It really is hard to believe that a mistranslation will eventually ground 50
gliders. I think more pressure on the FAA is also needed too. Maybe wishful thinking, but we owners should try *anything* to protect our investment, including a new translation. Doug "Ian" wrote in message ups.com... wrote: According to the FAA, there are approximately 50 Centrair Pegase 101 gliders in the US. I don't know how effective we are as a group, but letters to Centrair and emails couldn't do to much harm. If the problem is - have I read this right - that a mistranslation turned a 3,000 hour inspection into a 3,000 hour life, why don't the 50 of you club together, pay for another professional translation, then ask Centrair simply to inform the FAA by AD that the documentation has been upgraded? Minimum work on their part, and probably won't cost each of you that much. Sudden thought. What does the UK documentation for the Pegasus say? Ian |
![]() Doug wrote: It really is hard to believe that a mistranslation will eventually ground 50 gliders. I think more pressure on the FAA is also needed too. Maybe wishful thinking, but we owners should try *anything* to protect our investment, including a new translation. Doug "Ian" wrote in message ups.com... wrote: According to the FAA, there are approximately 50 Centrair Pegase 101 gliders in the US. I don't know how effective we are as a group, but letters to Centrair and emails couldn't do to much harm. If the problem is - have I read this right - that a mistranslation turned a 3,000 hour inspection into a 3,000 hour life, why don't the 50 of you club together, pay for another professional translation, then ask Centrair simply to inform the FAA by AD that the documentation has been upgraded? Minimum work on their part, and probably won't cost each of you that much. Sudden thought. What does the UK documentation for the Pegasus say? Ian If the problem is - have I read this right - that a mistranslation turned a 3,000 hour inspection into a 3,000 hour life.... That what it is. When I get home I will post on this group exact language from the manual. It is very obvious to me that it is a translation issue. On the other hand I don't buy that the FAA is so helpless. We simply need to pressure them until they will take an action. There are some Pegs here in the US with 3000 hours+, my is only 1100 hours or should I say "I don't care because I have a plenty of time? " They were importing the Pegs into the US without a flight manual in English. I don't emember if the pre-certification ships are now standard or experimental category but nonetheless something needs to be done. They are perfectly good gliders capable of some impressive flights and I think we, the owners of Pegase sailplanes, need to write a letter(s) or hire a lawyer (how the hell do you spell that...lawyer or layer) or do something. It is incredible to me that a stupid phrase in someones poor translation is a base for grounding a good and airworthy glider. Jacek Washington State P.S. I am curious what the UK manual says....maybe someone can post that info here and then we can take the issue with the FAA and show them the UK flight manual, maybe they will listen and that might give them a chance of a different approach with Centrair? |
![]() Jacek, Doug et al, Jacek's quote from the Pegase Owner's Manual is accurate. There is NO translation problem. The wording is exact and clear. Unfortunately, the Centrair factory made a mistake by saying two different things on two different pages. One statement said "3,000 hour service life" and the other referred to a "Five year or 3,000 hour inspection." When the glider was certificated in the US, the reference to the 3,000 hour service life was used for issuance of the STC- mainly because Centrair did not provide a 3,000 hour inspection plan. Apparently, they had promised to do so, but went out of business before coming up with it. When they ceased operation, the Type Certificate was taken over by a new entity- Societe Nouvelle Centrair (S.N. Centrair). They also failed to offer an inspection protocol. That is where we sit now. When the FAA inquired about the discrepancy in the two pages, S.N. Centrair once again failed to provide a plan for inspection and reiterated that the 3,000 hour service life is applicable in the US. Once the FAA gets information like that from the manufacturer or the holder of the Type Certificate, the procedure is cut and dried. The FAA is not allowed to make judgments contrary to factory information involving service life- unless the FAA determines that the service life from the factory is too high. S.N. Centrair REDUCED the life limit, therefore, an AD was issued. If S.N. Centrair had said that the 3,000 hour inspection was the governing reference, we would not have this problem. Since no inspection plan is specifically offered, interpretation could have been left open to the A&P or I.A. as to what needed to be checked. As a result of the French holder of the Type Certificate specifically instructing the FAA to disregard the reference to a 3,000 hour inspection, the FAA had no choice but to issue an AD requiring owners to use a pen to cross out the inspection reference. Unless S.N. Centrair reverses this instruction, the AD stays in effect. If they DO reverse the decision, the FAA (according to Greg) would be more than happy to issue an amended AD. This happened last year, when an AD was issued concerning elevator and aileron hinge pins on the Centrair 101 gliders. S.N. Centrair issued a Sevice Bulletin mandating replacement of hinge pins on a specific range of gliders by serial number and/or hinge pin delivery date. This bulletin was turned into an AD that required replacement of pins in ALL Centrair aircraft, regardless of serial number. When this was pointed out to the FAA, Greg rewrote the AD and we were off the hook. He hopes something similar can be done in the case of the service life limit, but it has to come from S.N. Centrair. Once again, TRANSLATION IS NOT THE ISSUE! Mark Mocho |
