simulator makes local news
Old December 30th 06, 04:37 AM posted to rec.aviation.piloting
Jay Honeck
Default simulator makes local news
http://gorgewindsinc.com/simulator.html
I wonder how they project the "world" on a curved screen? It's hard to
tell how many projectors they've got going, from that pic.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 30th 06, 04:41 AM posted to rec.aviation.piloting
Montblack
("Jay Honeck" wrote)
I count three. (?)
Montblack
Old December 30th 06, 06:45 AM posted to rec.aviation.piloting
Mxsmanic
Jay Honeck writes:
I see three projectors. Unless they have very special lenses indeed,
I don't see how they can project clear images onto curved screens.
Old December 30th 06, 02:29 PM posted to rec.aviation.piloting
Jay Honeck
Setting up the over-lap between the screens so that it doesn't look
weird must be a tricky affair, indeed.
(Gears turning...where can I mount a curved screen? Whey can I even
*buy* a curved screen? :-)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 30th 06, 03:17 PM posted to rec.aviation.piloting
Peter Dohm
"Jay Honeck" wrote in message
Jay Honeck
Iowa City, IA
Pathfinder N56993
The biggest problem should be eliminating "keystoning" so that the overlap
can be eliminated; and more expensive projectors should include that
adjustment. Then the unused area, after having eliminated the overlap,
should just appear as a dark vertical line.
I didn't spend enough time to look at the specifics of the simulator used in
the clip; but the annunced identified it as a Frasca TdruFlite simuator and
the Frasca website: http://www.frasca.com/ with the display options shown
at
http://www.frasca.com/web_pages/broc...%20systems.htm
Peter
Old December 31st 06, 05:14 AM posted to rec.aviation.piloting
John Clear
In article . com,
There is fancy stuff you can do with the video feed before sending
it to a standard projector, but I don't know how it is done. I
haven't played with this kind of thing in years, and that was on
high end SGI stuff. We had a machine in the lab that was driving
sixteen displays. That was a fun machine to play a flight sim on.
After you get the curved screen, you'll be looking for the next
upgrade. Why not just skip a few steps and build an IMAX dome
theater at the hotel?
John
John Clear - http://www.clear-prop.org/
Old December 31st 06, 05:47 AM posted to rec.aviation.piloting
Jose[_1_]
upgrade.
Yanno, take a few of the aircraft parts that get donated to you and
dummy up a real cockpit. Put relays behind the switches, and connect
them to the keyboard (or just take the keyboard apart and run wires).
Instant (heh) upgrade.
Jose
He who laughs, lasts.
Old February 9th 07, 01:41 AM posted to rec.aviation.piloting
Margy Natalie
Jay Honeck
Iowa City, IA
Pathfinder N56993
http://www.e-planetarium.com/
You can run movies in them too.
Margy
Old February 9th 07, 03:32 AM posted to rec.aviation.piloting
Morgans
Sorry abbout piggy-backing this on Margy - Jay's post was gone.
You could see where the projector's image ends on the screen and mask and
paint a thin black line on the screen. That would make overlap a non issue,
and be a minimal distraction. That would be the easy way out.
Get some bulk screen material, and sew a flap on the bottom and the top of
the material. Get some thin wall electrical conduit, and bend the
appropriate radius in the tube, with a top and bottom matching tube. You
would want to weld the joints, instead of using a connector. If you weld it
yourself, be sure to not breath the fumes, because the galvanized pipe
welding fumes will give you a very nasty headache, just for starts.
To mount it, make brackets to screw to the tubes, and fasten them on after
the screen has been streached on, so the screen will se the same tension
everywhere.
To make it somewhat portable, use some spreaders from the top to bottom
tube, mounted the same way, but mounted so they will be back away from the
screen. A mounting from the bottom to the floor could have some casters, so
you could roll it out of the way.
I'm not sure, but I think for the best results, a special lens would need to
be used, or a program to get the right aspect ration projected onto the
screen. Even then, I'm not so sure that it would be projected in focus
without a special lens, since the distance from the lens to a flat screen is
different (longer) at the sides of the picture as compared to the center of
the picture. With the curved screen, it would be the same distance on the
edges and the center.
Jim in NC
Old February 9th 07, 02:23 PM posted to rec.aviation.piloting
Jose
Even then, I'm not so sure that it would be projected in focus without a special lens, since the distance from the lens to a flat screen is different (longer) at the sides of the picture as compared to the center of the picture. With the curved screen, it would be the same distance on the edges and the center.
I'll bet it would be more in focus. I don't think lenses are designed
to take the straightness of a screen into account, and we just put up
with blurry edges and a sharper donut.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
16 Mar 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 March 17th 06 12:39 AM
30 Jan 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 31st 06 03:21 AM
30 Jan 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 January 31st 04 03:55 AM
Local TV News ran an accurate story about airframe icing last night Peter R. Piloting 5 January 29th 04 01:01 AM
