GNS 430W vs GNS 480
Old January 1st 07, 11:44 PM posted to rec.aviation.ifr
Roy N5804F
Default GNS 430W vs GNS 480
"JD" wrote in message
On Jan 1, 5:17 pm, "Roy N5804F"
Why is a new version of the software is required and what changes it will
introduce ?
I don't know what v3.0 firmware for the 480 will bring. The current 480
firmware is 2.1, so 3.0 should have some significate enhancements. I
just got this from the support guys when I was upgrading to 2.1
When did Garmin announced that they will "continue development and
support
for the 480" ?
What do all the aircraft fitted with only dual 430/530's use for primary
enroute navigation under instrument rules ?
What ever they have been using. Could be VOR for example.
I do believe that the updated software for the 480 is required to cure
existing problems found with the 480 during /W certification for the
430/530 units ?
The VOR portion is an integral part of the 430/530 so I would dispute that
the 430/530's are certified for enroute in a normal certified IFR
installation.
Am I wrong again ?
Roy
Old January 1st 07, 11:53 PM posted to rec.aviation.ifr
JD
On Jan 1, 5:44 pm, "Roy N5804F"
"JD" wrote in ooglegroups.com...
introduce ?
support
for the 480" ?
What ever they have been using. Could be VOR for example.I do believe that the updated software for the 480 is required to cure
430/530 units ?
installation.
Am I wrong again ?
Roy, could just be a time lag in reading/posting, but the 530/430s ARE
NOT currently certified for PRIMARY ENROUTE NAVIGATION, IFR or
otherwise.
Old January 2nd 07, 12:02 AM posted to rec.aviation.ifr
Mike Adams[_2_]
"JD" wrote in
ooglegroups.com...
primary enroute navigation under instrument rules ?
430/530 units ?
dispute that the 430/530's are certified for enroute in a normal
certified IFR installation.
Am I wrong again ?
otherwise.
I think Roy is correct. The 430/530 *GPS* function is not approved for primary nav, but the built-in VOR
receiver could serve as the required additional means of navigation. The issue is not the box failing, it's
the loss of RAIM integrity with the older TSO C129a GPS boxes. This limitation goes away with the
WAAS approval.
Mike
Old January 2nd 07, 12:17 AM posted to rec.aviation.ifr
JD
On Jan 1, 6:02 pm, Mike Adams wrote:
"JD" wrote in
ooglegroups.com...
430/530 units ?
Am I wrong again ?
otherwise.I think Roy is correct. The 430/530 *GPS* function is not approved for primary nav, but the built-in VOR
WAAS approval.
Mike
From Garmin's news letter:
http://www.garmin.com/pressroom/aviation/110906.html
"*Due to the TSO limitation in conjunction with the AFMS limitation,
Garmin's GNS 400/500 series navigators will not be certified as a
"primary means" of GPS navigation until after customers install a new
software version. Garmin expects to issue a Service Bulletin in the
first quarter of 2007 issuing the software. The software will be
updated via the 400/500W data loader card. This required software
update is expected to be available in the first quarter of 2007."
Old January 2nd 07, 02:42 AM posted to rec.aviation.ifr
Sam Spade
otherwise.
The only "otherwise" that comes to mind is VFR, and nothing, other than
my piloting skills, has to be certified for primary en route VFR nav. ;-)
Old January 2nd 07, 12:10 AM posted to rec.aviation.ifr
Stan Prevost
"Roy N5804F" wrote in message
ink.net...
that the 430/530's are certified for enroute in a normal certified IFR
installation.
Am I wrong again ?
I don't have direct personal knowledge of this, but I have read in several
places and have been told that the radios are on a separate power supply
from the GPS receiver. I don't know how the display is driven and powered,
if it is independent of the GPS portion.
