![]() Roy Smith wrote: In article , Jose wrote: Let's say the airport is using 34, and you're cleared by approach control for the ILS-16 circle to 34 in VFR conditions as a practice approach. It would be a very poor idea indeed for you to execute the circling maneuver, do a low approach, then decide to execute the published missed on your own. This would have you swimming upstream against the traffic on final for 34. Well, the way we are supposed to execute a missed approach is turn towards the airport environment and then fly the procedure as published unless otherwise told by ATC. So, if shooting the ILS-16 CTL 34 the Pilot would fly the published MAP for the ILS-16 approach. If he looses visual reference with the runway on downwind 34 he sould make an initial climbing (90º) turn towards the runway (not necessary if already on base) and then once he estimates he is over the runway, he should execute the MAP as published unless otherwise told or vectored by ATC. While I'm here I have an interesting one for you: You are on the LOC rwy 16 approach and (because you reached the MDA close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I was told by a Pilot Controller Journalist that although maybe not safe, he could not see any reason why it wouldn't be perfectly legal. Can you discuss the uncontrolled and controlled field issues associated with this ? Your points of view are welcome. Thanks |
In general you are not supposed to turn a botched ILS into a circle to
land. Go missed and come in again. |
Hi Doug and Merry Christmas
The question was geared towards non precsion approaches such as LOC, VOR NDB. Doug wrote: In general you are not supposed to turn a botched ILS into a circle to land. Go missed and come in again. |
![]() -----Original Message----- From: Doug ] Posted At: Tuesday, December 26, 2006 8:47 AM Posted To: rec.aviation.ifr Conversation: Cleared for the ILS 16 or circle to land 34 question? Subject: Cleared for the ILS 16 or circle to land 34 question? In general you are not supposed to turn a botched ILS into a circle to land. Go missed and come in again. The question was about a LOC 16, not the ILS so the minimums would have been higher. Also, the question was about legality not good operating sense. ;-) Since you are cleared for the approach, the airspace is yours until you land, miss, or land harder. Assuming the MDA is at least 600' in a light aircraft I'd probably be inclined to execute the 360 overhead - after all, the old pattern altitudes used to be 800' and the 600' would keep me above obstructions in the immediate vicinity. Here's another good reason for not shooting LOCs into short fields. |
close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I would say yes, so long as you are above the circle-to-land minima. Remember, they are usually higher than a straight-in. I presume you were expecting to land straight in and thus descended to the straight-in MDA. Now, suppose you did that... would it be legal to climb to the circle MDA and circle all the way around? I don't see why not, so long as you remain visual. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Jose wrote:
You are on the LOC rwy 16 approach and (because you reached the MDA close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I would say yes, so long as you are above the circle-to-land minima. Remember, they are usually higher than a straight-in. I presume you were expecting to land straight in and thus descended to the straight-in MDA. Now, suppose you did that... would it be legal to climb to the circle MDA and circle all the way around? I don't see why not, so long as you remain visual. Jose If you have the required flight visibility required for circle-to-land what you suggest would be legal and (assuming a good skill level) possibly preferable to doing the miss and starting all over again. |
On 12/26/06 07:46, Jose wrote:
You are on the LOC rwy 16 approach and (because you reached the MDA close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I would say yes, so long as you are above the circle-to-land minima. Remember, they are usually higher than a straight-in. I presume you were expecting to land straight in and thus descended to the straight-in MDA. Now, suppose you did that... would it be legal to climb to the circle MDA and circle all the way around? I don't see why not, so long as you remain visual. The regs say that if you're below the minimum, you must execute a missed approach. If you're below the circling minima when you decide to execute the circle maneuver, then you must execute the missed approach. Now, if you say you climbed back up to circling minima and *then* decided to execute the circling maneuver, you'd be lying and it would be obvious. If the winds really did preclude a landing on 34, shouldn't you have known that before flying the ILS to minimums? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
On 12/26/06 07:46, Jose wrote: You are on the LOC rwy 16 approach and (because you reached the MDA close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I would say yes, so long as you are above the circle-to-land minima. Remember, they are usually higher than a straight-in. I presume you were expecting to land straight in and thus descended to the straight-in MDA. Now, suppose you did that... would it be legal to climb to the circle MDA and circle all the way around? I don't see why not, so long as you remain visual. The regs say that if you're below the minimum, you must execute a missed approach. If you're below the circling minima when you decide to execute the circle maneuver, then you must execute the missed approach. Now, if you say you climbed back up to circling minima and *then* decided to execute the circling maneuver, you'd be lying and it would be obvious. If the winds really did preclude a landing on 34, shouldn't you have known that before flying the ILS to minimums? The regulation is written for flight conditions less than minimums. Like I said, if he had the flight visibility for circling he would be quite legal in doing what he proposed. And, the gears were shifted to an NPA for the question. |
Jose and Mark
I forgot to mention that I assumed that either circling minimums were equal to staright-in LOC minimums or for whatever reason, the aircraft did not descend below circling minimums at any time. Mark The Pilot in this example was not shooting the ILS 34 but the LOC-16. He finds himself seeing the runway to high to land on 16. Hope this clarifies the situation. I once did a CTL at the end of a VOR app on a very convective rainy night. I made the runway but the Lear behind couldn't and missed. Should I have been in the previously described situation I would have rather done the 360 circling than going back into that s..t again. Mark Hansen wrote: On 12/26/06 07:46, Jose wrote: You are on the LOC rwy 16 approach and (because you reached the MDA close to the MAP) you are in a position in which you are to too high to make a safe landing. Wind precludes landing on rwy 34. Is it legal to circle to land all the way round to rwy 16 provided you remain in the CTL protected area? I would say yes, so long as you are above the circle-to-land minima. Remember, they are usually higher than a straight-in. I presume you were expecting to land straight in and thus descended to the straight-in MDA. Now, suppose you did that... would it be legal to climb to the circle MDA and circle all the way around? I don't see why not, so long as you remain visual. The regs say that if you're below the minimum, you must execute a missed approach. If you're below the circling minima when you decide to execute the circle maneuver, then you must execute the missed approach. Now, if you say you climbed back up to circling minima and *then* decided to execute the circling maneuver, you'd be lying and it would be obvious. If the winds really did preclude a landing on 34, shouldn't you have known that before flying the ILS to minimums? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
fcoav8r wrote:
Jose and Mark I forgot to mention that I assumed that either circling minimums were equal to staright-in LOC minimums or for whatever reason, the aircraft did not descend below circling minimums at any time. Mark The Pilot in this example was not shooting the ILS 34 but the LOC-16. He finds himself seeing the runway to high to land on 16. Hope this clarifies the situation. And, if he has the required flight visibility for circle-to-land minimums, and has not yet reached the MAP, he can climb tp the circle-to-land MDA, then cirle to land, provided he still has the require flight visibility and has sight of the airport. |
Circle to land question | A Lieberman | Instrument Flight Rules | 33 | May 24th 05 04:22 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
One more question regarding great circle and two intersecting course. | Sims | Piloting | 7 | October 9th 03 07:25 PM |
Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 06:13 PM |
NACO charts - why have a reference circle? | Bob Gardner | Instrument Flight Rules | 5 | September 6th 03 01:15 PM |
