Smart Turbo Diesel or VW Lugo Diesel
Old December 20th 06, 10:37 PM posted to rec.aviation.homebuilt
bbutlergps
Default Smart Turbo Diesel or VW Lugo Diesel
Morgans wrote:
"bbutlergps" wrote
The Mercedes-Benz A Class 1.7 from Thielert Centurion even being light
alloy weighs in at just under 300 lbs. Too much for the 701. Being that
the smaller mercedes 3 cylinder diesel has been put in some planes
including the 701, 601 FK-9 as well as ultra lights but I feel that
they lack the HP needed.
Keep in mind that the diesel engines in airplanes tend to give the same
performance as a gas engine of up to 25% more HP. Would that make a difference
in the HP figures, in your case?
Jim in NC
Still haven't gotten any information on the Smart Mercedes 3 cyl. 95 hp
diesel found in the Smart ForFour of the Mitisibishi Colt such as
weight. I did however come across VW Lupo engine. This 1.2 engine is
found in Audi A2 and VW Lupo. It is all aluminum.
Diesel engines
Three cylinder
3L 1.2 TDI
This inline three cylinder is notorious for being the powerplant of the
Lupo 3L and A2 3L, both VAG cars with a low consumption of only three
liters per hundred kilometers (94 mpg/78 US mpg). It is based on the
1.4 TDI version but the block is made of aluminium and the elements are
lighter.
Configuration
Diesel 1191 cc inline three cylinder
Block
bore × stroke 76.5 × 86.4 mm, aluminum
Head
aluminum, 2 valves, overhead camshaft, 19.5 compression ratio
Aspiration
turbocharger
Fuel
Pump direct injection (PD Pump injector, Pumpe-Düse)
Dimensions
100 kg
Output
45 kW (61 hp) @ 4000 rpm, 140 N·m between 1800 and 2400 rpm, 80%
available from 1300 rpm
Applications
Audi A2, VW Lupo 3L
references
Audi AG (1999-11-28). Audi A2 1.2 TDI: The three-litre car from
Audi. Press release.
This engine can be chipped up to 75 hp.
I know, don't believe the chip turners, figure in cooling, PSRU, etc
weight while and there is other powerplants out there.
But I am in for discussion of LSA diesel power aircraft that the power
plant doesn't cost more than the aircraft.
Thanks,
Bill
Old December 20th 06, 11:14 PM posted to rec.aviation.homebuilt
Peter Dohm
"bbutlergps" wrote in message
ps.com...
difference
Jim in NC
Diesel engines
Three cylinder
3L 1.2 TDI
lighter.
Configuration
Block
Head
Aspiration
turbocharger
Fuel
Dimensions
100 kg
Output
Applications
Audi A2, VW Lupo 3L
references
Thanks,
Bill
My own concern with reprogrammed chips is not so much whether the results
are credible, although that is certainly an issue, but the possible effect
on reliability.
I would expect engine manufacturers program their engine controls based a
compromise between the performance they can demonstrate and the costs of
reliability problems and attendant warranty costs. Therefore, I am less
than enthusiastic about the idea of "souping up" an engine for use in an
aircraft--especially single engine.
Peter
I've been wrong before...
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Smart CDI diesel engine Hans Zwakenberg Home Built 14 January 9th 05 12:32 PM
turbo stc? The Weiss Family Owning 21 October 3rd 04 10:35 PM
