Confusion about when it's my navigation, and when it's ATC
Old January 4th 07, 10:15 PM posted to rec.aviation.ifr
Mxsmanic
Default Confusion about when it's my navigation, and when it's ATC
A Guy Called Tyketto writes:
Not often. For the most, visual approaches are used over ILS
approaches. When cleared for the visual approach, you won't be using
autoland, as you won't be on an ILS approach, regardless of if you join
the localizer and track it. You're still on the visual approach.
Yes, from a regulatory standpoint. But I can still configure for
autoland. It looks like any other landing from the tower, heh heh.
Anyway, the usual reason for this is that I'm working on the systems
and procedures, and not on the actual flying of the aircraft. If I
want to practice flying it, I set up a different flight. Sometimes I
just fly offline for practice in flying skills, since I don't need ATC
for that. Exercises like flying holds by hand or by autopilot, touch
and go landings, etc. I do this more in the Baron than in the 737.
Old January 5th 07, 12:54 AM posted to rec.aviation.ifr
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I'd hate to see what would happen if tower tells you that you
have a 40 or 50kt overtake on the traffic you're following, and to
S-turn. Kills your autoland. If you want the realism, you should and
fly the approach and land, and use your instruments when you need them.
Should you get the helmet and can't see them, you would be screwed...
royally.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
iD8DBQFFnaHYyBkZmuMZ8L8RAj7oAJ4+6uimAAwC0MsrBciICf cc2pI6bwCeJFBJ
GqSi/+r/pNBg5ZPYWENsT+0=
=X5cu
-----END PGP SIGNATURE-----
Old January 5th 07, 08:25 AM posted to rec.aviation.ifr
Mxsmanic
All you have to do is pull a switch and take over.
If you want the realism, you should and fly the approach and land,
Yes, in principle. But if I'm practicing the systems and automation,
I use those. If I'm offline, I can just stop the simulation when I've
covered the part I want to practice, and then go back and do it again.
If I'm online, I'm required to land, as it is bad form to simply
disappear from the controller's scope with no explanation. So I may
autoland, both for the practice with automation and to conform to the
requirement to land, given that online simulation is supposed to be
like real life.
Old January 5th 07, 10:00 PM posted to rec.aviation.ifr
Sam Spade
royally.
You can't S-turn at busy airline airports very often.
Old January 6th 07, 12:08 AM posted to rec.aviation.ifr
Hash: SHA1
royally.
Depending. It's done commonly at LAS on the 25s. I agree, it
isn't done often, but it is done.
BL.
iD8DBQFFnuhkyBkZmuMZ8L8RAqRjAKCVCZuS7s8bwMZTjEcmnR UtPhX90gCgqs4b
9/Fr7n/tJZX3uUgNjs6UQrs=
=+R5B
Old January 6th 07, 02:20 AM posted to rec.aviation.ifr
Sam Spade
Hash: SHA1
royally.
I guess we agree?
