![]() "Robert M. Gary" wrote in message oups.com... 2) Timing the hold to arrive back at the holding fix right at the EFC time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. Huh? Did you make all that up? The only time you need to cross the holding fix at any particular time is when you are doing a timed approach from the hold and you are given a crossing time. EFC time has nothing to do with anything other than lost com, and there is no requirement or recommendation from the FAA or anyone else I have ever heard to attempt crossing the fix at EFC time, nor can I imagine any need to do so. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. A hold can be almost any time you want unless you are assigned a specific time, and that time applies to the inbound leg, and is not meant to be precise. A default hold is a one-minute inbound leg, but you can make it longer or shorter if you want and nobody cares. Don't go to extremes, and go do five minutes, but within wide limits (depends on your speed), it just doesn't really matter. There is no specification anywhere that a hold must be four or three or two minutes or combinations thereof. The only guidance is a one-minute inbound leg for the default holding pattern, and staying within the maximum distance specified on the chart, if any. Of course, on a checkride, you ought to strive for the specified time for the inbound leg. On a timed approach, the crossing time is meant to be fairly exact, so you adjust as required, and not in increments of one minute. I don't understand the point of telling people that they shouldn't worry much about holds because you hardly ever have to fly one. You do have to fly them at times, and when that time comes, you have to know how to do them and be proficient at it. They are a standard maneuver of instrument flying. |
![]() Stan Prevost wrote: "Robert M. Gary" wrote in message oups.com... 2) Timing the hold to arrive back at the holding fix right at the EFC time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. Huh? Did you make all that up? The only time you need to cross the holding fix at any particular time is when you are doing a timed approach from the hold and you are given a crossing time. EFC time has nothing to do with anything other than lost com, and there is no requirement or recommendation from the FAA or anyone else I have ever heard to attempt crossing the fix at EFC time, nor can I imagine any need to do so. From the instrument PTS III(C) "Holding Procedures" "8.Uses proper wind correction procedures to maintain the desired pattern and to arrive over the fix as close as possible to a specified time." On your checkride you need to time your hold to arrive over the fix w/i about 1 minute of the specified time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. A hold can be almost any time you want unless you are assigned a specific time, and that time applies to the inbound leg, and is not meant to be precise. Right, that's how you cause the aircraft to arrive at the fix at the ETC. I don't understand the point of telling people that they shouldn't worry much about holds because you hardly ever have to fly one. I never said that. -Robert, CFII |
![]() "Robert M. Gary" wrote in message oups.com... Stan Prevost wrote: "Robert M. Gary" wrote in message oups.com... 2) Timing the hold to arrive back at the holding fix right at the EFC time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. Huh? Did you make all that up? The only time you need to cross the holding fix at any particular time is when you are doing a timed approach from the hold and you are given a crossing time. EFC time has nothing to do with anything other than lost com, and there is no requirement or recommendation from the FAA or anyone else I have ever heard to attempt crossing the fix at EFC time, nor can I imagine any need to do so. From the instrument PTS III(C) "Holding Procedures" "8.Uses proper wind correction procedures to maintain the desired pattern and to arrive over the fix as close as possible to a specified time." On your checkride you need to time your hold to arrive over the fix w/i about 1 minute of the specified time. That relates to timed approaches from a holding fix, which is the only time a crossing time will be specified. No specific tolerances on the time are given anywhere that I know of. I wouldn't disagree with your "about one minute", although nobody I know uses tolerances that large in training. DPEs around here don't seem to specify a time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. A hold can be almost any time you want unless you are assigned a specific time, and that time applies to the inbound leg, and is not meant to be precise. Right, that's how you cause the aircraft to arrive at the fix at the ETC. So why do you say to mix up holds having integral minute leg lengths? And why are holds 4, 3, or 2 minutes? I don't understand ETC, I assume you mean EFC as you stated in your original post. It has nothing to do with EFC. From the Instrument Flying Handbook: "EFC times require no time adjustment since the purpose for issuance of these times is to provide for possible loss of two-way radio communications." I don't understand the point of telling people that they shouldn't worry much about holds because you hardly ever have to fly one. I never said that. True, you did not explicitly say that. You did say: "In real life holding is about as common as being hit by lightening. Even when you do get a hold its usually just a vectored hold, not a formal procedures." I don't know your intent with that comment, but it appeared to me to be implicitly deprecating the importance of holding patterns as a component of instrument flight and the importance of being proficient in flying them. Anyway, my experience is certainly different, and "formal" holds are not uncommon (but not timed approaches). |
