Ron Lee wrote:
Congrats on a safe landing. Do keep us informed on actual cause. I don't think that it will ever be possible to say absolutely, but after a day of discussions on the COZY and canard-aviators mailing list, and a ton of email from many experts (Burt Rutan and Mike Melvill, both of whom I work for, included), the consensus (with which I agree) is that the prop bolt torque was low, causing bolt failure. For Mike Regish, yes, the bolts were safety wired, but as Bob Moore points out, with a wood core prop that doesn't necessarily mean diddly :-). .... I also have a Catto three blade prop on an RV-6A. The "undertorqued" option seems unlikely since you no doubt can properly torque bolts. You know, however smart, qualified, and wonderful a person may or may not be, mistakes can be made. I know that I make them at least my fair share. I might have screwed up in my torqueing technique; I might have had one or two bolts that were bottomed out; I might have had them loosen due to temperature/humidity changes; or who knows what. Is there a chance that a change in humidity from your normal location caused a change in torque? Well, I've been out here in the desert for over a year now, but it's possible that even when I THOUGHT I was testing the REAL torque, I wasn't, since I didn't loosen them and retighten them - I just pushed on the torque wrench. I will heretofore be checking torque at every oil change, rather than only at the condition inspection. Finding the prop could answer a lot of questions. It could, but this is the classic needle in the haystack. No roads nearby at all. To me, it's not even remotely worth the effort to find. -- Marc J. Zeitlin http://www.cozybuilders.org/ Copyright (c) 2006 |
Plastic planes are fast but landing speed too high | P S | Owning | 30 | June 20th 06 10:30 PM |
plane crashed on takeoff attempt after emergency landing | Toks Desalu | Piloting | 33 | November 1st 05 03:31 PM |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
C-17 Emergency Landing in Baghdad--CNN Report | Kevin Brooks | Military Aviation | 0 | December 10th 03 02:35 PM |
Military jet makes emergency landing at MidAmerica | Otis Willie | Military Aviation | 0 | September 1st 03 02:28 AM |
