"Dan Luke" wrote: "Aluckyguess" wrote : The Cirrus needs the autopilot to fly straight and level. Baloney. well, I would need one since I'm left-handed. I know, I know, I'm in the minority here wrt side-sticks. But I really don't like side-sticks. Two things turned me off the Lancair ES: one was it was very heavy in roll, and the other was the side-stick. -- Bob Noel Looking for a sig the lawyers will hate |
"Bob Noel" wrote in message
... In article , "Dan Luke" wrote: "Aluckyguess" wrote : The Cirrus needs the autopilot to fly straight and level. Baloney. well, I would need one since I'm left-handed. I know, I know, I'm in the minority here wrt side-sticks. But I really don't like side-sticks. Two things turned me off the Lancair ES: one was it was very heavy in roll, and the other was the side-stick. -- Bob Noel Looking for a sig the lawyers will hate You may be in the minority WRT side sticks, or you may not. I used to think they were the coolest idea ever, at least if mounted on the right, until I got tennis elbow a couple of times. I still haven't ever tried a side stick; but I no longer have any desire for one because I now see the value in being able to switch hands. BTW, I am also left handed which would add another layer to the problem! Peter |
In article Hr0jh.4957$_X.4070@bigfe9,
"Peter Dohm" wrote: "Bob Noel" wrote in message ... In article , "Dan Luke" wrote: "Aluckyguess" wrote : The Cirrus needs the autopilot to fly straight and level. Baloney. well, I would need one since I'm left-handed. I know, I know, I'm in the minority here wrt side-sticks. But I really don't like side-sticks. Two things turned me off the Lancair ES: one was it was very heavy in roll, and the other was the side-stick. -- Bob Noel Looking for a sig the lawyers will hate You may be in the minority WRT side sticks, or you may not. I used to think they were the coolest idea ever, at least if mounted on the right, until I got tennis elbow a couple of times. I still haven't ever tried a side stick; but I no longer have any desire for one because I now see the value in being able to switch hands. BTW, I am also left handed which would add another layer to the problem! Peter I suspect most of the modern side-stick designs are intended to be flown on A/P most of the time. Click it on at rotation, click it off in the flare. |
A/P most of the time. Click it on at rotation, click it off in the flare. That ain't flying. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
...intended to be flown on A/P most of the time....
That ain't flying. Amen to that! Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Jay Honeck writes:
I suspect most of the modern side-stick designs are intended to be flown on A/P most of the time. Click it on at rotation, click it off in the flare. That ain't flying. It may be the closest approximation for a pilot or aircraft that can't really get by otherwise. -- Transpose mxsmanic and gmail to reach me by e-mail. |
In article Hr0jh.4957$_X.4070@bigfe9, "Peter Dohm"
wrote: I know, I know, I'm in the minority here wrt side-sticks. But I really don't like side-sticks. Two things turned me off the Lancair ES: one was it was very heavy in roll, and the other was the side-stick. I used to think they were the coolest idea ever, at least if mounted on the right, until I got tennis elbow a couple of times. I still haven't ever tried a side stick; but I no longer have any desire for one because I now see the value in being able to switch hands. BTW, I am also left handed which would add another layer to the problem! I was told that the lancair owner is left-handed, which makes the design more "interesting" -- Bob Noel Looking for a sig the lawyers will hate |
On 2006-12-22, Bob Noel wrote:
In article , "Dan Luke" wrote: "Aluckyguess" wrote : The Cirrus needs the autopilot to fly straight and level. Baloney. well, I would need one since I'm left-handed. Huh? The side stick is in your left (dominant) hand. For the very short periods of time you need to write something down, then it should stay put if properly trimmed without needing an autopilot. I've flown (as it happens in a Bonanza) quite a lot of single pilot IFR hours without an autopilot. They always stay pretty much put in the times when I'm not touching the controls to do things like re-fold charts etc. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Dylan Smith wrote: well, I would need one since I'm left-handed. Huh? The side stick is in your left (dominant) hand. For the very short periods of time you need to write something down, then it should stay put if properly trimmed without needing an autopilot. I've flown (as it happens in a Bonanza) quite a lot of single pilot IFR hours without an autopilot. They always stay pretty much put in the times when I'm not touching the controls to do things like re-fold charts etc. My cherokee 140 won't stay put well enough to my liking. Even though I have an autopilot, I prefer to be able to fly with my right hand while writing with my left. Perhaps a question is: is the SR22 stable enough in roll? -- Bob Noel Looking for a sig the lawyers will hate |
The [Cirrus] side stick is in your left (dominant) hand. For the very short
periods of time you need to write something down, then it should stay put if properly trimmed without needing an autopilot. I flew a cirrus once (about an hour's worth) and found that the pitch trim was very sensitive. It's also all-electric, so you can't tweak it by hand. So, if the air is a little bumpy, it may need more attention than usual to keep altitude manually. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Auction at teh Kalamazoo Air Zoo this Saturday 11/12/05 | .Blueskies. | Home Built | 5 | November 14th 05 01:17 AM |
Bid to buy the Beechcraft was rigged? | Montblack | Piloting | 25 | October 19th 05 06:35 PM |
Japanese firm sold Libya uranium conversion plant | Dav1936531 | Military Aviation | 2 | March 17th 04 03:47 PM |
Service Manual for Beechcraft A23 Musketeer | Robert Little | Owning | 2 | August 21st 03 06:12 AM |
Beechcraft Sundowner | VM | Owning | 4 | August 9th 03 04:05 AM |
