2-Batteries
Old January 2nd 07, 12:28 AM posted to rec.aviation.soaring
ContestID67
Default 2-Batteries
I wish it were so. While most loggers can handle a momentary power
loss, not all can. I spoke at the last convention on this and related
avionics wiring issues. I contacted each manufacturer and as of Feb,
2006, I compiled the information below. I need to add the EW
MicroRecorder. I will be speaking on Saturday at the Memphis
convention if you are interested in more details.
2:00PM 3:00PM John DeRosa
Understanding Soaring Recorders and Computers
Convention Center Ballroom C
3:15PM 4:15PM John DeRosa
Aviation Electrical And Electronic Wiring Basics
- John DeRosa "67R"
Cambridge
During a power Interruption, will IGC file be maintained?: Yes
How long of a power interruption can be survived?: 2 hours with aux
battery, otherwise no response
Start new log file?: 5 mins before starting new log file
Require secondary power source?: CAA-117 auxillary battery
Other information maintained?: Yes
Minimum operational voltage?: 8vdc is guaranteed but 6vdc is possible
Garrecht Volkslogger
During a power Interruption, will IGC file be maintained?: No, new file
How long of a power interruption can be survived?: 0.1 sec
Start new log file?: Yes
Require secondary power source?: Yes
Minimum operational voltage?: 7vdc
LX Navigation
How long of a power interruption can be survived?: Approximately 1 min
Start new log file?: 1 min before starting new log file.
Require secondary power source?: No
New Techologies
How long of a power interruption can be survived?: few seconds
Minimum operational voltage?: 8.9vdc
Borgelt
How long of a power interruption can be survived?: hours to weeks
Start new log file?: no response
Require secondary power source?: Internal "super" capacitor
Minimum operational voltage?: 10.0vdc
Eric Greenwell wrote:
I thought all loggers just started again after a momentary power loss,
and continued the same flight file. It sounds like yours isn't behaving
properly, or are some brands a bit touchy?
Old January 2nd 07, 04:00 PM posted to rec.aviation.soaring
5Z
Default 2-Batteries
I have heard stories that the Volkslogger will also create a new
declaration on power up. That is, it sets the timestamp of the
declaration that is currently stored to be the time of power on. Any
idea this happens? Though, since one is already splicing together two
logs, the declaration of the previous log should be good enough.
The CAI 302, on the other hand, will not update the declaration (with
the timestamp of when it was made) until it starts a new log. This is
after about 5 minutes of "inactivity". I sent a concern to CAI a while
ago about this, as there could be a situation where a pilot will decide
to make a new declaration during a quick relight. If no OO is
available to do a paper declaration, then only the electronic one can
be used - and it's possible it won't take. (Consider a self-launcher
at an unattended airport).
....No matter how had one thinks during the design, the application will
always be different...
-Tom
Electric maned airplane Flyingmonk Piloting 26 July 20th 06 05:43 AM
Electric maned airplane Flyingmonk Home Built 26 July 20th 06 05:43 AM
Becker AR-3201 radio owners: check your batteries sssarah Soaring 3 May 24th 06 07:40 AM
Switching Batteries Advice? ContestID67 Soaring 17 January 12th 06 01:02 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
