Chris wrote:
There is no problem setting up a descent to bring you under cloud providing that whilst in cloud you remain 1000 feet above the highest obstacle within five miles either side of your track and once through the cloud are in VFR conditions. The above cannot be done in the US. We can descend to the MEA (which varies, ATC knows and will tell us), and if we are not in VFR conditions, then we have to do an intrument approach. MEA's are higher than 1000 AGL I can tell you that. MEA's are not published, but ATC has a map of them. Radar coverage madatory for IFR flight (with one exception, Class G). I don't honestly know what the rules are for descent in Class G with no radar and no IFR clearance. I don't think there are any. It doesn't happen much, almost all our IFR flight is with radar coverage and ATC clearances etc. |
Misposted a bit, radar coverage is not mandatory for IFR flight but ATC
clearance is and it USUALLY includes radar coverage. |
Doug wrote:
Misposted a bit, radar coverage is not mandatory for IFR flight but ATC clearance is and it USUALLY includes radar coverage. ATC clearance is mandatory for IFR flight IN CONTROLLED AIRSPACE. It is neither necessary nor available outside. Radar coverage while pretty pervasive isn't a requirement for nor a guarantee of an IFR clearance availability. Nearly all flights begin and end outside of radar coverage, some outside of controlled airspace. |
In controlled airspace. In uncontrolled airspace no ATC
service is available and neither is a clearance. But IFR is possible using the big sky random principle. § 91.177 Minimum altitudes for IFR operations. (a) Operation of aircraft at minimum altitudes. Except when necessary for takeoff or landing, no person may operate an aircraft under IFR below- (1) The applicable minimum altitudes prescribed in parts 95 and 97 of this chapter; or (2) If no applicable minimum altitude is prescribed in those parts- (i) In the case of operations over an area designated as a mountainous area in part 95, an altitude of 2,000 feet above the highest obstacle within a horizontal distance of 4 nautical miles from the course to be flown; or (ii) In any other case, an altitude of 1,000 feet above the highest obstacle within a horizontal distance of 4 nautical miles from the course to be flown. However, if both a MEA and a MOCA are prescribed for a particular route or route segment, a person may operate an aircraft below the MEA down to, but not below, the MOCA, when within 22 nautical miles of the VOR concerned (based on the pilot's reasonable estimate of that distance). (b) Climb. Climb to a higher minimum IFR altitude shall begin immediately after passing the point beyond which that minimum altitude applies, except that when ground obstructions intervene, the point beyond which that higher minimum altitude applies shall be crossed at or above the applicable MCA. 91.179 IFR cruising altitude or flight level. (a) In controlled airspace. Each person operating an aircraft under IFR in level cruising flight in controlled airspace shall maintain the altitude or flight level assigned that aircraft by ATC. However, if the ATC clearance assigns "VFR conditions on-top," that person shall maintain an altitude or flight level as prescribed by §91.159. (b) In uncontrolled airspace. Except while in a holding pattern of 2 minutes or less or while turning, each person operating an aircraft under IFR in level cruising flight in uncontrolled airspace shall maintain an appropriate altitude as follows: (1) When operating below 18,000 feet MSL and- (i) On a magnetic course of zero degrees through 179 degrees, any odd thousand foot MSL altitude (such as 3,000, 5,000, or 7,000); or (ii) On a magnetic course of 180 degrees through 359 degrees, any even thousand foot MSL altitude (such as 2,000, 4,000, or 6,000). (2) When operating at or above 18,000 feet MSL but below flight level 290, and- (i) On a magnetic course of zero degrees through 179 degrees, any odd flight level (such as 190, 210, or 230); or (ii) On a magnetic course of 180 degrees through 359 degrees, any even flight level (such as 180, 200, or 220). (3) When operating at flight level 290 and above in non-RVSM airspace, and- (i) On a magnetic course of zero degrees through 179 degrees, any flight level, at 4,000-foot intervals, beginning at and including flight level 290 (such as flight level 290, 330, or 370); or (ii) On a magnetic course of 180 degrees through 359 degrees, any flight level, at 4,000-foot intervals, beginning at and including flight level 310 (such as flight level 310, 350, or 390). (4) When operating at flight level 290 and above in airspace designated as Reduced Vertical Separation Minimum (RVSM) airspace and- (i) On a magnetic course of zero degrees through 179 degrees, any odd flight level, at 2,000-foot intervals beginning at and including flight level 290 (such as flight level 290, 310, 330, 350, 370, 390, 410); or (ii) On a magnetic course of 180 degrees through 359 degrees, any even flight level, at 2000-foot intervals beginning at and including flight level 300 (such as 300, 320, 340, 360, 380, 400). "Doug" wrote in message ps.com... | Misposted a bit, radar coverage is not mandatory for IFR flight but ATC | clearance is and it USUALLY includes radar coverage. | |
