#11
Doug wrote:
You ice up, can't climb and are forced to descend into unknown terrain/ceilings. Definitely DON'T do that. Given enough ice, you don't really have any other options. -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR |
On 12/22/06 15:49, Frank Stutzman wrote:
Doug wrote: You ice up, can't climb and are forced to descend into unknown terrain/ceilings. Definitely DON'T do that. Given enough ice, you don't really have any other options. I read his comment as "Don't allow yourself to get into this situation in the first place." Of course, once you're there, there's no going back ;-\ -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() -----Original Message----- From: Roy Smith ] Posted At: Friday, December 22, 2006 3:18 PM Posted To: rec.aviation.ifr Conversation: SE airplanes in clouds - near freezing level Subject: SE airplanes in clouds - near freezing level "Bob Gardner" wrote: Jim Carter's experience is telling. When a cold-soaked airframe descends into the clouds it is going to collect a lot of ice in a hurry. Where does the "quickly warmed" idea come from? The thin sheet metal skin on the plane warms up fast. It's the fuel in the tanks that hold the cold. So, obviously, the answer is to make sure you don't have any fuel left when you start your descent :-) Now there's a different approach to the problem -- can't say that I want to try it though. Very unique answer Roy. ;-} |
![]() -----Original Message----- From: Jose ] Posted At: Friday, December 22, 2006 4:22 PM Posted To: rec.aviation.ifr Conversation: SE airplanes in clouds - near freezing level Subject: SE airplanes in clouds - near freezing level The thin skin without any thermal mass beneath it apparently warmed rapidly enough to accumulate little and shed it, whereas the fuel tanks had enough thermal mass to keep the ice frozen. So, suppose the fuel tanks were insulated from the skin by about half an inch of (vented?) air... that should solve the problem, no? (albeit at a weight cost) -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. It might solve some of the problem, but in our case the upslope cumulus was pretty unstable. The visible moisture had risen well above the altitude (temp point) where it should have already turned to ice, so when we stuck our aircraft into the moisture it quickly adhered to the entire exterior. I suppose if you were descending into warmer air the ice would not accumulate anywhere except on pieces that took a while to warm up or in areas of reduced pressure. On the other hand, if you are descending into or flying through moisture that is still liquid but cooling rapidly you are going to encourage cooling with your cold airframe -- and have a souvenir to show for it. |
![]() "Jose" wrote in message . net... The thin skin without any thermal mass beneath it apparently warmed rapidly enough to accumulate little and shed it, whereas the fuel tanks had enough thermal mass to keep the ice frozen. So, suppose the fuel tanks were insulated from the skin by about half an inch of (vented?) air... that should solve the problem, no? (albeit at a weight cost) Probably. If it is indeed a problem. |
The thin skin without any thermal mass beneath it apparently warmed rapidly enough to accumulate little and shed it, whereas the fuel tanks had enough thermal mass to keep the ice frozen. So, suppose the fuel tanks were insulated from the skin by about half an inch of (vented?) air... that should solve the problem, no? (albeit at a weight cost) -- How would the vented air behave differently from the free air? Wouldn't the condensation freeze just as readily, inside the vented volume? |
![]() "Bob Gardner" wrote in message ... BTDT, in a Lear descending into Baton Rouge after a flight in the high 30 flight levels. Mucho ice on the bottoms of the wings. Thanks for that little story, Bob. You are the only person I have ever heard report the same kind of occurence. I have been accused of lying, even though it seems obvious that it will occur. |
Wouldn't the condensation freeze just as readily, inside the vented volume? Vented air would be at ambient temperature. Trapped air would probably be at equilibrium with the fuel tank. If you are descending into warmer air, it gives you an edge. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
![]() "John R. Copeland" wrote in message ... "Jose" wrote in message . net... The thin skin without any thermal mass beneath it apparently warmed rapidly enough to accumulate little and shed it, whereas the fuel tanks had enough thermal mass to keep the ice frozen. So, suppose the fuel tanks were insulated from the skin by about half an inch of (vented?) air... that should solve the problem, no? (albeit at a weight cost) -- How would the vented air behave differently from the free air? Wouldn't the condensation freeze just as readily, inside the vented volume? Vented air would probably add ice inside the wing, but would not disturb the aerodynamics. |
"Stan Prevost" wrote in message ...
"Bob Gardner" wrote in message ... BTDT, in a Lear descending into Baton Rouge after a flight in the high 30 flight levels. Mucho ice on the bottoms of the wings. Thanks for that little story, Bob. You are the only person I have ever heard report the same kind of occurence. I have been accused of lying, even though it seems obvious that it will occur. We pilots of Cessna tip-tank twins would support you too, Stan. On ground after a high flight, the fuel level in the tip tanks is clearly evident. Usually it's only condensation, but sometimes it can be clear ice. |
C-152 Breaks Up In Air | Mortimer Schnerd, RN | Piloting | 23 | September 7th 06 10:00 AM |
Yesterday's IFR flight with questions | A Lieberman | Instrument Flight Rules | 30 | November 23rd 05 10:31 PM |
Pentrating Towering Cumulus Clouds | O. Sami Saydjari | Instrument Flight Rules | 49 | May 11th 05 04:45 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
