![]() HL Falbaum wrote: "Eric Greenwell" wrote in message news:sWkkh.7731$6Z5.1910@trndny01... KM wrote: Is there any documentation for carnuba's UV and moisture protection on gel coat? There could be but I dont know for sure Eric.I probably should not have posted that Carnuba works best for UV.I should have posted that Carnuba works very well.Another thing that I should have posted is that the natural ingredients in Carnuba work to moisturize your finish much in the same way that lotion moisturizes your skin.This aids tremendously in the longevity of your finsh. Ultimatly, any care is better that nothing so some people will use these easy to apply or "one step" products like those used on cars.Alot of these will have some pretty harsh chemicals that will not be good for your finsh over the course of time.You will want to avoid anything with petrolium distilates in it (Which includes most of your car care stuff).Have you ever wondered why a profesional detailer will wax a car using a 3 step process?I would be very leary of any product that claims to be able to seal and protect your finish in one easy step (Like Nufinish). -- Eric Greenwell - Washington State, USA Might be biased ( ;-) ) , but check the WxBlock website----I thinhk they published a comparison betw WxBlock and Carnuba a few years ago. Wx Block did much better. Many of the newer products have UV blockers added in. Hartley, something to consider here is that these companies will sponsor several "Scientific Tests" but they only publish the one (Usually out of several) that casts their product in a favorable light. Hartley Falbaum Happy Holidays K Urban |
KM wrote:
Another thing that I should have posted is that the natural ingredients in Carnuba work to moisturize your finish much in the same way that lotion moisturizes your skin.This aids tremendously in the longevity of your finsh. I sincerely hope it does not trap any moisture at all in the way skin lotion does. Water is one of the mortal enemies of gel coat damage, the others being UV light and flexing in very low temperatures. Any good car polish will protect against water and UV. I'd suggest using Mer, mainly because it's so easy to apply you'll use it often. Even the best wax in the world is useless if it's long worn off. Dan |
![]() Dan G wrote: I sincerely hope it does not trap any moisture at all in the way skin lotion does. Water is one of the mortal enemies of gel coat damage, the others being UV light and flexing in very low temperatures. Wax does not "trap" moisture.Most waxes are designed to go on a dry surface (unlike Mer).You are correct that most gel coats are water soluble but only if saturated over long periods of time (like with a leaking trailer).This does NOT mean that you shouldnt protect your finish from oxidation by waxing it. Any good car polish will protect against water and UV. I'd suggest using Mer, mainly because it's so easy to apply you'll use it often. Huge misconception here Dan! You should NEVER polish a gelcoated or painted finsh without also waxing it.If you think about it, the main reason to polish and wax anything is for protection and not just appearance.By just polishing your finish you are leaving it exposed to oxidation and UV.Go back and read the post about using a one step product. Here is another way to look at it; the main reason a finish exists on a sailplane is to protect the structure from harmfull stuff like water and UV.So it stands to reason that the better you take care of a finsh, the longer your sailplane will last. Dan K Urban |
KM wrote:
Dan G wrote: I sincerely hope it does not trap any moisture at all in the way skin lotion does. Water is one of the mortal enemies of gel coat damage, the others being UV light and flexing in very low temperatures. Wax does not "trap" moisture.Most waxes are designed to go on a dry surface (unlike Mer). Mer can be used wet or dry. You are correct that most gel coats are water soluble but only if saturated over long periods of time (like with a leaking trailer).This does NOT mean that you shouldnt protect your finish from oxidation by waxing it. AFAIK gelcoat isn't water soluble, but it IS porous. If you allow water to get into the structure of the coating, it can result in freeze/thaw damage in low temps, and provides a solution for chemical attack. Any good car polish will protect against water and UV. I'd suggest using Mer, mainly because it's so easy to apply you'll use it often. Huge misconception here Dan! You should NEVER polish a gelcoated or painted finsh without also waxing it.If you think about it, the main reason to polish and wax anything is for protection and not just appearance.By just polishing your finish you are leaving it exposed to oxidation and UV.Go back and read the post about using a one step product. People get rather pedantic about the terms wax and polish; I'm quite lazy and tend to use them interchangeably. To be clear, Mer has a (very) light abrasive action, just enough to remove the oxidised and dirt-contaminated top layer (on the microscopic scale). Usually that layer is old polish, but if the surface has been neglected then it will be the top layer of the gelcoat/paint/whatever, which is likely in such bad state you'll want rid of the top surface anyway. Don't worry, it's impossible to take off so much that you'll rub through the gelcoat or even alter the profile of the wing. The Mer then leaves a protective layer (i.e. water proof and UV resisting) on the surface. Here is another way to look at it; the main reason a finish exists on a sailplane is to protect the structure from harmfull stuff like water and UV.So it stands to reason that the better you take care of a finsh, the longer your sailplane will last. Yes. Dan |
