Oil pressure problem
Old January 4th 07, 12:04 AM posted to rec.aviation.piloting
Aluckyguess
Default Oil pressure problem
"Newps" wrote in message
Aluckyguess wrote:
I have a Bonanza V35 with a IO 470.
So you have an N35 or P35, a V35 has an IO520.
Its an N model
Before and after engine overhaul the oil
pressure after the engine warms up goes just into the red. They have
tried turning the pressure up but this seems to only make the pressure go
up when cold. If the temperature outside is real cool the pressure goes
over 200 psi. The engine builder said its in spec. I think there is a
problem somewhere. I want the oil pressure to run in the green. Does
anybody have any ideas on what could be causing this. I'm afraid its
going to blow the gage out one cold morning.
How do you know the gauge is correct? Check that first.
Old January 4th 07, 12:16 AM posted to rec.aviation.piloting
Sounds like the relief valve is sticking. That'll cause low oil
pressure when hot and high when cold.
Dan
Old January 4th 07, 02:12 AM posted to rec.aviation.piloting
Aluckyguess
ps.com...
go
goes
Dan
I will ask the mechanic about this. I know they have replaced the oil pump
and a few other things before I bought it.
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 10:30 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
