Paul kgyy wrote:
If you want a better feel for what actually goes on than you will ever get via newsgroup, take a couple of United flights and listen to the ATC channel - it can be much more entertaining than the movie at times. A cheaper way is check this out: http://www.liveatc.net/ |
B A R R Y wrote:
Paul kgyy wrote: If you want a better feel for what actually goes on than you will ever get via newsgroup, take a couple of United flights and listen to the ATC channel - it can be much more entertaining than the movie at times. A cheaper way is check this out: http://www.liveatc.net/ I'd add the caveat that the value of listening to tower or TRACON, although, great, does not give the flavor of listening to center sectors adjacent to busy terminal airspace. For instance, all the descent stuff that might include PD clearances will occur on Los Angeles Center frequenices, high and low sectors, not on SoCal frequencies. |
Sam Spade wrote:
I'd add the caveat that the value of listening to tower or TRACON, although, great, does not give the flavor of listening to center sectors adjacent to busy terminal airspace. For instance, all the descent stuff that might include PD clearances will occur on Los Angeles Center frequenices, high and low sectors, not on SoCal frequencies. Not sure if you are assuming that LiveATC.net only carries tower or TRACON frequencies or not, but in case you a LiveATC.net also carries many centner frequencies. As an example, LiveATC.net has many Boston and NY center frequencies. Another point is that LiveATC is made up of volunteers providing scanned frequencies. There are not a lot of western US frequencies on the site due simply to the lack of volunteers offering them. If you know anyone... ![]() -- Peter A LiveATC volunteer feeding KSYR tower and approach. |
Peter R. wrote:
Sam Spade wrote: I'd add the caveat that the value of listening to tower or TRACON, although, great, does not give the flavor of listening to center sectors adjacent to busy terminal airspace. For instance, all the descent stuff that might include PD clearances will occur on Los Angeles Center frequenices, high and low sectors, not on SoCal frequencies. Not sure if you are assuming that LiveATC.net only carries tower or TRACON frequencies or not, but in case you a LiveATC.net also carries many centner frequencies. As an example, LiveATC.net has many Boston and NY center frequencies. Another point is that LiveATC is made up of volunteers providing scanned frequencies. There are not a lot of western US frequencies on the site due simply to the lack of volunteers offering them. If you know anyone... ![]() I missed the center frequencies. To get a good flavor of the east high and low LA frequenices you would need a volunteer in Barstow and one somewhere in the Ontario area. ;-) |
Sam Spade wrote:
I missed the center frequencies. To get a good flavor of the east high and low LA frequenices you would need a volunteer in Barstow and one somewhere in the Ontario area. ;-) Is that where their antenna farms or just the facilities are located? -- Peter |
Peter R. wrote:
Sam Spade wrote: I missed the center frequencies. To get a good flavor of the east high and low LA frequenices you would need a volunteer in Barstow and one somewhere in the Ontario area. ;-) Is that where their antenna farms or just the facilities are located? It would be where the remote transmitter/receivers would be located. (aka "RCO" remote communications outlet.) I am approximating the location of these two RCOs. Stay tuned. |
