09:27 AM posted to rec.aviation.piloting,rec.aviation.ifr
Stefan
Frankly, I didn't contemplate very much and just posted the obvious.
Stefan
Old December 19th 06, 01:57 AM posted to rec.aviation.piloting,rec.aviation.ifr
Travis Marlatte
Chad,
I think that some clarification of the use might help. I can imagine two
scenarios:
1) enroute - in this case, you know the track and ground speed from radar.
You have the filed TAS. You have no idea of the crab angle or heading. This
sounds like the information you presented in your question. However,
enroute, who cares what the wind correction is. I am having trouble
imagining how this would help a controller - in training or not.
2) terminal - in this case, you still know the track and ground speed from
radar. However, now the filed TAS is probably no longer valid since it is
probably at a lower altitude than filed and used to compute the TAS. The
plane may also be under speed constraints. On the other hand, the controller
may be vectoring so now you have an assigned heading and maybe even an
assigned speed. You also have the pressure for the area and the TAS can be
computed from that and radar data. If this were an automated computation, it
could be done on every plane that was given an assigned speed (or even IAS
queried from the pilot) and an assigned heading (or even queried from the
pilot). Now maybe not every plane can provide all of the data but certainly
some could. Enough to update the calculated wind periodically.
Scenario 2 seems to me the one that would make knowledge of the wind most
desirable. It is also the scenario that could provide additional data and
certainly provides different data than what was posed in your question.
What say you?
Travis
Lake N3094P
PWK
Old December 19th 06, 05:03 AM posted to rec.aviation.ifr
Chad Speer
two scenarios:
radar. You have the filed TAS. You have no idea of the crab angle or
heading. This sounds like the information you presented in your
question. However, enroute, who cares what the wind correction is. I am
having trouble imagining how this would help a controller - in training
or not.
This is for enroute training, Travis. It is not the crab angle we are
after, but the winds aloft. If we could pull the actual (or even just
forecast) winds aloft into this system, we'd be set. Unfortunately,
I'm told that data cannot be used for this purpose. I don't know if it
is inaccessible or if there is a contractual reason we can't get to it.
The bottom line is that we have only radar data to estimate the winds.
I see no other way of estimating the winds with this data. I hope that
this eventually provides us a workable solution. I've seen too many
trainees make bad decisions because they didn't consider the effects of
the wind to discount the usefulness of this information. A fair number
of operational errors occur because controllers don't use the wind to
their advantage.
By the way, my wife fell in love with Chicago on our trip last weekend,
so I'll be in your neck of the woods much more often. Atlantic
Aviation at Midway made us feel very welcome. :-)
Chad Speer
PP-ASEL, IA
Looking for a math wiz! Chad Speer Piloting 41 December 28th 06 10:11 AM
Help with 152 math pittss1c Piloting 12 May 13th 05 01:47 PM
# of Aircraft Club Members - Math Formula Wanted Rich Owning 3 September 16th 04 04:08 PM
Math help request ? Snead1 Soaring 5 June 8th 04 11:15 PM
Student invents new math process Otis Willie Military Aviation 29 December 2nd 03 02:13 AM
