GNS 430W vs GNS 480
Old January 3rd 07, 01:14 AM posted to rec.aviation.ifr
Robert M. Gary
Default GNS 430W vs GNS 480
Sam Spade wrote:
Robert M. Gary wrote:
I can only speak to a 530. In a hold in lieu of PT, it automatically
sequences after one circuit, no SUSPEND. When you go into a missed
approach hold it does go into SUSPEND and remains there "forever" until
you decide to leave the hold.
Are we speaking of the same thing? In the 480 you tell it to hold, give
it the turn direction, leg length etc and it flys the hold. I've not
seen that in any other GPS product.
The positive course guidance in a 400/500W is dependent upon having a
roll steering autopilot. I doubt your 182 has a roll steering
autopilot.
Yes, the 182T does. Its not even 1 year old yet. It has a nice KAP140
autopilot. Totally hands off. Flys a full ILS down to minimums w/o
touching it. The only thing it doesn't do is fly the hold.
-Robert
Old January 3rd 07, 02:11 AM posted to rec.aviation.ifr
Sam Spade
No, I think you are speaking of holds not in the database. Sounds like
the 480 does a nice job of that. I am speaking of charted approach
chart holds.
autopilot.
It will most likely fly the hold with a W mod.
Old January 3rd 07, 02:30 AM posted to rec.aviation.ifr
Robert M. Gary
chart holds.
Did this change in the 430 with WAAS? From my teaching in the 430 and
G1000 when you cross the holding fix it just goes into suspend mode
(with a suggested entry procedure). The 480 actually figures the entry
procedure and flys it, you never touch the yoke. Does the 430 WAAS unit
fly the entry procedure?
-Robert
Old January 3rd 07, 03:22 AM posted to rec.aviation.ifr
Peter R.
"Robert M. Gary" wrote:
Does the 430 WAAS unit fly the entry procedure?
If the sim for the GNS430W is to be believed, yes it will, assuming of
course it is coupled with an appropriate AP.
Peter
Old January 3rd 07, 09:33 AM posted to rec.aviation.ifr
Sam Spade
With a roll steering autopilot it will.
Old January 3rd 07, 05:04 PM posted to rec.aviation.ifr
Robert M. Gary
That's a motivation to upgrade the G1000 to WAAS. However, I just read
somewhere that the rumor is that the WAAS G1000 systems will not drive
VNAV to the KAP140. So you won't be able to fly fully coupled VNAV
approachs with the KAP140 (even though you can fly a fully coupled ILS
with it). Not sure what the techical limitation is but Garmin's
solution is to upgrade to their Garmin autopilot (which I don't believe
is certified for many applications yet). However, that will fix the
issue of having to set the barometer 3 times (G1000, KAP140, standby
alttitude) since the Garmin autopilot will take the baro setting from
the G1000 directly.
-Robert
Old January 3rd 07, 07:17 PM posted to rec.aviation.ifr
Sam Spade
with it).
If an LNAV approach has VNAV minimums will you be able to use DA or will
you have to use the MDA concept?
Old January 3rd 07, 02:25 PM posted to rec.aviation.ifr
Roy N5804F
Peter
I am really interested to hear how many of us have actually been asked to
fly a Holding pattern by ATC in the recent past ?
Roy
Old January 3rd 07, 02:38 PM posted to rec.aviation.ifr
Peter R.
It is more common than you think, assuming you routinely fly IFR to
uncontrolled airports (at least in the Northeast US). While certainly not
a lot, I have been asked twice over the year I was commuting to Dunkirk,
NY, to momentarily hold due to another IFR aircraft ahead of me flying the
approach.
Additionally, on frequency I have heard holding instructions go out to
every aircraft (air carriers and GA alike) approaching the big three NY
airports when a line of t-storms was about to move through.
The point being that the more you fly IFR, the more likely you will
encounter a request to hold.
Peter
Old January 3rd 07, 03:14 PM posted to rec.aviation.ifr
Sam Spade
Airliners sometimes hold for an hour, or more on STARS serving JFK, EWR,
and LGA. Holding west of Boston is very common, too.
