I think he's referring to Art Mattson's high performance take-off procedure
for Cherokees. See http://www.pipermods.com/ "Stephen N Mills" wrote in message ... I guess I missed something.... What is "Mattisons procedure"? Steve Mills On Tue, 02 Jan 2007 21:13:28 -0400, Dave wrote: In the FWIW department.... Been "Playing" ....carefully.. Not very scientific, but thought I would share this anyway.... Our Warrior was light, 1/2 fuel, me alone (165 lbs) 60lbs in baggage ... -6 Deg C, Did some takeoffs using Mattisons procedure without the rolling start... 45 mph, dropped 2 notches, counted "thousand 1, thousand 2", and hauled back.. a LOT! (but not all the way, kind of timid yet) When the flaps went down, the plane instantly popped up on the struts... When I rotated, the plane literally leaped off the rny! I had 50 AGL in a few seconds.. The deck angle was scary!- but it kept on going.... NO WAY would I have been able to do that before.. Art says that if you do it properly, the stall warning horn should emit a short beep at rotation, and the yoke should come ALL the way back.. BTW, at this load, temp and 3000 ft agl, I was stalling at 40 knts indicated with 40 degs of flap. Anyone have any formula to work out the calibrated AS at that angle? The POH (PA-28 151) leaves a bit to be desired here.. Interesting day.... ![]() Dave |
On Wed, 03 Jan 2007 14:24:15 GMT, "Steve Foley"
wrote in j0Pmh.2$5g.0@trndny01: I think he's referring to Art Mattson's high performance take-off procedure for Cherokees. See http://www.pipermods.com/ Dave must have some information additional to that provided on the web site, as is see no mention of moving the elevator to the stop at rotation: http://www.pipermods.com/shortfield.htm Short Field Takeoff Procedure Getting the best short field performance out of your Cherokee begins before reaching the end of the runway. This requires leaning to slightly rich of max. power at your runup. This is achieved by leaning to maximum static RPM and then richening the mixture slightly as you would at your cruise altitude. (If you plan to cruise more than 2000 AGL, you will need to further richen the mixture.) Never stop on the end of the runway. After you are cleared for takeoff, make a rolling turn onto the runway-no flaps. When you reach an angle of 45 deg. to the runway, start accelerating so that by the time you have completed your turn, you are at full throttle. Accelerate to your predetermined rotation speed (this is between 45 and 60 mph depending on mods, temperature and loading), at this speed, pull in 2 notches of flaps, count 1.... 2 and rotate! You can take your first notch of flaps off fairly soon after gaining some speed and take the second one out as you continue to gain speed. This procedure is like adding 300ft+ to the runway which reduces your "pucker factor" for clearing obstacles. Practice on a longer than needed runway and get comfortable with it before doing it on a short field. I use this procedure on all takeoffs regardless of runway length, as I go into short grass strips regularly and want the procedure to be second nature. By using ths [sic] procedure, you will quickly discover that your Cherokee is capable of more than you realized. For a first-hand account of how well this works, read Jim Cavanaugh's article from Pipers Magazine. |
From Jim Cavanaugh's article from Pipers Magazine: (noted at the end of your
post) "His technique is to accelerate the airplane to 45mph, quickly pull in two notches of flap, count to two and pull the wheel back into your stomach. " "Larry Dighera" wrote in message ... On Wed, 03 Jan 2007 14:24:15 GMT, "Steve Foley" wrote in j0Pmh.2$5g.0@trndny01: I think he's referring to Art Mattson's high performance take-off procedure for Cherokees. See http://www.pipermods.com/ Dave must have some information additional to that provided on the web site, as is see no mention of moving the elevator to the stop at rotation: http://www.pipermods.com/shortfield.htm Short Field Takeoff Procedure Getting the best short field performance out of your Cherokee begins before reaching the end of the runway. This requires leaning to slightly rich of max. power at your runup. This is achieved by leaning to maximum static RPM and then richening the mixture slightly as you would at your cruise altitude. (If you plan to cruise more than 2000 AGL, you will need to further richen the mixture.) Never stop on the end of the runway. After you are cleared for takeoff, make a rolling turn onto the runway-no flaps. When you reach an angle of 45 deg. to the runway, start accelerating so that by the time you have completed your turn, you are at full throttle. Accelerate to your predetermined rotation speed (this is between 45 and 60 mph depending on mods, temperature and loading), at this speed, pull in 2 notches of flaps, count 1.... 2 and rotate! You can take your first notch of flaps off fairly soon after gaining some speed and take the second one out as you continue to gain speed. This procedure is like adding 300ft+ to the runway which reduces your "pucker factor" for clearing obstacles. Practice on a longer than needed runway and get comfortable with it before doing it on a short field. I use this procedure on all takeoffs regardless of runway length, as I go into short grass strips regularly and want the procedure to be second nature. By using ths [sic] procedure, you will quickly discover that your Cherokee is capable of more than you realized. For a first-hand account of how well this works, read Jim Cavanaugh's article from Pipers Magazine. |