I'm still curious about the wording in the manuals from across the pond on
the 3k hrs issue. Also, how do you get around the 3k hrs limit in your country? Anyone have a comment? Doug wrote in message oups.com... Jacek, Doug et al, Jacek's quote from the Pegase Owner's Manual is accurate. There is NO translation problem. The wording is exact and clear. Unfortunately, the Centrair factory made a mistake by saying two different things on two different pages. One statement said "3,000 hour service life" and the other referred to a "Five year or 3,000 hour inspection." When the glider was certificated in the US, the reference to the 3,000 hour service life was used for issuance of the STC- mainly because Centrair did not provide a 3,000 hour inspection plan. Apparently, they had promised to do so, but went out of business before coming up with it. When they ceased operation, the Type Certificate was taken over by a new entity- Societe Nouvelle Centrair (S.N. Centrair). They also failed to offer an inspection protocol. That is where we sit now. When the FAA inquired about the discrepancy in the two pages, S.N. Centrair once again failed to provide a plan for inspection and reiterated that the 3,000 hour service life is applicable in the US. Once the FAA gets information like that from the manufacturer or the holder of the Type Certificate, the procedure is cut and dried. The FAA is not allowed to make judgments contrary to factory information involving service life- unless the FAA determines that the service life from the factory is too high. S.N. Centrair REDUCED the life limit, therefore, an AD was issued. If S.N. Centrair had said that the 3,000 hour inspection was the governing reference, we would not have this problem. Since no inspection plan is specifically offered, interpretation could have been left open to the A&P or I.A. as to what needed to be checked. As a result of the French holder of the Type Certificate specifically instructing the FAA to disregard the reference to a 3,000 hour inspection, the FAA had no choice but to issue an AD requiring owners to use a pen to cross out the inspection reference. Unless S.N. Centrair reverses this instruction, the AD stays in effect. If they DO reverse the decision, the FAA (according to Greg) would be more than happy to issue an amended AD. This happened last year, when an AD was issued concerning elevator and aileron hinge pins on the Centrair 101 gliders. S.N. Centrair issued a Sevice Bulletin mandating replacement of hinge pins on a specific range of gliders by serial number and/or hinge pin delivery date. This bulletin was turned into an AD that required replacement of pins in ALL Centrair aircraft, regardless of serial number. When this was pointed out to the FAA, Greg rewrote the AD and we were off the hook. He hopes something similar can be done in the case of the service life limit, but it has to come from S.N. Centrair. Once again, TRANSLATION IS NOT THE ISSUE! Mark Mocho |
So I guess we need the equivalent of a class action lawsuit against SN
Centrair to come up with the 3k hr inspection. Anyone know of a good, cheap law firm in France? I'm not bumping against the 3000 hour limit yet as my Pegasus has about 1200 hrs on it. But if we want to sell the glider it sure would be nice to have that limit dropped. I am curious to know how the manual reads in other countries since they don't seem to have the same problem. Anyone have a Brit, German, or French version floating around? Doug "ASM" wrote in message oups.com... wrote: Doug wrote: It really is hard to believe that a mistranslation will eventually ground 50 gliders. I think more pressure on the FAA is also needed too. Maybe wishful thinking, but we owners should try *anything* to protect our investment, including a new translation. Doug "Ian" wrote in message ups.com... wrote: According to the FAA, there are approximately 50 Centrair Pegase 101 gliders in the US. I don't know how effective we are as a group, but letters to Centrair and emails couldn't do to much harm. If the problem is - have I read this right - that a mistranslation turned a 3,000 hour inspection into a 3,000 hour life, why don't the 50 of you club together, pay for another professional translation, then ask Centrair simply to inform the FAA by AD that the documentation has been upgraded? Minimum work on their part, and probably won't cost each of you that much. Sudden thought. What does the UK documentation for the Pegasus say? Ian If the problem is - have I read this right - that a mistranslation turned a 3,000 hour inspection into a 3,000 hour life.... That what it is. When I get home I will post on this group exact language from the manual. It is very obvious to me that it is a translation issue. On the other hand I don't buy that the FAA is so helpless. We simply need to pressure them until they will take an action. There are some Pegs here in the US with 3000 hours+, my is only 1100 hours or should I say "I don't care because I have a plenty of time? " They were importing the Pegs into the US without a flight manual in English. I don't emember if the pre-certification ships are now standard or experimental category but nonetheless something needs to be done. They are perfectly good gliders capable of some impressive flights and I think we, the owners of Pegase sailplanes, need to write a letter(s) or hire a lawyer (how the hell do you spell that...lawyer or layer) or do something. It is incredible to me that a stupid phrase in someones poor translation is a base for grounding a good and airworthy glider. Jacek Washington State P.S. I am curious what the UK manual says....maybe someone can post that info here and then we can take the issue with the FAA and show them the UK flight manual, maybe they will listen and that might give them a chance of a different approach with Centrair? O'K...here is what the manual says: 5.01 - Life Limits The structure life limit is 3000 hours. 