![]() "john smith" wrote in message ... d&tm wrote: in my PPL training it was drummed in to me the importance of always doing the w & b calcs with the fuel you were taking and also the zero fuel case. I posted sometime ago that with the Warriors I flew it was impossible to go outside the w & b envelope by burning fuel. I have just finished my transition to the C172 and have extensively investigated different loading scenarios and found exactly the same thing, at least with this N model I am flying. Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? Terry Bonanza's come immediately to mind. I do not know if the current models are built this way, the older models had the fuel stored in the front of the wing, ahead of the main spar. Any weight in the aircraft behind the front seats is behind the fuel weight. As fuel is burned, the weight ahead of the spars decreases while the weight behind the spar remains the same, hence the cg moves aft. At some point, the cg moves out of the envelope (the ability of the horizontal stabilizer to provide sufficient lift). Piper PA32's will can also develope this situation. Cessna's seem to have a broader range. You have to look at each aircrafts envelope. Van's tandem seat RV-4's had a bad string of fatal accidents until the word got out and builders became more aware of the potential danger. It is true that the CG moves aft with fuel burn on all of the 2 place Van's designs. It is also true that depending on the individual aircraft and the loading that you could run the CG beyond the aft limit. You certainly can in my RV-6. That said, please do some fact checking before you conjure up a "bad string of fatal accidents" for RV-4's due to CG issues. Didn't happen. There was one accident in the NTSB database between 1980 and today where CG was listed as a factor... Not jumping your kimchee or anything, but facts are facts, and making 'em up (or remembering 'em incorrectly) isn't a good idea when safety is at issue. KB |
(or remembering 'em incorrectly) isn't a good idea when safety is at issue. Kyle, I have personal knowledge of four, and first hand reports from others in the RV community. The rash of accidents happened in the late 80's/early 90's. They were the basis for Van revising the aft cg limit on RV-4's Just because the NTSB doesn't list it doesn't mean they didn't happen. I also know of other NTSB final reports where the report did not match the facts. You have to understand that the NTSB does not investigate all accidents. In most cases, they take the information from another agency and synthesize the results. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
"Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 03:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
