![]() Mxsmanic wrote: How do you know? Plenty of people thought they knew it well enough in the simulator. And? And maybe you are wrong as well. Until you actually do "instrument flight" in a real airplane with real clouds, you wouldn't know. |
On 4 Jan 2007 14:51:28 -0800
"bdl" wrote: Mxsmanic wrote: How do you know? Plenty of people thought they knew it well enough in the simulator. And? And maybe you are wrong as well. Until you actually do "instrument flight" in a real airplane with real clouds, you wouldn't know. When I was doing my initial training for my private, I was lucky enough to have the opportunity to do a flight to 10,000 ft with a CFII during minimum VFR (just over 3 miles visibility, unlimited ceiling) conditions due to mist. With the slant to see the ground at nearly 2 miles up, we couldn't see anything around us and were effectively on an IFR flight in contact with Center, though technically in VFR conditions. Even though we had completely smooth conditions at the time, there was a world of difference in realizing your only way out of the white bubble you are floating in is your instruments versus flying in similar conditions in the simulator. Things like the vibration of the engine, the forces the plane exerts in level and banking flight, and the actuality of it cannot be fully replicated in a PC simulator. It was a very eerie experience that would be good for VFR pilots to see for themselves. The hood and the simulator don't replicate the experience well at all. After flying in near actual instrument conditions, it is easy to see where a VFR pilot, even one with simulator experience but without real world experience, could lose control of the plane in short order. Continued VFR flight into instrument conditions is a top cause of accidents according to the Nall report. Throw in some turbulence and some distractions and you have a completely different experience from the safety of a simulator. Doug -- For UNIX, Linux and security articles visit http://SecurityBulletins.com/ |
![]() Doug Spencer wrote: After flying in near actual instrument conditions, it is easy to see where a VFR pilot, even one with simulator experience but without real world experience, could lose control of the plane in short order. Continued VFR flight into instrument conditions is a top cause of accidents according to the Nall report. Throw in some turbulence and some distractions and you have a completely different experience from the safety of a simulator. Exactly my point Dough. I had a similar flight for my night cross-country when doing my PPL (moderate turbulence below 12000, strong winds, snow(!) and of course night). I could see lights below but because of the extreme sideways ground track due to the winds It was all i could do to keep the plane level. I kept wanting to turn it so that the pretty lights below me were traveling in the "right" direction. |
bdl writes:
And maybe you are wrong as well. Until you actually do "instrument flight" in a real airplane with real clouds, you wouldn't know. Maybe. But I've always been quite good at evaluating myself. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: bdl writes: And maybe you are wrong as well. Until you actually do "instrument flight" in a real airplane with real clouds, you wouldn't know. Maybe. But I've always been quite good at evaluating myself. Not having any instrument flight experience you are not qualified to evaluate your instrument flying ability. Just like I'm not qualified to judge my aerobatic ability by being able to loop the 747 in MSFS. |
bdl writes:
Not having any instrument flight experience you are not qualified to evaluate your instrument flying ability. I am qualified to evaluate my ability to handle activities of this type without prior experience, however. The tacit assumption in your post seems to be that everyone is bad at instrument flight by default, and can only become good by doing it in an actual aircraft. I'm not convinced that this is true. Some people are able to fly an aircraft competently under VFR with no prior instruction; they simply happen to be good at that sort of thing. The same may also apply for IFR. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: bdl writes: Not having any instrument flight experience you are not qualified to evaluate your instrument flying ability. I am qualified to evaluate my ability to handle activities of this type without prior experience, however. Which activities would these be? The tacit assumption in your post seems to be that everyone is bad at instrument flight by default, and can only become good by doing it in an actual aircraft. I'm not convinced that this is true. Some people are able to fly an aircraft competently under VFR with no prior instruction; they simply happen to be good at that sort of thing. The same may also apply for IFR. You don't sound to sure. So your position is that there are people that are naturally good at flying, and also naturally good at flying IFR, and that you are one of these enlightened souls because you've got so many hours in a simulator in IFR conditions (albeit at a constant 1-g) and that ability would naturally translate to a real aircraft in real IMC. Oh wait, you did crack up one of your simulated aircraft didn't you. That CFIT you mentioned. |
bdl writes:
Which activities would these be? Activities that involve primarily mental tasks, such as reading instruments, assessing the information gained therefrom, and deciding upon an appropriate course of action. You don't sound to sure. I'm not sure. So your position is that there are people that are naturally good at flying, and also naturally good at flying IFR ... Yes. ... and that you are one of these enlightened souls because you've got so many hours in a simulator in IFR conditions ... I don't know if I'd be good at flying from a physical standpoint. I tend to be uncoordinated at first compared to others, but I learn and improve until I'm often better than average, although it's a long process. I'm good at being precise rather than quick. As for instrument flight, I'm pretty sure I'd be good at that. It's the type of task that I generally do well. ... (albeit at a constant 1-g) and that ability would naturally translate to a real aircraft in real IMC. For instrument flight, yes. For visual flight, less so, although it still would be significant. Oh wait, you did crack up one of your simulated aircraft didn't you. That CFIT you mentioned. I haven't had a crash in quite a while. In general, though, if I crash, it is from an overambitious attempt to land--what pilots call getthereitis. In real life, I am vastly more prudent. My most recent crashes have been due to extremely bad weather--weather I'd never attempt to fly in in real life. On some occasions, I've been lifted 20 feet while 10 feet above the runway, and then slammed back down. I don't see how any pilot could land in conditions like that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: I don't know if I'd be good at flying from a physical standpoint. I tend to be uncoordinated at first compared to others, but I learn and improve until I'm often better than average, although it's a long process. I'm good at being precise rather than quick. IFR flying is a very physical process. It requires you to disregard your senses. Something that is not able to be simulated in your chair at your computer. This has been my point all along. |
Dual glide slope, $95...priceless! | Jack Allison | Owning | 20 | October 22nd 06 03:45 AM |
Priceless Tugs | kojak | Owning | 0 | August 9th 05 10:25 PM |
"Priceless" in Afghanistan | Pechs1 | Naval Aviation | 34 | March 7th 04 06:27 AM |
"Priceless" in Afghanistan | BUFDRVR | Military Aviation | 15 | February 28th 04 04:17 PM |
Priceless in Afganistan | breyfogle | Military Aviation | 18 | February 24th 04 05:54 AM |