On Wed, 03 Jan 2007 15:39:56 GMT, "Steve Foley"
wrote in g7Qmh.5$Jf.4@trndny03: From Jim Cavanaugh's article from Pipers Magazine: (noted at the end of your post) "His technique is to accelerate the airplane to 45mph, quickly pull in two notches of flap, count to two and pull the wheel back into your stomach. " I'd be more comfortable hauling back on the yoke like that if it were possible to do try it at altitude. But I suppose, if you could perform slow flight at 45 MPH, it would work fine in ground effect for takeoff. I wonder what it would take to produce new performance graphs for modified aircraft? It would seem the FAA would require them to certify the modification. http://www.pipermods.com/SEATBELT.html Technique by Mattson The aircraft was not light with the fuel, Art and myself on board. We held the door open until the runup was completed and only buttoned up when we were ready to roll. I had asked Art to fly left seat and show me his technique for a maximum performance takeoff. I contented myself to sit there and watch his movements and the airspeed indicator as he advanced the throttle and dance the pedals to keep us lined up and it was quite a show. With the VG’s, airflow over the Cherokees wings is greatly enhanced. We had watched a video tape made by a physics teacher at Embry Riddle, showing the stalled condition of the wing at various stations at low airspeeds. I don’t know if Art has tuft tested the wing with his VG’s installed, but it felt like angle of attack had been taken out of the equation when he rotated and lifted off. His technique is to accelerate the airplane to 45mph, quickly pull in two notches of flap, count to two and pull the wheel back into your stomach. It is a very daunting procedure from where I was setting. But it worked! I couldn’t believe the deck angle as we sprang off the ground. It was more like a Maule than a Cherokee. The entire takeoff run had just been about 400-450 feet, and I would estimate that it was just a second or two to 50 feet AGL. The book says the roll alone would have taken 800 feet on a standard day, and another 900 feet to clear the 50 foot obstacle. We had to have been flying out of another book! I quickly calculated that the fuel, Art and I weighed in at 570 lbs., roughly 280 lbs. less than the normal useful load, but still it was about an 8,000 feet D.A. day! Art held the climb for a bit, then let the airplane accelerate to 70mph and he raised a notch of flaps, then at 80 mph indicated he cleaned up the airplane and we began to fly normally. The rest of the climbout was at 85 mph and about 500 fpm. Once at 3,000 feet MSL, we poured the coals to her and waited as the noise level and airspeed raced each other to the max. It takes a lot of time to overcome the inherent drag of an airframe, particularly one that is not cleaned up much. Eventually, though, we settled in on a steady 139 mph TAS and a veritable symphony of wind noise and engine roar. A passing thought was that designers who don’t expect their airplanes to go fast don’t do much to cancel out wind noise. Art needs one more STC! Coming back to the airport, Art demonstrated a short field landing and with an approach at 70 mph, cutting back the throttle over the fence, we quickly dropped in and touched down at about 47 mph, about 8 mph lower than the book. With judicious braking, not heavy, we were able to stop in about 400 feet. The Novice’s Turn We next taxied back for my turn and from the right side I tried to reproduce Art’s takeoff. It wasn’t bad, but I experienced what a lot of his customers do: it doesn’t feel natural to be so abrupt in a Cherokee. Art had told me of some of his customers complaining that their takeoff performance doesn’t match his. He has questioned them and flown with some and determined that most of the performance complaints is due to their lack of aggression with the controls. "They’ve got to trust the numbers," he told me, so I did. Still, it felt funny forcing the airplane off the ground when all you’ve ever heard and read about Cherokees tells you it can’t be done. I shot two takeoffs like this before Art had me stop and let him out. He wanted me to experience what the airplane would do when it was light. And it was dramatic! It may be difficult for some of you to get excited about a dowdy old Cherokee. Its reputation is that it is about as exciting as a wild night in Mayberry with Aunt Bea. True, it