On Fri, 22 Dec 2006 09:10:02 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote: Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I am playing with the new Garmin 400/500W trainer and the needle movement is very smooth. I also verified the great difference between when the scaling becomes localizer-like with VTF and own-nav. I flew the LPV into KIXD Runway 36. Using VTF, I did an intercept 8 miles prior to JIKLA (the FAF). The CDI scaling was already well below 1 mile. Then I did an intercept at the same position with ANQUIM (the IF) to JIKLA as the active leg. The needle came off the peg at 1 mile crosstrack error. The 530W also has a nice feature, not present in th 530. When there is a course change at a waypoint it shows a broken magenta line, which is the flyby course that will be flown if on autopilot. Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) I have no experience with anything other than the 480, so can't comment. I also do not have a roll-steering a/p. The 480 does show a solid curved magenta line for course changes at waypoints representing the expected flight path. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Haven't flown in a long while... | Flyingmonk | Piloting | 33 | April 5th 06 06:30 AM |
Total cross country distance flown | Bill Daniels | Soaring | 9 | November 4th 05 11:53 AM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | Piloting | 1 | February 8th 05 06:45 PM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | General Aviation | 0 | February 2nd 05 04:11 AM |
Most aircraft types flown by 1 pilot? | Chad Irby | Military Aviation | 10 | January 7th 04 03:47 AM |
