Dumb Question
Old December 20th 06, 09:21 PM posted to rec.aviation.rotorcraft
Stefan Lörchner
Default Dumb Question
My guess is that because the tips are enclosed inside a duct that there
is no vortex or boundary effects at the tips?
Although some VTOL aircraft have been designed with ducted fans, I think the
biggest reason for a lack of interest in that area is that you loose the
ability to perform emergency landings by autorotation. And that's a biggie
Why should a ducted fan/rotor not be capable of working in autorotation?
I never heard about that and cannot find a reason.
Old December 20th 06, 09:57 PM posted to rec.aviation.rotorcraft
Maxwell
How could it? With a duct around it, would you not have to descend straight
down? And if you did, would the rotational mass of a rotor that small in
diameter, and designed to work at such a high rpm, store enough energy in
free fall, to stop your descent when you applied collective to land?
Old December 22nd 06, 01:24 AM posted to rec.aviation.rotorcraft
Stefan Lörchner
Straight down can be a possibility. But if you can fly the thing, you
can also tilt the thrust vectors. So just tilt it so that the airflow
matches airspeed like in a heli.
That's a design issue since it is not free fall. Otherwise it wouldn't
be autorotation. The rotors/fans would of course have a windmilling
braking effect. And certainly, the inertia has to be sufficient to allow
smooth and preferably save touchdown as should be the case in every
helicopter.
Smaller and faster rotors are less effective and therefore need more
descent rate (more power). That's fact, too. Compare the sink rate in
autorotation of a Hughes 500 and a R44 (or the HV diagrams).
DUMB ROOKIE QUESTION Travis Beach Soaring 10 November 7th 06 07:28 PM
stupid question JaKoB General Aviation 2 November 9th 04 09:48 AM
Dumb Transponder Question! John P Owning 2 March 30th 04 01:26 AM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