will never be a Cessna 185 or a Maule MX-7, but performance, as is thrill, is relative. I shot three takeoffs solo and each was a little shorter and a little steeper. Flying alone is simply fun. I have a tendency to be slightly distracted when someone is with me, whether in an airplane or on the golf course…anyplace where focus has an effect on your personal performance level. When we stopped for lunch, Art showed me the propeller that had been on the airplane when Vince brought it to him. It was so far out of tolerance that you didn’t even have to use a measuring device to see it. The blades had been dressed so many times that they were very thin and merely taking off and cruising had caused them to be bent forward. I put a tape measure on it and one blade was an eighth of an inch longer than the other, and the blade width was different on each end. Sensenich has definite parameters for their props and this one just needed a coat of paint to be a permanent wall decoration. Gap Seal Installation After lunch, Art , his son Scott and I cleaned the wings for the installation of the gap seals. Vince had asked for the seals and Art thought it would be a good time for me to fly the airplane before and after. We didn’t have time to do a complete installation, since the application time takes about an hour per control, so I had to fly it with just the aileron gaps sealed. Art said that this is the most important of the three. Flying an airplane on the same day is a great way to get before and after impressions. I was fortunate to be in the right place at the right time. By this time, the fuel was down to about one-third, but it was up to 96 degrees. Power up to 45…two notches…count to two and pull. By now I was getting fairly comfortable with the routine and noticed almost immediately how much smoother the roll force was. They just felt more solid with the gap seals. I flew wing wobbles up to 3000 feet and left the throttle in all the way to see what happened to the top end. Again I had to wait about 5 minutes. This seems like a long time in cruise mode, but the result was an increase over the earlier reading by 2 mph. Allowing for a few bumps, the needle on the True Airspeed Indicator vacillated around 141 mph for so long that I considered this new speed to be valid. I headed back to the airport and decided to shoot one more takeoff. It was too hot for any more of this foolishness, This time I got cocky. I was feeling good and when I pulled her off I really pulled her off. It was the only time I got the stall horn to honk and when I got back, Art was grinning ear to ear. I guess I had nailed one! Art and his assistant Will had been installing wheelpant on Art’s personal airplane and it was time to take it up. This airplane has always been slower than his first Cherokee. Whether rigging, tools left by the builders or something else, it just hasn’t been able to produce the good numbers. Art reasons it might be the design of the aileron skins, which have the stiffening beads fabricated outward, as opposed to the inward beads of his original plane. At least the performance increase from stock to modified is the same in both, which demonstrates the effectiveness of the mods, but Art has the speed bug now and he can’t help but be disappointed. The airplane has the prop mod, gap seals and VG’s and that is about it at this point. He has decided to keep the engine in the 150 hp configuration to aid in evaluating the different mods he has planned. He admits that he had been bitten by the speed bug and went all out for speed and not all his customers are interested in an engine mod. He needs to know what each mod will do with a standard engine. Difference in Takeoff Performance Naturally, the takeoff performance is different. It was still light years ahead of a standard Cherokee, because of the VG’s. With a stall speed lowered by 8mph, you’re going to see a difference. At top end, the airplane can achieve 135 mph, and normally cruises at 120mph and I could feel Art’s frustration, since his first airplane had broken 180 mph over a dozen times under Sea Level conditions. On a more pragmatic level, I realize that this is a test airplane and that each mod will generate a performance change. Each of these will then be documented against a known value. The speed will come later, as will the increased horsepower, I’m sure. I asked Art to shoot a couple of takeoffs for the camera, and the day was over. |
... On Wed, 03 Jan 2007 15:39:56 GMT, "Steve Foley" wrote in g7Qmh.5$Jf.4@trndny03: I wonder what it would take to produce new performance graphs for modified aircraft? It would seem the FAA would require them to certify the modification. They are not required for engine upgrades. That has certainly affected the performance of my plane. I increased the HP from 150 to 160 and put on a cruise prop (58" to 62"). I get similar takeoff performance as before, but cruise much faster (relatively - it's still a fat-wing Cherokee) |
Hi Larry!
