"Sam Spade" wrote in message ...
With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. |
John R. Copeland wrote:
"Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. |
![]() "Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. Do you have a link to the TSO handy? And is it the full requirement? Last time I tried to read TSO C129, seems like it was a skeleton document, referencing a commercial spec that had to be purchased. |
Stan Prevost wrote:
"Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. Do you have a link to the TSO handy? And is it the full requirement? Last time I tried to read TSO C129, seems like it was a skeleton document, referencing a commercial spec that had to be purchased. Same with 145/146. The nuts-and-boths is in RTCA Doument 229C. $350. |
John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. I'm definitely gonna have to set up an experiment over that! I'd expect to have noticed it, if my CNX80 behaved that way. Is that a behavior demanded by TSO-C145/146, or merely allowed? |
"Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. I'm definitely gonna have to set up an experiment over that! I'd expect to have noticed it, if my CNX80 behaved that way. Is that a behavior demanded by TSO-C145/146, or merely allowed? Stay tuned. |
"Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. I'm definitely gonna have to set up an experiment over that! I'd expect to have noticed it, if my CNX80 behaved that way. Is that a behavior demanded by TSO-C145/146, or merely allowed? The following language suggests that LNAV must always be 350 feet at the MAP. Both Figures 2-12 and 2-13 show 350 at the MAP. 2.2.3.3.1 Approach Path Definition If the pilot has not selected a VTF approach, deviations shall be provided with respect to the active leg of the approach procedure. See Figure 2-12. If the pilot has selected a VTF approach, deviations shall be provided relative to the inbound course to the FAF. See Figure 2-13. The active waypoint shall initially be the FAWP. The equipment should also account for short turns onto the final approach where the FAWP may not be crossed. Note 1: A VTF approach can be selected at any time. |
Haven't flown in a long while... | Flyingmonk | Piloting | 33 | April 5th 06 06:30 AM |
Total cross country distance flown | Bill Daniels | Soaring | 9 | November 4th 05 11:53 AM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | Piloting | 1 | February 8th 05 06:45 PM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | General Aviation | 0 | February 2nd 05 04:11 AM |
Most aircraft types flown by 1 pilot? | Chad Irby | Military Aviation | 10 | January 7th 04 03:47 AM |
