Morgans wrote:
This is my 1st post, just found you guys today. I'm located in Central Mississippi, flying PA-28-180. I'm interested in moving up to the new Garmin 496, I would appreciate any thoughts. Check your settings, and make sure you are posting using plain text for newsgroups, instead of HTML. Morgans, I don't quiet understand how to check to see if I am using plain text or HTML. Remember I am a pilot not a computer expert. I am open to learn, though. Everything looks finr on my end. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200701/1 |
"Cherokee via AviationKB.com" u30624@uwe wrote in message
news:6bc204bd0ed5c@uwe... Check your settings, and make sure you are posting using plain text for newsgroups, instead of HTML. Morgans, I don't quiet understand how to check to see if I am using plain text or HTML. Remember I am a pilot not a computer expert. I am open to learn, though. Everything looks finr on my end. You *are* using plain text. It just happens to be set to "UTF-8" encoding, which in Outlook Express causes the message to be displayed with a different font. This makes Jim think you posted in HTML (since he's only looking at how the message looks, rather than paying attention to the actual format of the message). You probably don't have control over the posting format anyway, since you're using a web site to post to the newsgroup. Personally, I think that's a bad idea, but some people have no direct access to an NNTP server. Perhaps you're one of these people. In any case, in this situation I don't see anything about your use of a web site instead of a newsreader that is causing actual problems for the rest of us. In other words, don't worry about it. ![]() Pete |
![]() "Peter Duniho" wrote You probably don't have control over the posting format anyway, since you're using a web site to post to the newsgroup. Personally, I think that's a bad idea, but some people have no direct access to an NNTP server. Perhaps you're one of these people. In any case, in this situation I don't see anything about your use of a web site instead of a newsreader that is causing actual problems for the rest of us. In other words, don't worry about it. ![]() You are right, I didn't check. To me, his message is readable, but id about 25% smaller print, which makes it hard for my farsighted eyes to see. Is there a way to make it larger? I'm no computer geek, either (as you guessed) so I don't know. -- Jim in NC |
"Morgans" wrote in message
... You are right, I didn't check. To me, his message is readable, but id about 25% smaller print, which makes it hard for my farsighted eyes to see. Is there a way to make it larger? I'm no computer geek, either (as you guessed) so I don't know. Yes. In the Tools/Options... dialog, click on the "Read" tab, then the "Fonts" button at the bottom. In the big list, click on "Unicode" and then set the font to whatever suits you. You may want to set the font for both "UTF-7" and "UTF-8" encodings, as long as you're there (you can select the encodings with the "Encodings" drop-down list box, near the bottom of that dialog). You may find that you prefer to set the both the "Proportional" and "Fixed-width" fonts to a font that's actually fixed-width. For example, "Courier New" or "Lucida Console". I don't see any point in reading any post on Usenet with a proportional-spaced font, since no post will depend on have a proportional-spaced font, but some may only look correct with a fixed-width. On the other hand, some people find proportional-spaced fonts easier to read, and may not care about "ASCII graphics" looking right. If you're such a person, you may find that you prefer a proportional-spaced font for both choices. Pete |
text or HTML. You are posting through a web interface (AviationKB.com). THat is why it is coming through as HTML. Web interfaces tend to do that (among other things). I don't know if you are aware, but this newsgroup does -not- belong to AviationKB.com. It is completely independent, and is best accessed through a newsreader. Outlook is one and comes with windows. There are better ones. You set it up similar to an Email client, and the result is =much= easier, and you aren't beholden to a web site. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Jose wrote:
Morgans, I don't quiet understand how to check to see if I am using plain text or HTML. You are posting through a web interface (AviationKB.com). THat is why it is coming through as HTML. Web interfaces tend to do that (among other things). I don't know if you are aware, but this newsgroup does -not- belong to AviationKB.com. It is completely independent, and is best accessed through a newsreader. Outlook is one and comes with windows. There are better ones. You set it up similar to an Email client, and the result is =much= easier, and you aren't beholden to a web site. Jose Jose, how do I go about setting up thru a newsreader, to post and recieve. I would appreciate any help -- Message posted via http://www.aviationkb.com |
news:6bcf152d11407@uwe... Jose, how do I go about setting up thru a newsreader, to post and recieve. I would appreciate any help I'm not Jose, but I'll tell you that it depends on your ISP. You may or may not have access to Usenet via a news server (a server that supports NNTP, the protocol used to get Usenet data). Generally speaking, whatever news reader you use will have a way to add a news server account. Your ISP will have to tell you the name of your news server, and the user ID and password (if required...it usually is) for the server. The user ID and password is often the same as your email user ID and password. You enter this information for the new account. At that point, the news reader will require you to download a list of the newsgroups it carries. From that list, you can select newsgroups you want to read. To read this one, select "rec.aviation.piloting". There is, of course, a lot more you can do with a news reader. One popular feature is the "kill file" (implemented in a variety of ways in different news readers), that you can use to filter out particular threads, messages, or even individuals. One of the biggest advantages IMHO over a web interface is that with a news reader, you download all the new messages at once, and they are stored locally. Browsing through the newsgroup is much faster and easier, and doesn't involve any overhead of sending lots of data back and forth between you and the web site (and in fact, once the messages are downloaded, you don't even need to be connected to the Internet until you want to download again and/or post new messages yourself). Commonly used news readers on Windows include Outlook Express, Agent, Free Agent (a free version of Agent, with fewer features), 40titude, and Xnews. There are a number of other news readers available on other operating systems as well. I'll also reiterate that while I agree with Jose that using a news reader is better than using a web interface, a) not everyone agrees with us, and b) in spite of what Jose says, you are not actually posting in HTML and aren't really causing a real problem for anyone. There are other reasons to not use a web interface, but your posts coming across as HTML isn't one of them, since that's not actually happening. Pete |
would appreciate any help Here's a page I recently wrote for our flying club which might help: http://www.flying20club.org/newsgroups You'll need to know a few pieces of data from your ISP, like the name of their news server. That might be available on their web site, or from their tech support line. Let me know if this works for you, or you'd like more help. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Garmin 530 WAAS? | Al G | Instrument Flight Rules | 53 | November 21st 06 11:30 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
