![]() Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan |
oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan About 25+ years ago at one of our local airports, in southeastern Florida, the rag draggers used to make a very short takeoff at roughtly mid-field, level off at around 50 feet, and make a very steep turn to transition across the airport to their pick-up area. One had a mishap, and after that the operation was much more conservative. I never heard the details or extent of damage, but suspect that the apparent headwind may have only been a long gust. Peter |
Was that accident at FXE?
Frank "Peter Dohm" wrote in message ... wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan About 25+ years ago at one of our local airports, in southeastern Florida, the rag draggers used to make a very short takeoff at roughtly mid-field, level off at around 50 feet, and make a very steep turn to transition across the airport to their pick-up area. One had a mishap, and after that the operation was much more conservative. I never heard the details or extent of damage, but suspect that the apparent headwind may have only been a long gust. Peter |
No, at North Perry (HWO)
Peter "Frank Barchi" wrote in message . net... Was that accident at FXE? Frank "Peter Dohm" wrote in message ... wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan About 25+ years ago at one of our local airports, in southeastern Florida, the rag draggers used to make a very short takeoff at roughtly mid-field, level off at around 50 feet, and make a very steep turn to transition across the airport to their pick-up area. One had a mishap, and after that the operation was much more conservative. I never heard the details or extent of damage, but suspect that the apparent headwind may have only been a long gust. Peter |
Well... it's like this... The story was told to me one day back around 1980,
after the operational techniques had suddenly changed--and become much more conservative. I just checked FAA's accident database for Hollywood, FL for the period from 1970 through 1990 and found no refference to any similar accident. At this point, I can only presume that someone was "yanking my chain" and I made the mistake of repeating the story without checking it out, even though such stories are now quite easy to verify. Peter Sorry about the incorrect report. "Peter Dohm" wrote in message news:1Mmih.895$_X.3@bigfe9... No, at North Perry (HWO) Peter "Frank Barchi" wrote in message . net... Was that accident at FXE? Frank "Peter Dohm" wrote in message ... wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan About 25+ years ago at one of our local airports, in southeastern Florida, the rag draggers used to make a very short takeoff at roughtly mid-field, level off at around 50 feet, and make a very steep turn to transition across the airport to their pick-up area. One had a mishap, and after that the operation was much more conservative. I never heard the details or extent of damage, but suspect that the apparent headwind may have only been a long gust. Peter |
![]() wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. The theory about that accident in the RV community is that the pilot had used the seatbelt on the passenger's side as a control lock, was in a rush to leave the show, and didn't do a control check before takeoff. With the belt latched, the elevator was in an "up" configuration, and the rest, unfortunately, is history. KB snip Dan |
"Kyle Boatright" wrote in message
. .. The theory about that accident in the RV community is that the pilot had used the seatbelt on the passenger's side as a control lock, was in a rush to leave the show, and didn't do a control check before takeoff. With the belt latched, the elevator was in an "up" configuration, and the rest, unfortunately, is history. That was a popular theory, true, and not just among RVers. However, the NTSB carefully looked at the possibility and while they could not with 100% certainty exclude that possibility, the investigation showed no evidence whatsoever that the controls were secured by the seatbelt on takeoff, and some reasonable evidence that they were not (in particular, there was no burn residue of the seatbelt found on the control stick, in spite of there being seatbelt burn residue elsewhere...also, several witnesses failed to note any unusual deflection of the elevator, as would be readily apparent if the theory were true). The final NTSB conclusion was "The pilot's excessive climb rate, which lead to his failure to maintain an airspeed above stalling speed", with the "seatbelt control lock" theory carrying no weight at all. http://www.ntsb.gov/ntsb/brief2.asp?...FA105& akey=1 Pete |
Garmin 300XL GPS Approach didn't arm | Steve S | Instrument Flight Rules | 9 | May 11th 06 02:54 AM |
Trust those Instruments.... Trust those Instruments..... | A Lieberman | Instrument Flight Rules | 1 | May 2nd 06 03:54 PM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Where is approach good about multiple approaches and clearances in the air? | Andrew Gideon | Instrument Flight Rules | 29 | February 14th 04 02:51 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
