![]() 5Z wrote: On Dec 27, 8:34 pm, Bob Caldwell Also any other XPDR equipped pilots here in the Rocky Mountain area please weigh in on the subject. You may want to get a month's worth of OLC flight logs and plot them all together to show where we fly and why it would be beneficial for them to see us. -Tom Good suggestions all. Right now Phil Ecklund is point person on this. Like to keep it that way unless he defers to someone else. A quick search of the RAS postings WRT Reno over the years seems to indicate that 0440 is only applicable within 25 miles of Reno, or has it been extended in cooperation with Oakland ARTCC? Someone comment on the boundaries? Very best regards, Frank Whiteley |
Frank Whiteley wrote:
5Z wrote: On Dec 27, 8:34 pm, Bob Caldwell Also any other XPDR equipped pilots here in the Rocky Mountain area please weigh in on the subject. You may want to get a month's worth of OLC flight logs and plot them all together to show where we fly and why it would be beneficial for them to see us. -Tom Good suggestions all. Right now Phil Ecklund is point person on this. Like to keep it that way unless he defers to someone else. A quick search of the RAS postings WRT Reno over the years seems to indicate that 0440 is only applicable within 25 miles of Reno, or has it been extended in cooperation with Oakland ARTCC? Someone comment on the boundaries? That poses an interesting problem. I cannot change transponder codes in flight in my ship. So when it's based at Truckee, Air Sailing, or Minden I set it on the ground to 0440 and don't change it back to 1200 until I bring it "home" to Hollister. If I fly a significant distance from the Reno area (which I get a little better at each season), does that cause a problem? In a sense, 0440 is my "assigned" code, though not explicitly assigned (and not discretely to me). But what if I'm 300 miles away? If an authority doesn't try to assign a new one to me (I'd have to say "unable" if they did), is that legit? Hmm. Personally, I'd rather have the transponder powered on and using a reasonable code than powered off because I left the Reno area and couldn't change it in flight. Jeremy Jeremy |
Jeremy Zawodny wrote:
I cannot change transponder codes in flight in my ship. So when it's based at Truckee, Air Sailing, or Minden I set it on the ground to 0440 and don't change it back to 1200 until I bring it "home" to Hollister. I've got to know: why can't you change codes in the air? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
I am guessing that he mounted it where he cannot reach it
BT "Eric Greenwell" wrote in message news ![]() Jeremy Zawodny wrote: I cannot change transponder codes in flight in my ship. So when it's based at Truckee, Air Sailing, or Minden I set it on the ground to 0440 and don't change it back to 1200 until I bring it "home" to Hollister. I've got to know: why can't you change codes in the air? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric Greenwell wrote:
Jeremy Zawodny wrote: I cannot change transponder codes in flight in my ship. So when it's based at Truckee, Air Sailing, or Minden I set it on the ground to 0440 and don't change it back to 1200 until I bring it "home" to Hollister. I've got to know: why can't you change codes in the air? Because there's no room in the panel to expose the transponder controls. The transponder lives behind the panel of my 304C, so I can change the code only by removing the canopy. My 304C has the instrument panel designed for taller pilots, with deeper leg cutouts and less room for instruments. Here's a shot: http://flickr.com/photos/jzawodn/34233620/ It was either that or *not* install a transponder at all. Since I fly most of the summer in the Reno area, I opted for having one. Well, that's not entirely true. I could have spent hundreds of dollars to re-instrument my panel the way I'd really like, but I'm not ready to go quite that far yet. But, hey, I do have an ident button. :-) Jeremy |
Eric Greenwell wrote: I've got to know: why can't you change codes in the air? Because there's no room in the panel to expose the transponder controls. The transponder lives behind the panel of my 304C, so I can change the code only by removing the canopy. My 304C has the instrument panel designed for taller pilots, with deeper leg cutouts and less room for instruments. Here's a shot: http://flickr.com/photos/jzawodn/34233620/ It was either that or *not* install a transponder at all. Since I fly most of the summer in the Reno area, I opted for having one. Well, that's not entirely true. I could have spent hundreds of dollars to re-instrument my panel the way I'd really like, but I'm not ready to go quite that far yet. Yeah, you have plenty of space for another instrument, but it has to be gathered up into one corner. You've probably thought of this: if it's a Becker, you just need some way of pushing the VFR1 (set for 1200) and VFR2 (set for 0440) buttons remotely to allow switching. A plastic model airplane pushrod might do the job. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Jeremy Zawodny wrote: Eric Greenwell wrote: I've got to know: why can't you change codes in the air? Because there's no room in the panel to expose the transponder controls. The transponder lives behind the panel of my 304C, so I can change the code only by removing the canopy. My 304C has the instrument panel designed for taller pilots, with deeper leg cutouts and less room for instruments. Here's a shot: http://flickr.com/photos/jzawodn/34233620/ It was either that or *not* install a transponder at all. Since I fly most of the summer in the Reno area, I opted for having one. Well, that's not entirely true. I could have spent hundreds of dollars to re-instrument my panel the way I'd really like, but I'm not ready to go quite that far yet. Yeah, you have plenty of space for another instrument, but it has to be gathered up into one corner. Right. It can be done, but not without a lot of moving things around, cutting, and so on. I figure that in a few more years I'll convince myself that it's worth it. But so far I haven't. I've toyed with the idea of removing the LX-5000 (freeing up two large holes) and dropping in a B400 and using the empty hole for a small transponder. I use a PDA and backup handheld GPS anyway, to the LX-5000 is really overkill. I mainly use it only as a logger and vario. Others have tried to convince me that a 302 is the way to go. In any case, it's money I'm not sure I need to spend at this point. You've probably thought of this: if it's a Becker, you just need some way of pushing the VFR1 (set for 1200) and VFR2 (set for 0440) buttons remotely to allow switching. A plastic model airplane pushrod might do the job. Actually, it's a Garmin GTX 320 that I got one heck of a deal on. It's not the most power efficient thing for a glider, but I've got dual 12aH batteries on board... Jeremy |
How to get maximum height on a winch launch? | Dan G | Soaring | 38 | December 22nd 16 12:29 AM |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Has a glider ever been found using the transponder radar track? | Eric Greenwell | Soaring | 14 | February 3rd 05 02:41 PM |
More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 06:37 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
