![]() Dan G wrote: AFAIK gelcoat isn't water soluble, but it IS porous. If you allow water to get into the structure of the coating, it can result in freeze/thaw damage in low temps, and provides a solution for chemical attack. With most of the gel coats in use on sailplanes there isnt going to be enough moisture "traped" by wax to cause any kind of "chemical attack".My point was that if you dont wax because of a fear of this you are probably incuring bigger concerns that just moisture. People get rather pedantic about the terms wax and polish; I'm quite lazy and tend to use them interchangeably. Dan, you are not alone here, I think as a verb everyone does this.As a noun, these are completely separate products with totally different uses. To be clear, Mer has a (very) light abrasive action, Dan, many products work like this.Abrasives in wax have their pro's and con's, mostly cons unfortunatly.I looked on the Mer website after I read your post.Have you noticed this stuff isnt clear coat safe?Did you also notice that they dont recomend its use on aircraft?I have emailed them about this and they havent gotten back to me yet but I already know the answer why. Dan, there are alot of misconceptions out there about car care products.I think some of this is due to the fact that modern finishes (And gel coat for that matter) need different care than the car paints in use 20 years ago.People want to do things the way they always have.Old habits die hard I guess. Dan K Urban |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Teflon gap seal tape... | Marc Ramsey | Soaring | 10 | April 3rd 05 04:35 PM |
sump drain cleaning | Mike Noel | Owning | 15 | August 15th 03 02:41 AM |
