Courious Crash
Old December 19th 06, 03:51 AM posted to rec.aviation.piloting
john smith
Default Courious Crash
Sunday evening, 17 December, a small plane crashed two miles south of
the Bucyrus Ohio airport (17G). A family of four (father, mother, two
children) died in the crash. There was minor damage to an apartment
building from flying debris, and no injuries to those on the ground.
The husband and wife are reported to have been pilot rated and
preliminary reports describe the aircraft as a 60's/70's Comanche.
Witnesses on the ground reported the engine sputtering and seeing sparks
coming from the airplane prior to the crash.
The aircraft had departed Oklahoma earlier in the afternoon.
Q: what are the possible ranges of various models of Comanche's?
My speculation...
Oklahoma to Bucyrus Ohio is a long haul. If the engine is sputtering, I
am guessing fuel exhaustion.
That it was within two miles of the airport makes me strongly think they
were stretching it.
Tulsa OK to Bucyrus OH is 665 nm. Fuel burn on a Comanche 260 is what?
14 per hour?
Cruise speed is 160 kts?
That gives about five hours and 700 nm.
How close am I?
Old December 19th 06, 04:01 AM posted to rec.aviation.piloting
Dan[_1_]
14 per hour is what I use for planning in a Comanche 260. With aux
tanks, we're talking about 84 gallons usable. 84/14 = 6 hours of
cruise at 155 kts. = 930nm to dry tanks.
If there were no aux tanks, that's 56 gallons usable/14 = 4 hrs x 155
kts = 620nm.. with a tailwind, you just might run dry slightly short of
the airport in that scenario.
I've also noticed that line folks often leave the tanks less than
completely topped due to the nature of the tanks looking full when they
still have room. A few weeks back, I called the lineman back to the
plane and he added 5 gallons after "topping it off" earlier. Maybe
that's a bit "anal" but on a night/IFR flight from Oakland, CA to
Phoenix I want all the fuel I can get... that's an extra 22 minutes of
cruise.
--Dan
My speculation...
were stretching it.
14 per hour?
How close am I?
Old December 19th 06, 04:49 AM posted to rec.aviation.piloting
Jose[_1_]
still have room.
If a tank is completely topped off in the cool evening air, how much gas
will pour overboard when the wing heats up in the noonday sun?
I know - "it depends". Let's take as an example a cherokee 24 gallon
wing, 45 degrees at night, 80 degrees under hot spring sun. Or
something similar. Could one lose more than a gallon per tank?
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Orval Fairbairn
My speculation...
were stretching it.
14 per hour?
How close am I?
I have never had an engine "sputter" when a tank goes dry! They just
quit until you switch tanks.
Old December 19th 06, 08:42 AM posted to rec.aviation.piloting
Montblack
("Orval Fairbairn" wrote)
I have never had an engine "sputter" when a tank goes dry! They just quit
....plus the "sparks" before the crash. ???
Montblack
Old December 19th 06, 01:10 PM posted to rec.aviation.piloting
Jim Macklin
§ 23.969 Fuel tank expansion space.
Each fuel tank must have an expansion space of not less than
two percent of the tank capacity, unless the tank vent
discharges clear of the airplane (in which case no expansion
space is required). It must be impossible to fill the
expansion space inadvertently with the airplane in the
normal ground attitude.
"Nomen Nescio" wrote in message
| -----BEGIN PGP SIGNED MESSAGE-----
air, how much gas
sun?
cherokee 24 gallon
sun. Or
tank?
| A quick look at the Marks' Mechanical Engineers Handbook
puts
| the coefficient of expansion at about .0007.
| So I'd tend to say no.
| You're probably looking at a little over a half gallon.
| -----BEGIN PGP SIGNATURE-----
| Version: N/A
iQCVAwUBRYem+JMoscYxZNI5AQF09QQAmrNzWVb46u3Kp+PszB zVMBUUbnoXuRgi
BFoBxHBILrW4E0uLNlsv9SOpqhEYDffH52OGOp3QUrzb4LPnMo pMbucqldy9QdaV
V5MS8hMA0e0EO7XamlvaK77Rx2lp3mos/Viot31mWwNtnzLnAxot/9imkyOctIfC
| TxaJ3pMZdBw=
| =/h7e
| -----END PGP SIGNATURE-----
Old December 19th 06, 02:32 PM posted to rec.aviation.piloting
Paul Tomblin
One truth of NTSB reports is that non-pilot witnesses are *never*
reliable.
Paul Tomblin http://blog.xcski.com/
But seriously, I've got root, so it's his problem.
-- Nick Manka
Old December 19th 06, 04:46 PM posted to rec.aviation.piloting
Jose[_1_]
I don't know whether cherokees have expansion space, but they do have a
fuel vent that vents fuel "clear of the airplane" (as far as I can tell).
However, I would infer from the reg that 2% would be typical of expected
expansion. So, half a gallon loss out of a 24 gallon tank would not be
outrageous.
Am I missing something?
Jose
Old December 19th 06, 07:23 PM posted to rec.aviation.piloting
John Clonts
reliable.
Statements asserting "always" or "never" are always wrong!
Old December 19th 06, 07:49 PM posted to rec.aviation.piloting
Christopher Campbell[_1_]
On Mon, 18 Dec 2006 19:51:14 -0800, john smith wrote
(in article ):
My speculation...
were stretching it.
14 per hour?
How close am I?
Who knows? No one here knows any more about it than anyone else. We do not
even know if they stopped to refuel along the way. You don't know when the
oil was last changed, what kind of weather briefing he got, when the last
annual was, the condition of the electrical system, or anything else. So it
seems to be going out on a limb to be immediately suspecting fuel exhaustion.
Pilots in general have a pretty good idea of how far they can fly on a full
tank and they do not intentionally stretch it. Most of the guys who get in
trouble with fuel exhaustion seem to be people who encounter unexpected
headwinds, had to divert to another airport for some reason, or who did not
find fuel where they expected it.
So, I would not assume fuel exhaustion right off the bat. In fact, from the
facts given, I would not assume anything.
One thing I do know -- these people had family and friends, some of whom
might read these news groups.
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Pilot claims no blame in July crash Mortimer Schnerd, RN Piloting 48 March 15th 06 09:00 PM
Doubts raised in jet crash Dave Butler Piloting 8 July 26th 05 01:25 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
