#21
![]() "Steven P. McNicoll" wrote in message .net... "Stan Prevost" wrote in message ... Of course there is something to intercept. There is the final approach course. By definition, it extends southward from the runway on a course of 182 degrees forever, to SENNA and beyond. RNAV/GPS equipment does not need a navaid signal overlying the FAC to allow me to navigate it. I can intercept and track that FAC with my GNS430 GPS, and it will even draw a magenta line for me on the map. You're mistaken. About what? |
Sam Spade wrote: Stan Prevost wrote: "Sam Spade" wrote in message ... The pilot can go to OBS mode and select FRZZN as the active waypoint, then select bearing 002 mag to FRZZN. You don't have to use OBS mode, at least on the GNS430. Use DIRECT TO, then set the course. This way draws a line on the map, OBS doesn't. That won't work with the GNS400/500 series. Doing it the way I describe will provide a course line. I don't have a clue about the 480. ;-) On the 480, I would hit the VTF soft key (assuming I've already got the approach loaded with some arbitrary IAF selected). At that point, the box would create a segment from [a point 50(*) miles 182 degrees from FRZZN] to FRZZN, make that the active leg (i.e. draw it in magenta on the map), and go into suspend mode. Assuming I was given a good vector, flew it correctly, and had sufficient fuel, I would eventually intercept that segment. At that time the box would automagically come out of suspend mode. When I reached FRZZN, it would sequence to FRZZN-MAP36 being the active leg. (*) I think it's 50 miles. Could be something else, but it's long enough that it's never been an issue for me. |
Sam Spade writes:
That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Sam Spade writes: That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). -- Transpose mxsmanic and gmail to reach me by e-mail. The point, though, was to have the magenta line along the final approach course, not on the direct path between the present position and the fix. |
![]() "Steven P. McNicoll" wrote in message k.net... "Stan Prevost" wrote in message ... You don't have to use OBS mode, at least on the GNS430. That would imply that there are variations in the way different model GPS receivers perform. Use DIRECT TO, then set the course. This way draws a line on the map, OBS doesn't. DIRECT TO where? The clearance was to turn ten degrees and join the final approach course. Set the GPS for Direct To SENNA course 002. Then turn ten degrees and join the final approach course. Complies with the clearance. |
"Stan Prevost" wrote: "Steven P. McNicoll" wrote in message k.net... "Stan Prevost" wrote in message ... You don't have to use OBS mode, at least on the GNS430. That would imply that there are variations in the way different model GPS receivers perform. Use DIRECT TO, then set the course. This way draws a line on the map, OBS doesn't. DIRECT TO where? The clearance was to turn ten degrees and join the final approach course. Set the GPS for Direct To SENNA course 002. Then turn ten degrees and join the final approach course. Complies with the clearance. Stan, Just curious why you picked SENNA and not FRZZN as the waypoint. From "Turn left 10 degrees to intercept the final approach course", I'd assume I'd intercept outside of FRZZN, but perhaps not outside of SENNA. I would think -D- FRZZN with a course of 002 would make more sense. |
![]() "Roy Smith" wrote in message ... Set the GPS for Direct To SENNA course 002. Then turn ten degrees and join the final approach course. Complies with the clearance. Stan, Just curious why you picked SENNA and not FRZZN as the waypoint. From "Turn left 10 degrees to intercept the final approach course", I'd assume I'd intercept outside of FRZZN, but perhaps not outside of SENNA. I would think -D- FRZZN with a course of 002 would make more sense. In Steven's original scenario, the intercept was way south, so I didn't worry about it too much and didn't give it too much thought, as it wasn't important to the point under discussion. I don't see any reason that FRZZN wouldn't work, although having SENNA as a waypoint provides a definite point where you are established on a published segment of the approach and can begin descent in accordance with the published procedure. Your clearance will also contain an altitude to maintain until becoming established on a published segment. If you are close enough that you might intercept inside SENNA, the TO waypoint will switch to FRZZN when you pass by SENNA, serving the same purpose. |
#28
Isn't this an RNAV approach?
http://www.naco.faa.gov/d-tpp/0612/09092R35.PDF Mark "Steven P. McNicoll" wrote in message .net... "Roy Smith" wrote in message ... Sure. And what's so cool about the internet today is that not only can I show you the chart for the approach (http://204.108.4.16/d-tpp/0612/00286VDG24.PDF), I can also show you how we flew it (http://flightaware.com/live/flight/N...953Z/KHPN/KPOU) . Now all we need are the ATC tapes and a webcam sitting on the pilot's shoulder :-) On the other hand, I'm not sure if a "... or GPS ..." approach is quite the same thing as a "RNAV GPS ..." approach. No, RNAV approaches have RNAV in the name. |
#29
Stan Prevost writes:
The point, though, was to have the magenta line along the final approach course, not on the direct path between the present position and the fix. On the GNS530, you can insert a waypoint into your currently active flight plan. If you put it after the current fix, it will be inserted in your current route from your last waypoint. I don't have it in front of me so I don't recall the exact sequence, but you can put stuff in and take it out on the fly. Approaches are different, though, since changing them seems to mutate them into regular routes. I don't use approaches and the like too much on the GPS, since it's harder to get it working than to fly it by hand (or by autopilot). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
Steven P. McNicoll wrote:
Use DIRECT TO, then set the course. This way draws a line on the map, OBS doesn't. DIRECT TO where? The clearance was to turn ten degrees and join the final approach course. Any point on the final approach course. One of the 480 "DIRECT" modes is to set a course to/from an the thing you are going "DIRECT" to. It's one of the options along with "enter a holding pattern at that point". You're prompted for the course. The VTF button is a much cleaner way of doing this. |
Contact Approach -- WX reporting | [email protected] | Instrument Flight Rules | 64 | December 22nd 06 01:43 PM |
RNAV Operations in FS2004 | Rookie | Instrument Flight Rules | 2 | November 29th 06 11:51 PM |
RNAV approaches | Kevin Chandler | Instrument Flight Rules | 3 | September 18th 03 06:00 PM |
RNAV approaches | Kevin Chandler | Piloting | 3 | September 18th 03 06:00 PM |
Slam dunk into Janesville | Steven P. McNicoll | Piloting | 0 | July 31st 03 01:08 AM |