Was not quoting Art here, although he mentioned to me verbally that he has used full back yoke to rotate, especially with the heavier engined cherokees and the "full fuel, 2 heavy front seat Pilot/pax and no baggage" situation.... I had it well back, but have not hit the stop yet, and may never. Apparently, if done to soon, the aircraft simply won't lift... Although having spoken to several about this mod, I was only slightly prepared for the result.. ![]() Now, remember, it was cold, slight head wind, and I was light. Brakes held , full RPM, and let go.... I was well in the air at the 500 ft marker.. The deck angle was ...umm... "interesting" . And the little Warrior just wanted to keep going up... no wobbles, no stall warning, no buffeting, just the most rapid "up" I have ever experienced with 150 horses... Over a year ago. I got an E-mail from a straight wing Cherokee pilot who indicated that these two mods are " the FIRST ones to spend money on " when it comes to the Cherokees. He said he lowered his stall speed by 7 mph. I was doing 45 deg "S" turns at 45 knts indicated (at altitude) easily. Lots of protest from the horn, but solid, no buffeting.... We have it at 4 knot difference so far, maybe 5.. One of my partners frequents a 1600 ft strip near his parents home. We thought the extra margin would be a good investment. More testing to come.. Will post results here if anyone interested. Cheers! Dave ... On Wed, 03 Jan 2007 15:25:04 GMT, Larry Dighera wrote: On Wed, 03 Jan 2007 14:24:15 GMT, "Steve Foley" wrote in j0Pmh.2$5g.0@trndny01: I think he's referring to Art Mattson's high performance take-off procedure for Cherokees. See http://www.pipermods.com/ Dave must have some information additional to that provided on the web site, as is see no mention of moving the elevator to the stop at rotation: http://www.pipermods.com/shortfield.htm Short Field Takeoff Procedure Getting the best short field performance out of your Cherokee begins before reaching the end of the runway. This requires leaning to slightly rich of max. power at your runup. This is achieved by leaning to maximum static RPM and then richening the mixture slightly as you would at your cruise altitude. (If you plan to cruise more than 2000 AGL, you will need to further richen the mixture.) Never stop on the end of the runway. After you are cleared for takeoff, make a rolling turn onto the runway-no flaps. When you reach an angle of 45 deg. to the runway, start accelerating so that by the time you have completed your turn, you are at full throttle. Accelerate to your predetermined rotation speed (this is between 45 and 60 mph depending on mods, temperature and loading), at this speed, pull in 2 notches of flaps, count 1.... 2 and rotate! You can take your first notch of flaps off fairly soon after gaining some speed and take the second one out as you continue to gain speed. This procedure is like adding 300ft+ to the runway which reduces your "pucker factor" for clearing obstacles. Practice on a longer than needed runway and get comfortable with it before doing it on a short field. I use this procedure on all takeoffs regardless of runway length, as I go into short grass strips regularly and want the procedure to be second nature. By using ths [sic] procedure, you will quickly discover that your Cherokee is capable of more than you realized. For a first-hand account of how well this works, read Jim Cavanaugh's article from Pipers Magazine. |
Now you caught my interest.
What were the first two mods again? VGs and gap seals? KC PA28-180 Cherokee Challenger |
Hi Kevin,
Yes, gap seals and the VG's.. We also have the RMD upswept tips and the K2U wing root fairings, and they all contribute.. Reports from the customers were what really convinced us, Art Mattison is more conservative, almost too modest about any claims.... The fairings seemed to increase the pitch authority in the flare/rotation and decreased the wind noise in the cabin, the tips helped the aileron response, adding the gap seals REALLY increased the aileron response.. Other make gap seals would probably do the same, but we could not use them because of them freezing (!) in our climate. The Tape seals are practically invisible on our new (very) white paint. All this is low speed handling and performance, no change in cruise or top speed noted, at least no noticible change... Kevin, seriously, we changed a good handling plane into a great handling plane, with NO change in the beneign stall characteristics of the Warrior. With practice, no gusts, I can touch down with the stall horn screaming, indicated 40 knots. (Calibrated speed is actually higher ) Hard to believe that 8 little peices of bent aluminum can do that, but....we seem to be able to validate the articles quoted above.. We are going to try (at altitude) power on stalls next, but I need to get my partner back on board (he is 200 lbs), fuel to tabs, and the whiz wheel to correct for DA. (this is the load we used to take out "before" numbers with) We have also been told the "Full flap go around" performance is much better, the flaps can be raised to 30 deg right after application of power... We will try this next, at alt 1st of course... ![]() Dave On Thu, 04 Jan 2007 00:53:57 GMT, Kevin Clarke wrote: Now you caught my interest. What were the first two mods again? VGs and gap seals? KC PA28-180 Cherokee Challenger |
On Wed, 03 Jan 2007 20:35:48 -0400, Dave
