2-Batteries
Old December 31st 06, 12:03 AM posted to rec.aviation.soaring
Gary Emerson
Default 2-Batteries
Tinwings wrote:
Being the incurably curious type, I decided to test this theory. I
took two known good 7Ah 12V SLA batteries and discharged one to 8 volts
(resting) with a 12V light bulb. The other battery I topped off with a
charger to 13.6 volts. I connected the two using less than two feet of
18 gauge wire and a ordinary toggle switch. Using a 60 Mhz bandwith
oscilloscope and a hall-effect type current probe I looked at the
resulting waveform when I closed the switch; a nice square edged rise
to about 3 amps, tapering down to 2.5 amps in a few seconds. Because I
didn't know what the frequency response of this current probe was, I
inserted a precision .001 ohm current shunt in line (very high
frequency response) and used the scope to watch the voltage drop across
it. The results were identical; no current spike, no inrush of current
- just a nice square edged waveform rising to about 3 amps. This simply
isn't going to weld contacts, burn out switches or blow (properly
sized) fuses. As for "wasting energy" by dumping from the good battery
into the dead battery when switching over - just do the math. Even if
the two batteries were connected for as much as 5 seconds while
switching from one to the other (two switch or "make before break"
switch arrangement), you will be using less than one thousanth of the
good battery's capacity to charge the "dead" battery.
If the batteries are both "good", but not charged equally, then the last
part is true. If a battery happens to go "bad" and won't take a charge
then the situation is different. Then the "bad" battery will just suck
down the extra power from the good battery and that power will not be
recovered.
Old December 31st 06, 12:09 AM posted to rec.aviation.soaring
Gary Emerson
Default 2-Batteries
recovered.
Sorry, didn't read your post fully. You were only talking about the
very short period when the batteries are still connected while switching
from A to B. The nice thing about the diode setup is you'll never have
to fiddle with a battery switch again.
Old December 31st 06, 12:34 AM posted to rec.aviation.soaring
[email protected][_1_]
Default 2-Batteries
The previous poster was making measuremnts that disproved the argument
that there is a loss while temporarilly having both masters on while
switching batteries.Whichever way you slice that it is just not an
issue that causes any significant power loss, It is totally
insignificant, you lose much more power though ohmic loses in fuses
and circuit breakers.
Of course that relies on the operator not to accidently leave two
master switches both on all the time (without taking the diode
approach).
Darryl
recovered.
Electric maned airplane Flyingmonk Piloting 26 July 20th 06 05:43 AM
Electric maned airplane Flyingmonk Home Built 26 July 20th 06 05:43 AM
Becker AR-3201 radio owners: check your batteries sssarah Soaring 3 May 24th 06 07:40 AM
Switching Batteries Advice? ContestID67 Soaring 17 January 12th 06 01:02 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
