GA is priceless
Old January 5th 07, 10:06 AM posted to rec.aviation.piloting
Mxsmanic
Default GA is priceless
bdl writes:
Not having any instrument flight experience you are not qualified to
evaluate your instrument flying ability.
I am qualified to evaluate my ability to handle activities of this
type without prior experience, however.
The tacit assumption in your post seems to be that everyone is bad at
instrument flight by default, and can only become good by doing it in
an actual aircraft. I'm not convinced that this is true. Some people
are able to fly an aircraft competently under VFR with no prior
instruction; they simply happen to be good at that sort of thing. The
same may also apply for IFR.
  #312
Old January 5th 07, 06:27 PM posted to rec.aviation.piloting
bdl
Mxsmanic wrote:
bdl writes:
Which activities would these be?
You don't sound to sure.
So your position is that there are people that are naturally good at
flying, and also naturally good at flying IFR, and that you are one of
these enlightened souls because you've got so many hours in a simulator
in IFR conditions (albeit at a constant 1-g) and that ability would
naturally translate to a real aircraft in real IMC.
Oh wait, you did crack up one of your simulated aircraft didn't you.
That CFIT you mentioned.
  #313
Old January 5th 07, 08:52 PM posted to rec.aviation.piloting
Mxsmanic
Wolfgang Schwanke writes:
Flying an aircraft level can be done by a 5 year old after 5 minutes
instruction. Take off, landing, and many of the things in between have
to be learnt.
Some people get it right the first time.
  #314
Old January 5th 07, 08:57 PM posted to rec.aviation.piloting
Mxsmanic
bdl writes:
Activities that involve primarily mental tasks, such as reading
instruments, assessing the information gained therefrom, and deciding
upon an appropriate course of action.
I'm not sure.
flying, and also naturally good at flying IFR ...
Yes.
... and that you are one of these enlightened souls because you've
got so many hours in a simulator in IFR conditions ...
I don't know if I'd be good at flying from a physical standpoint. I
tend to be uncoordinated at first compared to others, but I learn and
improve until I'm often better than average, although it's a long
process. I'm good at being precise rather than quick.
As for instrument flight, I'm pretty sure I'd be good at that. It's
the type of task that I generally do well.
... (albeit at a constant 1-g) and that ability would
For instrument flight, yes. For visual flight, less so, although it
still would be significant.
I haven't had a crash in quite a while. In general, though, if I
crash, it is from an overambitious attempt to land--what pilots call
getthereitis. In real life, I am vastly more prudent.
My most recent crashes have been due to extremely bad weather--weather
I'd never attempt to fly in in real life. On some occasions, I've
been lifted 20 feet while 10 feet above the runway, and then slammed
back down. I don't see how any pilot could land in conditions like
that.
  #315
Old January 5th 07, 10:49 PM posted to rec.aviation.piloting
bdl
IFR flying is a very physical process. It requires you to disregard
your senses. Something that is not able to be simulated in your chair
at your computer. This has been my point all along.
  #316
Old January 6th 07, 07:05 AM posted to rec.aviation.piloting
Mxsmanic
bdl writes:
your senses.
These two statements conflict.
  #317
Old January 6th 07, 03:29 PM posted to rec.aviation.piloting
Thomas Borchert
Bdl,
It also requires to be quick, not precise, quite often.
Thomas Borchert (EDDH)
  #318
Old January 6th 07, 04:35 PM posted to rec.aviation.piloting
Mxsmanic
Thomas Borchert writes:
If you have to depend on the speed of your reflexes, you've already
made a mistake.
  #319
Old January 6th 07, 05:39 PM posted to rec.aviation.piloting
Thomas Borchert
Mxsmanic,
made a mistake.
How would you know?
  #320
Old January 6th 07, 08:06 PM posted to rec.aviation.piloting
bdl
Mxsmanic wrote:
bdl writes:
your senses.
Physically draining... That better? If I could put myself in a little
1-G bubble inside the cockpit, IFR flying would be a piece of cake.
See the attitude indicator? Keep it right side up.. (Except when it
fails).
Dual glide slope, $95...priceless! Jack Allison Owning 20 October 22nd 06 03:45 AM
Priceless Tugs kojak Owning 0 August 9th 05 10:25 PM
"Priceless" in Afghanistan Pechs1 Naval Aviation 34 March 7th 04 06:27 AM
"Priceless" in Afghanistan BUFDRVR Military Aviation 15 February 28th 04 04:17 PM
Priceless in Afganistan breyfogle Military Aviation 18 February 24th 04 05:54 AM