wrote in : Was not quoting Art here, although he mentioned to me verbally that he has used full back yoke to rotate, especially with the heavier engined cherokees and the "full fuel, 2 heavy front seat Pilot/pax and no baggage" situation.... So the forward CG required more aggressive elevator. I had it well back, but have not hit the stop yet, and may never. Apparently, if done to soon, the aircraft simply won't lift... The aggressive application of elevator reduces airspeed below stall speed I suppose. Although having spoken to several about this mod, I was only slightly prepared for the result.. ![]() Now, remember, it was cold, slight head wind, and I was light. Brakes held , full RPM, and let go.... I was well in the air at the 500 ft marker.. That's impressive. The information here http://www.planeandpilotmag.com/content/specs/2006/piper_cherokee140.html indicates that 800' is the book value. That works out to about a 38% performance increase. The deck angle was ...umm... "interesting" . You mean you should have been wearing a parachute to comply with 91.307(c)(2)? :-) And the little Warrior just wanted to keep going up... no wobbles, no stall warning, no buffeting, just the most rapid "up" I have ever experienced with 150 horses... Gap seals help too. Over a year ago. I got an E-mail from a straight wing Cherokee pilot who indicated that these two mods are " the FIRST ones to spend money on " when it comes to the Cherokees. He said he lowered his stall speed by 7 mph. I was doing 45 deg "S" turns at 45 knts indicated (at altitude) easily. Lots of protest from the horn, but solid, no buffeting.... Cherokees were designed with a laminar flow airfoil, but the rivets and any chipped paint, bugs and irregularities tend to cause premature airflow separation. Apparently the VGs overcome that to some extent. We have it at 4 knot difference so far, maybe 5.. One of my partners frequents a 1600 ft strip near his parents home. We thought the extra margin would be a good investment. More testing to come.. Will post results here if anyone interested. I'm interested. I'm planning on grading a runway on an 80 acre parcel if my offer is accepted. This parcel only permits about a 1,500' length with some tall oaks in a ravine at one end, so anything that reduces takeoff ground run is going to be installed. I'm hoping to find a nice PA28-236, so keep us posted. |
On Thu, 04 Jan 2007 01:35:29 GMT, Larry Dighera
wrote: So the forward CG required more aggressive elevator. I believe so Larry....yes.... I had it well back, but have not hit the stop yet, and may never. Apparently, if done to soon, the aircraft simply won't lift... The aggressive application of elevator reduces airspeed below stall speed I suppose. Hmmm... I don't think so.. At, say 50 mph, a large deflection is needed to produce any solid response at that speed... The aircraft continues to accelerate with this deflection, and would continue to "fly off" the rny, but the TO distance would be longer. Getting "light" on the wheels earlier helps a lot on soft/grass, and getting the wheels off into ground effect early helps it even more. On grass runways here, our plane seems to struggle to accelerate in the 50 mph to 65 mph range against the drag of grass, which makes sense. Getting everything out of the grass sooner seems to make a big difference... I was well in the air at the 500 ft marker.. That's impressive. The information here http://www.planeandpilotmag.com/content/specs/2006/piper_cherokee140.html indicates that 800' is the book value. That works out to about a 38% performance increase. I am guessing that would be at standard DA. We were light, 7 knt wind at 10 deg off rny heading, and -6 C deg. Our POH gives us 1065 ft at gross, which we can usually beat anytime, unless it is a hot day. I suspect we will improve the "book"by 25% using the rolling start procedure, maybe more... The deck angle was ...umm... "interesting" . You mean you should have been wearing a parachute to comply with 91.307(c)(2)? :-) Hehe...don't know how much help it would be at 10 ft AGL.. ![]() And the little Warrior just wanted to keep going up... no wobbles, no stall warning, no buffeting, just the most rapid "up" I have ever experienced with 150 horses... Gap seals help too. Absolutely... Cherokees were designed with a laminar flow airfoil, but the rivets and any chipped paint, bugs and irregularities tend to cause premature airflow separation. Apparently the VGs overcome that to some extent. According to Art, the Cherokee wing has a very agressive washout twist. (it does). At high angles of attack, the inner portion of the wing (inboard of the tanks) stops producing lift LONG before the wing stalls. The VG'S "stick" the airflow to the wing and get it producing lift at this angle of attack. It is like adding 30 sq ft of wing in this condition/attitude. (The VG's, 4 on each side, are placed ONLY on this portion of the wing) I'm interested. I'm planning on grading a runway on an 80 acre parcel if my offer is accepted. NICE! ![]() This parcel only permits about a 1,500' length with some tall oaks in a ravine at one end, so anything that reduces takeoff ground run is going to be installed. I'm hoping to find a nice PA28-236, so keep us posted. Will do. The 236 will haul a full load away from our light Warrior. Good choice... Check out the Cheroke pilots group, if there is a good one anywhere, someone there probably knows about it... Jay is a member, and if I have my numbers correct, he has a 236. (Pathfinder?) Dave |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
knowledge test results coming back to haunt you | chris priest | Piloting | 51 | December 8th 04 05:33 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
FAA Knowledge Test Results | Richard Moore | Instrument Flight Rules | 4 | October 12th 03 07:10 AM |
FAA Knowledge Test Results | Richard Moore | Simulators | 3 | October 12th 03 04:48 AM |
