Years ago Air Progress magazine had a picture of an F-15 in
Germany that did the same thing, except it was about 6 inches into the ground. The top side appeared undamaged but there must have been a ton of dirt in the engines. "Dudley Henriques" wrote in message ... |I don't think he "saved it" really. He just bottomed out too low and the | mush gave him just enough room to clear. | He would have known instinctively how much back pressure he had left and | couldn't have gone past that anyway. | Once you have all the g in there that the airplane's recovery profile can | give you, you're totally committed to the recovery line that amount of g | provides. Feed in more and you're topping off the CL curve and you're done | for when that happens. If anything, he had all the stick in there the line | was giving him and just sweated out the exit . | Ground effect won't save you going through a bad recovery line. The impetus | will take you right through it into ground contact. He maxed out the line | and went tail low with just enough air under him to clear the prop tips. Had | he caught the tips with that much power on the airplane, the vibration would | have probably torn him apart through the exit. | I think I know who it was. This guy is a very good warbird pilot. He just | blew the line on this one and got away with it. | He's an even better warbird pilot now :-)) | Dudley Henriques | | | "Ben Jackson" wrote in message | ... | On 2006-12-28, Dudley Henriques wrote: | As an aside, if anyone is even remotely interested in the technical | aspects | involved in low altitude vertical recoveries like this one when being | flown | | I'm curious to know if he actually saved it because of the extra lift | of ground effect right at the bottom, or if he really hit the ground. | Since he executed a victory roll afterwards I figured he was not worried | about the plane coming apart... | | -- | Ben Jackson AD7GD | | http://www.ben.com/ | | |
Some guys just live right! :-))
DH "Jim Macklin" wrote in message ... Years ago Air Progress magazine had a picture of an F-15 in Germany that did the same thing, except it was about 6 inches into the ground. The top side appeared undamaged but there must have been a ton of dirt in the engines. "Dudley Henriques" wrote in message ... |I don't think he "saved it" really. He just bottomed out too low and the | mush gave him just enough room to clear. | He would have known instinctively how much back pressure he had left and | couldn't have gone past that anyway. | Once you have all the g in there that the airplane's recovery profile can | give you, you're totally committed to the recovery line that amount of g | provides. Feed in more and you're topping off the CL curve and you're done | for when that happens. If anything, he had all the stick in there the line | was giving him and just sweated out the exit . | Ground effect won't save you going through a bad recovery line. The impetus | will take you right through it into ground contact. He maxed out the line | and went tail low with just enough air under him to clear the prop tips. Had | he caught the tips with that much power on the airplane, the vibration would | have probably torn him apart through the exit. | I think I know who it was. This guy is a very good warbird pilot. He just | blew the line on this one and got away with it. | He's an even better warbird pilot now :-)) | Dudley Henriques | | | "Ben Jackson" wrote in message | ... | On 2006-12-28, Dudley Henriques wrote: | As an aside, if anyone is even remotely interested in the technical | aspects | involved in low altitude vertical recoveries like this one when being | flown | | I'm curious to know if he actually saved it because of the extra lift | of ground effect right at the bottom, or if he really hit the ground. | Since he executed a victory roll afterwards I figured he was not worried | about the plane coming apart... | | -- | Ben Jackson AD7GD | | http://www.ben.com/ | | |