Doug writes:
I don't honestly know what the rules are for descent in Class G with no radar and no IFR clearance. Class G is so close to the ground in most locations that you'll only be in it quite briefly during descent (or take-off), anyway, which I presume is why there aren't many rules concerning that airspace. Anyone who cruises for an extended period in Class G on instruments is either way out in the boondocks or very bold or both. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Doug wrote:
The above cannot be done in the US. We can descend to the MEA (which varies, ATC knows and will tell us), and if we are not in VFR conditions, then we have to do an intrument approach. MEA's are higher than 1000 AGL I can tell you that. MEA's are not published, but ATC has a map of them. MEA's are published. MVA's are not published. A minimum instrument altitude is always going to be 1000 above the terrain. Radar coverage madatory for IFR flight (with one exception, Class G). Absolutely INCORRECT. Radar coverage is not mandatory for flight in controlled airspace. An IFR clearance is, but radar is not necessary nor sufficient for a clearance. I don't honestly know what the rules are for descent in Class G with no radar and no IFR clearance Same as for controlled airspace 91.175 makes no distiction. ?. I don't think there are any. It doesn't happen much, almost all our IFR flight is with radar coverage and ATC clearances etc. Nonsense. Many airports with approaches exist outside of controlled airspace. |
Ron Natalie wrote:
Doug wrote: The above cannot be done in the US. We can descend to the MEA (which varies, ATC knows and will tell us), and if we are not in VFR conditions, then we have to do an intrument approach. MEA's are higher than 1000 AGL I can tell you that. MEA's are not published, but ATC has a map of them. MEA's are published. MVA's are not published. A minimum instrument altitude is always going to be 1000 above the terrain. Change that to "at least 1,000 feet above obstacles." (2,000 in DMAs). Nonsense. Many airports with approaches exist outside of controlled airspace. Cite an example, other than below 700 feet inside the FAF. |
Where are MEA'a published?
Doug wrote:
Where are MEA'a published? On Victor aiways. |
In controlled airspace, the MEA or MVA [radar] is
controlling unless you have a IAP. In Class G, you can fly under IFR in IMC w/o a clearance, but you can't climb into or fly sideways into any controlled airspace w/o first getting a clearance. You can descend for a landing then, | Chris wrote: | There is no problem setting up a descent to bring you under | cloud providing that whilst in cloud you remain 1000 feet above the highest | obstacle within five miles either side of your track and once through the | cloud are in VFR conditions." In mountainous areas the minimum is 2,000 feet and most areas of Class G large enough and high enough in which to fly IFR are in mountainous areas. The far western Kansas/eastern Colorado area comes to mind, there are only a handful of airports within those areas. Alaska pilots are probably the ones who do this type of flying on a regular basis. "Doug" wrote in message oups.com... | Chris wrote: | There is no problem setting up a descent to bring you under | cloud providing that whilst in cloud you remain 1000 feet above the highest | obstacle within five miles either side of your track and once through the | cloud are in VFR conditions. | | The above cannot be done in the US. We can descend to the MEA (which | varies, ATC knows and will tell us), and if we are not in VFR | conditions, then we have to do an intrument approach. MEA's are higher | than 1000 AGL I can tell you that. MEA's are not published, but ATC has | a map of them. Radar coverage madatory for IFR flight (with one | exception, Class G). I don't honestly know what the rules are for | descent in Class G with no radar and no IFR clearance. I don't think | there are any. It doesn't happen much, almost all our IFR flight is | with radar coverage and ATC clearances etc. | |
Is 91.175 enforced in the USA? | Ron Rosenfeld | Instrument Flight Rules | 4 | December 22nd 06 06:44 PM |
Is 91.175 enforced in the USA? | Jim Macklin | Instrument Flight Rules | 0 | December 20th 06 12:19 PM |
