Roy Smith wrote:
I also know that all the planes we have will get off the ground just fine a little over-gross. I have far less confidence in their ability to make it to the runway with the tanks a little under-empty. Too true. My personal rule is at the point where I'm starting to worry about fuel, I don't have enough. All the pontification I've been reading from the purists with the totalizers is getting to be a bit much for me. I've never flown an aircraft with a totalizer and somehow have survived the experience. And as far as the trip that started this whole thread goes, I don't see what everybody is whining about. To me, it sounded like a typical trip in a new (to him) aircraft. Stuff like the transponder failure are par for the course. Apparently flying a whole fleet of crappy aircraft has made me somewhat more forgiving in that regard, I suppose. I *expect* things not to all work at the same time. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote:
All the pontification I've been reading from the purists with the totalizers is getting to be a bit much for me. I've never flown an aircraft with a totalizer and somehow have survived the experience. Most of my club's planes now have totalizers. At first, I thought they would be a great tool for more precise fuel management. Over time, however, I've come to realize that, like many other things, they're not as magical as you might think. If they are correctly calibrated, they can be amazingly accurate. The problem is, in a fleet like mine, you can never really know if they're calibrated or not. Each unit has a "k factor" which must be determined and programmed into the unit. If the k factor is wrong, what you've got is a very precise random number generator. You can reset the k factor with some combination of button presses, and you never know which of the N pilots who flew the plane before you have finger-****ed the unit sufficiently to reset the calibration. The units have the potential to be a very valuable addition to the panel. If properly interfaced with your GPS, you can get information like "how many minutes of fuel will I have left when I reach my destination?" Of course, that assumes that your current fuel burn rate will remain constant for the rest of the flight, and the winds won't change, and you won't get rerouted, etc. And that the k-factor is set right. And that you've mastered the totally inscrutable user interface sufficiently to have set the starting fuel quantity correctly. |
![]() Mortimer Schnerd, RN wrote: Too true. My personal rule is at the point where I'm starting to worry about fuel, I don't have enough. All the pontification I've been reading from the purists with the totalizers is getting to be a bit much for me. I've never flown an aircraft with a totalizer and somehow have survived the experience. I don't have a fuel totalizer. However I won't hesitate to plan a flight with 30 minute fuel reserve if all the conditions I mentioned in my previous post are met. Fuel reserve has more to do with weather, alternate runways, enroute progress check than an arbitrary number of minute in fuel reserve. One can easily name a situation when even an hour of fuel reserve isn't safe (say flying a limited range aircraft to a wide spread IFR area). |
M wrote:
I don't have a fuel totalizer. However I won't hesitate to plan a flight with 30 minute fuel reserve if all the conditions I mentioned in my previous post are met. Fuel reserve has more to do with weather, alternate runways, enroute progress check than an arbitrary number of minute in fuel reserve. One can easily name a situation when even an hour of fuel reserve isn't safe (say flying a limited range aircraft to a wide spread IFR area). Not me, Buddy. I once ran a C-210 out of gas at the end of a 45 minute flight that started with 1.5 hour's fuel (figured from elapsed time). Beautiful VFR weather coming back from Freeport, Bahamas into Ft. Pierce, FL. Ended up with one wing hanging over the edge of the tarmac at Ft. Pierce... another 30 second's fuel and I'd have been fine. As it was, it only injured my pride and my wallet a bit. No violation from the feds at least.... They teach you not to believe the fuel gauges; to go by elapsed time instead. Well, I did, and it bit me on the ass. So now I leave with full tanks and take elapsed time with a grain of salt. And once I start worrying about fuel, I stop and get some because I don't have enough. As a result, I never really worry about fuel anymore except in the planning phase of the flight. 30 minutes? Sheeeeiiitttt. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote: Not me, Buddy. I once ran a C-210 out of gas at the end of a 45 minute flight that started with 1.5 hour's fuel (figured from elapsed time). So, what went wrong? |
Roy Smith wrote:
In article , "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote: Not me, Buddy. I once ran a C-210 out of gas at the end of a 45 minute flight that started with 1.5 hour's fuel (figured from elapsed time). So, what went wrong? Never really found out. Personally, I think fuel was stolen at Freeport. I took off early in the morning; I couldn't buy fuel or find a ladder to climb up and physically look in the fuel tanks. For me to run out when I actually did, mathmatics would suggest I burned over 22 gallons an hour. That just wasn't possible. I had averaged maybe 15 gallons block to block on earlier trips. 65% power at my selected altitude should have yielded about 13.5 gallons per hour at cruise. Anyway, I freely admit I screwed the pooch on many different planes, pardon the pun. Be that as it may, and after much grumbling from the FAA, they finally decided to do nothing. No violation, no civil penalty, not even a nasty letter. It just went away. However, I have adjusted my practices quite a bit in the years that followed. And of course, my personal rule about worrying about fuel means I don't have enough came out of that. As an aside: my father, a former USAF command pilot, ran out of gas while driving near his home a couple of weeks later. Some wag down there asked if he'd taught me how to fly. G -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
![]() Ok, I have to admit, for me to plan a flight with 30 minute fuel reserve, I have to start with full tanks. Otherwise there're just too many variables to do it safely. Mortimer Schnerd, RN wrote: Never really found out. Personally, I think fuel was stolen at Freeport. |
![]() I contend a better way to set power is needed in fixed pitch A/C. We had a manifold pressure gage in our 172. Others thought it was guilding a lily, but fuel consumption could be predicted within maybe 4 percent. A tachometer is so variable w altitude. |
M wrote:
Ok, I have to admit, for me to plan a flight with 30 minute fuel reserve, I have to start with full tanks. Otherwise there're just too many variables to do it safely. Even with full tanks, there are too many variables to really fly down to 30 minutes left. Just being a little off level when you fill your tanks can make enough difference to make 30 minutes dicey in a plane that burns less than 6 gallons in 30 minutes. That isn't much margin. Matt |
![]() I guess I'm getting better... I just got back from a trip from KSAV (Savannah, GA) to KLIT (Little Rock, AR) and back. I bought fuel three times and never took more than 40 gallons to top it off. I got the transponder fixed before the trip... So I think we did a pretty safe and sane trip with no squaks and didn't stretch our luck... Sure is nice coming back east and getting 130 kts ground speed !!! I've really enjoyed all the discussion on this thread. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