![]() Stan Prevost wrote: "Robert M. Gary" wrote in message oups.com... So why do you say to mix up holds having integral minute leg lengths? And why are holds 4, 3, or 2 minutes? The 4,3 and 2 are the standard holds a pilot has in his bag. So if he needs to hold for 7 minutes, he starts with a 4 and then does a 3, and he's back at the fix, ready for the approach. A 4 minute hold is 1 minute out, a 3 minute hold is 30 seconds out, and a 2 minute hold is a circle. These are standard training techniques for teaching holds. I never said that. True, you did not explicitly say that. You did say: "In real life holding is about as common as being hit by lightening. Even when you do get a hold its usually just a vectored hold, not a formal procedures." I don't know your intent with that comment, but it appeared to me to be implicitly deprecating the importance of holding patterns as a component of instrument flight and the importance of being proficient in flying them. Because simulator guys don't need to take checkrides, they don't need to wait for further clearance. They're trying to reproduce real life, in real life you almost never get assigned formal holds. I think you take the gamers way to seriously. -Robert, CFII |
![]() "Robert M. Gary" wrote in message ups.com... The 4,3 and 2 are the standard holds a pilot has in his bag. So if he needs to hold for 7 minutes, he starts with a 4 and then does a 3, and he's back at the fix, ready for the approach. A 4 minute hold is 1 minute out, a 3 minute hold is 30 seconds out, and a 2 minute hold is a circle. These are standard training techniques for teaching holds. I don't know what you mean by standard training techniques. Maybe they are your standards. There is no reference to such techniques, that I am aware of, in any of the FAA materials, and I have never seen any published non-FAA instrument training book that mentions such techniques. I would appreciate knowing about them. Everything I have ever read just says to adjust your last time around to cross at the specified time (not EFC time). There are limits, of course. If you are just beginning your outbound turn (for example), and ATC calls and says to cross the fix one minute later, you ain't gonna make it. Because simulator guys don't need to take checkrides, they don't need to wait for further clearance. They're trying to reproduce real life, in real life you almost never get assigned formal holds. I think you take the gamers way to seriously. I don't understand where gamers fit into this exchange, I took issue with your statements, not a gamer's. I and other real-life pilots have disputed, based on real-life experience, your repeated assertion that in real life you almost never get assigned formal holds. And I dispute any positive value to such a statement, and would assign it a negative value, for the reasons already stated. |
your statements, not a gamer's. If you've watched these groups for long you would know that Mxsmanic is not a real pilot. He is a gamer and will not likely ever set foot in a real plane. If you can find a good reason for gamers to play with holds go ahead. -Robert |
![]() Stan Prevost wrote: From the instrument PTS III(C) "Holding Procedures" "8.Uses proper wind correction procedures to maintain the desired pattern and to arrive over the fix as close as possible to a specified time." On your checkride you need to time your hold to arrive over the fix w/i about 1 minute of the specified time. That relates to timed approaches from a holding fix, which is the only time a crossing time will be specified. No specific tolerances on the time are given anywhere that I know of. I wouldn't disagree with your "about one minute", although nobody I know uses tolerances that large in training. DPEs around here don't seem to specify a time. From the PTS for ATP V Instrument B: Holding 9 ) Arrives over the holding fix as close as possible to the "expect further clearance" time. -Robert, CFII |
![]() "Robert M. Gary" wrote in message oups.com... From the PTS for ATP V Instrument B: Holding 9 ) Arrives over the holding fix as close as possible to the "expect further clearance" time. Thanks for that reference, Robert. I have not read the ATP PTS but have never seen any other reference to using EFC in a hold. I still have no idea why it would be so, other than just as a checkride device. It contradicts the standard FAA references that I quoted. Stan |
![]() Stan Prevost wrote: "Robert M. Gary" wrote in message oups.com... From the PTS for ATP V Instrument B: Holding 9 ) Arrives over the holding fix as close as possible to the "expect further clearance" time. Thanks for that reference, Robert. I have not read the ATP PTS but have never seen any other reference to using EFC in a hold. I still have no idea why it would be so, other than just as a checkride device. It contradicts the standard FAA references that I quoted. Yes, your right that it contradicts the Instrument Flying Handbook. Not sure if there is a revision in the works for either or if the FAA is happy for them to disagree. ![]() for both checkrides. IR or ATP, we pretty much teach the same instrument stuff since a lot of the IR students plan on taking the ATP checkride when able. -Robert |
People do care..
"Stan Prevost" wrote in message ... A hold can be almost any time you want unless you are assigned a specific time, and that time applies to the inbound leg, and is not meant to be precise. A default hold is a one-minute inbound leg, but you can make it longer or shorter if you want and nobody cares. Don't go to extremes, and go do five minutes, but within wide limits (depends on your speed), it just doesn't really matter. There is no specification anywhere that a hold must be four or three or two minutes or combinations thereof. The only guidance is a one-minute inbound leg for the default holding pattern, and staying within the maximum distance specified on the chart, if any. Of course, on a checkride, you ought to strive for the specified time for the inbound leg. People do care about timeing in the holding pattern, time is set to one minute on the inbound leg, (1.5 min at higher altitudes) to for "protected airspace", this protected airspace is to protect you from other traffic or terrain in a non radar enviroment. You can ask for more from ATC. But if you do not ask, he is expecting you to fly one minute legs (1.5 min legs).. and not extend your pattern to 20nm on your own whim. BT |
How much is autopilot on commercial flights today? | Mxsmanic | Piloting | 25 | September 12th 06 06:41 AM |
KAP140 autopilot and a KLN94 GPS question | STICKMONKE | Instrument Flight Rules | 5 | November 12th 05 04:06 AM |
mitchell autopilot | dave | Owning | 1 | May 5th 04 06:11 PM |
Chelton AP-3C autopilot | Kyler Laird | Owning | 0 | April 2nd 04 03:08 PM |
KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 02:01 AM |