![]() Dan G wrote: AFAIK gelcoat isn't water soluble, but it IS porous. If you allow water to get into the structure of the coating, it can result in freeze/thaw damage in low temps, and provides a solution for chemical attack. With most of the gel coats in use on sailplanes there isnt going to be enough moisture "traped" by wax to cause any kind of "chemical attack".My point was that if you dont wax because of a fear of this you are probably incuring bigger concerns that just moisture. People get rather pedantic about the terms wax and polish; I'm quite lazy and tend to use them interchangeably. Dan, you are not alone here, I think as a verb everyone does this.As a noun, these are completely separate products with totally different uses. To be clear, Mer has a (very) light abrasive action, Dan, many products work like this.Abrasives in wax have their pro's and con's, mostly cons unfortunatly.I looked on the Mer website after I read your post.Have you noticed this stuff isnt clear coat safe?Did you also notice that they dont recomend its use on aircraft?I have emailed them about this and they havent gotten back to me yet but I already know the answer why. Dan, there are alot of misconceptions out there about car care products.I think some of this is due to the fact that modern finishes (And gel coat for that matter) need different care than the car paints in use 20 years ago.People want to do things the way they always have.Old habits die hard I guess. Dan K Urban |
don't use the UV blocking claims of many products too seriously......many
products (even clear glass!) block some UV.typically UVA, UVB but few offer real UV protection beyond that UVC is another more harmful source of serious damage and few if any of the advertised products offer a substantial source to block this range (Wx/Block and Wx/Seal does). Looking at the way Wx/Block actually does this (well beyond my knowledge of chemistry) is by actually in layman's terms is by sacrificing of itself hence repeated applications are needed to keep this high level of UV inhibitor active and this is why we suggest repeated applications and annual/semi-annual rewaxing with Wx/Block depending on the UV exposure.......and yes it also has a very high moisture barrier included. Bob Lacovara, the designer of Wx/Block has extensive knowledge in the areas of Gelcoat and other finishes and has given very informational talks on the subject in previous SSA conventions. tim Please visit the Wings & Wheels website at: www.wingsandwheels.com "KM" wrote in message ups.com... Dan G wrote: I sincerely hope it does not trap any moisture at all in the way skin lotion does. Water is one of the mortal enemies of gel coat damage, the others being UV light and flexing in very low temperatures. Wax does not "trap" moisture.Most waxes are designed to go on a dry surface (unlike Mer).You are correct that most gel coats are water soluble but only if saturated over long periods of time (like with a leaking trailer).This does NOT mean that you shouldnt protect your finish from oxidation by waxing it. Any good car polish will protect against water and UV. I'd suggest using Mer, mainly because it's so easy to apply you'll use it often. Huge misconception here Dan! You should NEVER polish a gelcoated or painted finsh without also waxing it.If you think about it, the main reason to polish and wax anything is for protection and not just appearance.By just polishing your finish you are leaving it exposed to oxidation and UV.Go back and read the post about using a one step product. Here is another way to look at it; the main reason a finish exists on a sailplane is to protect the structure from harmfull stuff like water and UV.So it stands to reason that the better you take care of a finsh, the longer your sailplane will last. Dan K Urban |
![]() Tim Mara wrote: don't use the UV blocking claims of many products too seriously......many products (even clear glass!) block some UV.typically UVA, UVB but few offer real UV protection beyond that UVC is another more harmful source of serious damage and few if any of the advertised products offer a substantial source to block this range (Wx/Block and Wx/Seal does). Amen to your comment about UV claims Tim.Unfortunatly Lacovara also makes some pie in the sky claims his product doesnt back up.We tried WX Block on our fleet and it just didnt work that well.To add to this, the stuff is obscenely expensive when compared to the stuff that the gel coat manufacturers recomend. Looking at the way Wx/Block actually does this (well beyond my knowledge of chemistry) is by actually in layman's terms is by sacrificing of itself hence repeated applications are needed to keep this high level of UV inhibitor active and this is why we suggest repeated applications and annual/semi-annual rewaxing with Wx/Block depending on the UV exposure.......and yes it also has a very high moisture barrier included. Tim, pretty much all of the waxes work like this.They start to oxidate the minute you finish a wax job. Happy Holidays, K Urban |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Teflon gap seal tape... | Marc Ramsey | Soaring | 10 | April 3rd 05 04:35 PM |
sump drain cleaning | Mike Noel | Owning | 15 | August 15th 03 02:41 AM |
