Jay Honeck wrote:
I did a flight shortly after getting the 396 installed. I had the altitude voice on, and had a multi-leg route programmed into it as the active flight. I decided to land at an intermediate airport that wasn't at the end of the flight plan. The voice came on during final approach with terrain warnings and demands to "pull up". Thought it was rather amusing but it is probably a good feature to have. That's a neat feature -- although I'm glad you told me about it *before* it surprised me. Can you imagine flying a newbie somewhere for lunch, diverting to a different, nearby airport, and having THAT come over the intercom turning base to final? Hi Jay, You can get the same warning even at the destination airport. I talked to a Garmin engineer who explained how they decide whether you are landing or just too close to terrain. At the destination airport, there is a virtual surface that is lower along the axis of the *primary* runway at the airport. If you break that surface, you get the warning. Landing on some runway other than the primary runway, the virtual surface is higher and you are more likely to get the warning. For example, I get it all the time when landing on runway 32 at RDU (Raleigh/Durham, NC). The primary runways at RDU are 05/23 L and R. There seem to be some other anomalies where you can get the warning. I used to get it all the time when turning final for runway 21 at TTA (Sanford, NC). I never could find anything unusual about the terrain or obstructions there. I think another r.a.o poster also mentioned this anomaly. Come to think of it, I just did that landing the other day, and didn't get the warning, so maybe they've changed something in the later versions of the firmware. I try to remember to warn my Angel Flight passengers that they might hear the warning. It's quite alarming if you're not prepared for it. Dave |
![]() You can get the same warning even at the destination airport. ..stuff snipped There seem to be some other anomalies where you can get the warning. I used to get it all the time when turning final for runway 21 at TTA (Sanford, NC). I never could find anything unusual about the terrain or obstructions there. I think another r.a.o poster also mentioned this anomaly. Come to think of it, I just did that landing the other day, and didn't get the warning, so maybe they've changed something in the later versions of the firmware. I get the "pull up" terrain warning on my 396 when turning base at too high a sink rate. We have towers nearby and my theoretical flight path would put me too close to them if I did not turn final. Somehow I am outside the zone of "landing" at that point. With the aerodynamics of a 2 by 4, I come in a wee bit higher than some expect (Cherokee 140 - nuff' said). I finally see "red over white" on short final. Maybe that does it. It seems to be coupled to the sink rate cuz I sometimes get it on final. Mike |
Mike Spera wrote:
With the aerodynamics of a 2 by 4, I come in a wee bit higher than some expect (Cherokee 140 - nuff' said). I finally see "red over white" on short final. Is that because you're doing power-off landings? I fly a Warrior, which I assume has simular aerodynamics, and have no problem holding the glideslope. With power in, you'd be able to control the descent rate, no? .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
2 by 4, I come in a wee bit higher than some expect (Cherokee 140 - nuff' said). I finally see "red over white" on short final. Is that because you're doing power-off landings? I fly a Warrior, which I assume has simular aerodynamics, and have no problem holding the glideslope. With power in, you'd be able to control the descent rate, no? That's the way I do it, too (and I think most Cherokee pilots carry a bit of power to land smoothly) -- but a lot of guys like to do power-off landings, just to prepare themselves for the eventuality of a failed engine in the pattern. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Alan Gerber wrote:
Mike Spera wrote: With the aerodynamics of a 2 by 4, I come in a wee bit higher than some expect (Cherokee 140 - nuff' said). I finally see "red over white" on short final. Is that because you're doing power-off landings? I fly a Warrior, which I assume has simular aerodynamics, and have no problem holding the glideslope. With power in, you'd be able to control the descent rate, no? ... Alan No, No, No, my friend. The tapered wing is WAY different than a constant chord wing. Power is at around 17500 rpm and it sinks like a rock. Go for a ride in a 140 and you will be enlightened (or scared to death). Yes, you can control the descent rate right at 500fpm. But, you do so at a MUCH greater angle to the ground than your Warrior. First time I flew a tapered wing I could not believe how flat you had to come in to avoid floating right past the airport. If you tried that with the 140, your CFI would immediately pull the power back and announce "Engine Out" and laugh while you quickly figured out you would NEVER make the runway. Try it out. Mike |
MVAs in AZ | Dan | Instrument Flight Rules | 36 | September 16th 06 02:19 AM |
Naval Aviators | jsmith | Piloting | 1 | March 25th 04 02:56 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
gps altitude accuracy | Martin Gregorie | Soaring | 12 | July 18th 03 08:51 PM |
