![]() "BT" wrote in message ... People do care.. "Stan Prevost" wrote in message ... A hold can be almost any time you want unless you are assigned a specific time, and that time applies to the inbound leg, and is not meant to be precise. A default hold is a one-minute inbound leg, but you can make it longer or shorter if you want and nobody cares. Don't go to extremes, and go do five minutes, but within wide limits (depends on your speed), it just doesn't really matter. There is no specification anywhere that a hold must be four or three or two minutes or combinations thereof. The only guidance is a one-minute inbound leg for the default holding pattern, and staying within the maximum distance specified on the chart, if any. Of course, on a checkride, you ought to strive for the specified time for the inbound leg. People do care about timeing in the holding pattern, time is set to one minute on the inbound leg, (1.5 min at higher altitudes) to for "protected airspace", this protected airspace is to protect you from other traffic or terrain in a non radar enviroment. You can ask for more from ATC. But if you do not ask, he is expecting you to fly one minute legs (1.5 min legs).. and not extend your pattern to 20nm on your own whim. You will notice that I cautioned against extremes and not exceeding maximum distances. My intent was to illustrate that the leg time is nothing to obsess over, within reasonable lengths, and that leg lengths are not limited to integral minutes, and that EFC has nothing to do with it. If a holding pattern might be flown at anywhere from, say, 60 knots to possibly over 200 knots, a one minute leg will range from one to over three miles, not even considering wind. Since it is really distance that matters, and over three miles is acceptable (unless Cat E is excluded), that would correspond to over three minutes for the 60 knot airplane. Variation from one minute or less to over three minutes would be quite large in term of pilot technique, and would border on extreme, IMO. Nonwithstanding all that, an instrument pilot should, IMO, be proficient in being able to adjust leg timing as required (not just mixing up integral minute legs) to meet a crossing time for a timed approach. It is just that when prioritizing workload during a normal hold, precise leg timing is not at top of the list, especially for slower aircraft. (Can a helicopter hover for a hold in VMC, or must it fly the hold pattern with specified legs?) |
BT writes:
People do care about timeing in the holding pattern, time is set to one minute on the inbound leg, (1.5 min at higher altitudes) to for "protected airspace", this protected airspace is to protect you from other traffic or terrain in a non radar enviroment. I distinctly remember, when I was little, seeing a drawing that showed aircraft in what appeared to be a holding pattern (an oval track around a fix), and at different levels, with each aircraft dropping one level on each trip around the pattern. I understood that aircraft were "stacked" this way while waiting to land. Is that no longer done? I don't see any mention of it in any of the sources I've consulted. Or perhaps I remembered something incorrectly? Maybe it was never done (?). It sounds a bit risky. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... BT writes: People do care about timeing in the holding pattern, time is set to one minute on the inbound leg, (1.5 min at higher altitudes) to for "protected airspace", this protected airspace is to protect you from other traffic or terrain in a non radar enviroment. I distinctly remember, when I was little, seeing a drawing that showed aircraft in what appeared to be a holding pattern (an oval track around a fix), and at different levels, with each aircraft dropping one level on each trip around the pattern. I understood that aircraft were "stacked" this way while waiting to land. Is that no longer done? I don't see any mention of it in any of the sources I've consulted. Or perhaps I remembered something incorrectly? Maybe it was never done (?). It sounds a bit risky. -- Transpose mxsmanic and gmail to reach me by e-mail. It is done that way.. but what protects them laterially from adjacent or crossing airways, other holding patterns, or terrain at low altitude in a non radar environment. BT |
So last week then?
"....I distinctly remember, when I was little....." |
How much is autopilot on commercial flights today? | Mxsmanic | Piloting | 25 | September 12th 06 06:41 AM |
KAP140 autopilot and a KLN94 GPS question | STICKMONKE | Instrument Flight Rules | 5 | November 12th 05 04:06 AM |
mitchell autopilot | dave | Owning | 1 | May 5th 04 06:11 PM |
Chelton AP-3C autopilot | Kyler Laird | Owning | 0 | April 2nd 04 03:08 PM |
KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 02:01 AM |
