Anyone flown atn LPV yet?
Old December 21st 06, 10:10 AM posted to rec.aviation.ifr
Sam Spade
Default Anyone flown atn LPV yet?
John R. Copeland wrote:
"Sam Spade" wrote in message ...
With LPV, the sensitivity continues to increase (course width decreases)
from the FAF to the runway. That causes LPV to be an angular system
from the FAF to the runway. Not so with other RNAV.
Thanks. I didn't know of the difference. I'll watch for it.
I getting up to speed on the 145/146 spec. The LNAV approach also
reduces in the lateral mode similar to the laternal mode of the LPV
approach. When you reach the MAP, it is only 350 feet full scale
deflection, instead of the 0.3 mile defection for TSO 129 LNAV final.
Old December 21st 06, 02:44 PM posted to rec.aviation.ifr
Stan Prevost
from the FAF to the runway. That causes LPV to be an angular system from
I getting up to speed on the 145/146 spec. The LNAV approach also reduces
in the lateral mode similar to the laternal mode of the LPV approach.
When you reach the MAP, it is only 350 feet full scale deflection, instead
Do you have a link to the TSO handy? And is it the full requirement? Last
time I tried to read TSO C129, seems like it was a skeleton document,
referencing a commercial spec that had to be purchased.
Old December 21st 06, 04:19 PM posted to rec.aviation.ifr
Sam Spade
Same with 145/146. The nuts-and-boths is in RTCA Doument 229C. $350.
Old December 21st 06, 03:12 PM posted to rec.aviation.ifr
John R. Copeland
I'm definitely gonna have to set up an experiment over that!
I'd expect to have noticed it, if my CNX80 behaved that way.
Is that a behavior demanded by TSO-C145/146, or merely allowed?
Old December 21st 06, 04:20 PM posted to rec.aviation.ifr
Sam Spade
Stay tuned.
Old December 21st 06, 05:07 PM posted to rec.aviation.ifr
Sam Spade
The following language suggests that LNAV must always be 350 feet at the
MAP. Both Figures 2-12 and 2-13 show 350 at the MAP.
2.2.3.3.1 Approach Path Definition
If the pilot has not selected a VTF approach, deviations shall be
provided with respect to the active leg of the approach procedure. See
Figure 2-12. If the pilot has selected a VTF approach, deviations shall
be provided relative to the inbound course to the FAF. See Figure 2-13.
The active waypoint shall initially be the FAWP. The equipment should
also account for short turns onto the final approach where the FAWP may
not be crossed.
Note 1: A VTF approach can be selected at any time.
Haven't flown in a long while... Flyingmonk Piloting 33 April 5th 06 06:30 AM
Total cross country distance flown Bill Daniels Soaring 9 November 4th 05 11:53 AM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch Piloting 1 February 8th 05 06:45 PM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch General Aviation 0 February 2nd 05 04:11 AM
Most aircraft types flown by 1 pilot? Chad Irby Military Aviation 10 January 7th 04 03:47 AM
