Any Cessna 210 owners?
Old December 30th 06, 11:35 PM posted to rec.aviation.owning
Jim Carter[_1_]
Default Any Cessna 210 owners?
-----Original Message-----
Posted At: Saturday, December 30, 2006 5:09 PM
Posted To: rec.aviation.owning
Conversation: Any Cessna 210 owners?
Subject: Any Cessna 210 owners?
Does anyone here own an older model C210 (strut-wing models)? I'm
looking at a 1966 and would like to learn more about the real world
costs of operation as compared to the 182 I owned previously. I know
the insurance is a lot higher ($3800 vs. $1200), and fuel burn is
higher, but what about maintenance costs? Other than the gear saddle,
what are the other trouble spots? How much trouble is the gear saddle
in actuality?
Matt
I used to be a member of Cessna Pilots Assoc and found access to their
210 documentation quite useful. I was looking at an F model a couple of
years ago after deciding that the D model and years prior had some
issues with fuel tanks. I think the F model was where they switched from
bladders to wet wing, but I'd have to go back to check for sure. Isn't
the F model the '65 or '66?
They also have a well-respected 210 owners course that is almost always
sold out.
Cessna Owners Assoc isn't as focused on the maintenance aspects as far
as I can tell, but is rather focused on pilot safety issues.
Old December 31st 06, 12:05 AM posted to rec.aviation.owning
Mike Adams
I'll second that recommendation. The CPA has a wealth of information
available including very active discussion forums on all the models, where
I'm sure you can get some good input. http://www.cessna.org
Mike
Old December 31st 06, 12:10 AM posted to rec.aviation.owning
Matt Whiting
I'll check to see how much information is available to non-members.
Unless the membership is pretty cheap, I don't want to join just to
research a purchase. I can definitely see the value though as an owner.
Thanks,
Matt
Old December 31st 06, 02:32 AM posted to rec.aviation.owning
Jim Carter[_1_]
Posted At: Saturday, December 30, 2006 6:11 PM
Mike Adams wrote:
their
where
owner.
Thanks,
Matt
The membership is less than 10 gallons of 100LL.
Old December 31st 06, 02:34 AM posted to rec.aviation.owning
Matt Whiting
Mike Adams wrote:
their
where
owner.
Thanks,
Matt
Depends on where you buy your gas. My local airport sells 10 gallons
for $31.50 which is quite a bit less than the $45 membership for CPA,
but your point is well taken. It just seems a waste to join a brand
organization when you don't even own an airplane. And I'd hate to have
to join every other association just to compare a few different airplane
models.
Matt
Old December 31st 06, 10:19 AM posted to rec.aviation.owning
Jim Carter[_1_]
Posted At: Saturday, December 30, 2006 8:35 PM
have
airplane
models.
Matt
Dang Matt - can I get that fuel delivered?
Seriously though, albeit I don't own a Cessna I do fly them a lot. I've
gotten a lot of good info from both CPA and COA that is directly
applicable to my needs. The ability to contact them for technical
information for $45 a year is still a lot cheaper than most "help desks"
-- and they comprehend my question without having to follow some script.
I would recommend a "brand organization" rather than a "type club"
because they tend to cover an entire manufacturer's line -- in case you
occasionally fly different models. For example, there will be
information about the 310 and the 140 in the same weekly tech update.
Old December 31st 06, 02:22 PM posted to rec.aviation.owning
Matt Whiting
have
airplane
models.
Matt
Just land at N38 and you can deliver into your tanks all that you want! :-)
Matt
Jim Carter[_1_]
Mike Adams wrote:
their
where
owner.
Thanks,
Matt
Jim Carter[_1_]
Mike Adams wrote:
their
where
owner.
Thanks,
Matt
Old December 31st 06, 09:43 AM posted to rec.aviation.owning
Jim Carter[_1_]
Mike Adams wrote:
their
where
owner.
Thanks,
Matt
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
Any Cessna 400 series owners out there? G.R. Patterson III Owning 1 April 9th 04 12:41 AM
