Looking for a math wiz!
Old December 19th 06, 01:57 AM posted to rec.aviation.piloting,rec.aviation.ifr
Travis Marlatte
Default Looking for a math wiz!
Chad,
I think that some clarification of the use might help. I can imagine two
scenarios:
1) enroute - in this case, you know the track and ground speed from radar.
You have the filed TAS. You have no idea of the crab angle or heading. This
sounds like the information you presented in your question. However,
enroute, who cares what the wind correction is. I am having trouble
imagining how this would help a controller - in training or not.
2) terminal - in this case, you still know the track and ground speed from
radar. However, now the filed TAS is probably no longer valid since it is
probably at a lower altitude than filed and used to compute the TAS. The
plane may also be under speed constraints. On the other hand, the controller
may be vectoring so now you have an assigned heading and maybe even an
assigned speed. You also have the pressure for the area and the TAS can be
computed from that and radar data. If this were an automated computation, it
could be done on every plane that was given an assigned speed (or even IAS
queried from the pilot) and an assigned heading (or even queried from the
pilot). Now maybe not every plane can provide all of the data but certainly
some could. Enough to update the calculated wind periodically.
Scenario 2 seems to me the one that would make knowledge of the wind most
desirable. It is also the scenario that could provide additional data and
certainly provides different data than what was posed in your question.
What say you?
Travis
Lake N3094P
PWK
Old December 19th 06, 05:03 AM posted to rec.aviation.ifr
Chad Speer
two scenarios:
radar. You have the filed TAS. You have no idea of the crab angle or
heading. This sounds like the information you presented in your
question. However, enroute, who cares what the wind correction is. I am
having trouble imagining how this would help a controller - in training
or not.
This is for enroute training, Travis. It is not the crab angle we are
after, but the winds aloft. If we could pull the actual (or even just
forecast) winds aloft into this system, we'd be set. Unfortunately,
I'm told that data cannot be used for this purpose. I don't know if it
is inaccessible or if there is a contractual reason we can't get to it.
The bottom line is that we have only radar data to estimate the winds.
I see no other way of estimating the winds with this data. I hope that
this eventually provides us a workable solution. I've seen too many
trainees make bad decisions because they didn't consider the effects of
the wind to discount the usefulness of this information. A fair number
of operational errors occur because controllers don't use the wind to
their advantage.
By the way, my wife fell in love with Chicago on our trip last weekend,
so I'll be in your neck of the woods much more often. Atlantic
Aviation at Midway made us feel very welcome. :-)
Chad Speer
PP-ASEL, IA
ATCS, Kansas City ARTCC
Looking for a math wiz! Chad Speer Piloting 41 December 28th 06 10:11 AM
Help with 152 math pittss1c Piloting 12 May 13th 05 01:47 PM
# of Aircraft Club Members - Math Formula Wanted Rich Owning 3 September 16th 04 04:08 PM
Math help request ? Snead1 Soaring 5 June 8th 04 11:15 PM
Student invents new math process Otis Willie Military Aviation 29 December 2nd 03 02:13 AM