5.1 - Types of Inspections and Intervals -Small maintenance inspection (S.M.I.) The small maintenance inspection has it be executed after every glider assembly or every 100 flight hours. -Annual inspection The program for annual inspection has to be executed when the first of the two following limits is reached: -Yearly, -After 500 flight hours -General inspection The program for general inspection should be executed when the first of the two following limits is reached: -Every five years -After 3000 flight hours. I copied the text above word for word from my sailplane flight manual dated Dec. 16th 1983. If you really read this carefully it also means that when you assemble glider you need to have a mechanic (A&P in case of the US) inspect the glider! Also, the paragraph "General Inspection" does refer to 5 years- that also means (or can it be interpreted by another inspector) that the sailplane needs to be discarded after 5 years ???!!! This is clearly case of poor translation and in some degree a case of over-zealous FAA inspector You cannot convince me otherwise. In the mean time we need to keep pressing the FAA for a corrective action or deletion of this "controversial" AD. Jacek Washington State Peg Serial #156 |
ASM wrote:
O'K...here is what the manual says: US manual, I assume? -Small maintenance inspection (S.M.I.) The small maintenance inspection has it be executed after every glider assembly or every 100 flight hours. I copied the text above word for word from my sailplane flight manual dated Dec. 16th 1983. If you really read this carefully it also means that when you assemble glider you need to have a mechanic (A&P in case of the US) inspect the glider! I think - someone may wish to correct me - that that is indeed the case in France. I flew at Le Blanc a few times and at St Auban once, and my understanding was that in both places French gliders had to be assembled and checked by qualified personnel. Ian |
![]() Ian wrote: ASM wrote: O'K...here is what the manual says: US manual, I assume? -Small maintenance inspection (S.M.I.) The small maintenance inspection has it be executed after every glider assembly or every 100 flight hours. I copied the text above word for word from my sailplane flight manual dated Dec. 16th 1983. If you really read this carefully it also means that when you assemble glider you need to have a mechanic (A&P in case of the US) inspect the glider! I think - someone may wish to correct me - that that is indeed the case in France. I flew at Le Blanc a few times and at St Auban once, and my understanding was that in both places French gliders had to be assembled and checked by qualified personnel. Ian To All Pegs Owners in the US: The problem can be resolved using a lawyer. I spend 4 days calling around and made some phone calls in Europe. The best answer is a class action against S.A.Centrair. Please email me directly. Jacek Washington State |
What a brilliant idea !!
Send the hords of lawyers to France. The French must be trembling with fear now ! Lets be a little bit more realistic and analyze the business aspects. Here is a French company that has successfully (and legally) limited its liability exposure in the US market, albeit in a sneaky way. (Other companies are not even bothering anymore with offering product in the US due to the liability hassle) The FAA nicely supported SN Centrair by taking the over-time Pegs out of the market. Why in hell would Centrair pick up new liabilities in the US territory, where they have exited the glider market long time ago. From a business perspective, they would have to be complete fools to re-engage on this. For you Peg drivers, I hope that I am wrong. I know the Peg is a nice ship. Quote:
Sell them in France; ship them over, get them certified
for 12,000hrs there, and re-import with a French POH and fly experimental. At 10:12 04 January 2007, Dumass wrote:[color=blue][i] What a brilliant idea !! Send the hords of lawyers to France. The French must be trembling with fear now ! Lets be a little bit more realistic and analyze the business aspects. Here is a French company that has successfully (and legally) limited its liability exposure in the US market, albeit in a sneaky way. (Other companies are not even bothering anymore with offering product in the US due to the liability hassle) The FAA nicely supported SN Centrair by taking the over-time Pegs out of the market. Why in hell would Centrair pick up new liabilities in the US territory, where they have exited the glider market long time ago. From a business perspective, they would have to be complete fools to re-engage on this. For you Peg drivers, I hope that I am wrong. I know the Peg is a nice ship. Wrote: Ian wrote: To All Pegs Owners in the US: The problem can be resolved using a lawyer. I spend 4 days calling around and made some phone calls in Europe. The best answer is a class action against S.A.Centrair. Please email me directly. Jacek Washington State -- dumass |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
