![]() "Stefan" wrote in message ... d&tm schrieb: if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. I give up, can you please explain how there can be 2 ? |
![]() "d&tm" wrote in message ... "Stefan" wrote in message ... d&tm schrieb: if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. I give up, can you please explain how there can be 2 ? There are two possible situations for the wind correction. You do not know the direction of the correction for wind ( i.e. is the plane crabbing left or right to compensate for x-wind) you only know the magnitude (wind speed). Think of the triangle that is formed by vectors on the e6b. Without the direction, you have an ambiguous answer, looks like two similar triangles, a lefty and a righty. Someone else could probably explain this better, that's the basic idea. Mike |
"Michael Ware" writes:
"d&tm" wrote "Stefan" wrote d&tm schrieb: if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. I give up, can you please explain how there can be 2 ? There are two possible situations for the wind correction. You do not know the direction of the correction for wind ( i.e. is the plane crabbing left or right to compensate for x-wind) you only know the magnitude (wind speed). Think of the triangle that is formed by vectors on the e6b. Without the direction, you have an ambiguous answer, looks like two similar triangles, a lefty and a righty. Someone else could probably explain this better, that's the basic idea. And a simple explanation of the whole process is that the wind triangle has three (vector) components: heading, course, and wind. The vector sum of heading and wind gives course which is the problem that pilots are accustomed to solving. Rearranging the equation so as to compute wind given heading and course is not at all difficult. The law of cosines allows determination of the third side of a triangle given two sides and the included angle. The law of sines allows determining the other two angles given the three sides. There is no left/right ambiguity given the course and heading. |
Help with 152 math | pittss1c | Piloting | 12 | May 13th 05 01:47 PM |
Another Math Question | Dan Nafe | Home Built | 2 | May 4th 05 01:50 AM |
# of Aircraft Club Members - Math Formula Wanted | Rich | Owning | 3 | September 16th 04 04:08 PM |
Math help request ? | Snead1 | Soaring | 5 | June 8th 04 11:15 PM |
Student invents new math process | Otis Willie | Military Aviation | 29 | December 2nd 03 02:13 AM |
