#91
![]() Mxsmanic wrote: If your instructor shouts, you need a new instructor. I remember preparing to takeoff from a training hill in a hang glider and when I started running, then wind direction slightly changed and I started hesitating and thought about aborting run. An instructor started shouting "Run, run you bloody stupid f***d!" . And a lot of other unpleasant words in a split second. I ran, took off Ok and landed well. When I came back, I thanked her for saving me from possibly broken arm or leg (no kidding) and unpleasant time spent in hospital, never mind bent aluminium. You have no clue, have you? |
#92
"Mxsmanic" wrote in message
... There are many different possibilities. In the experiment suggested to me, I held the wings level (via the autolevel function of the autopilot), applied full right rudder, and the aircraft yawed and gradually changed heading. The ground track was a segment of a circle (depending on how long I held the rudder). Supposedly MSFS can't do this, but it did. Well, then that conflicts with what another poster said which I believe was that MSFS allowed you to yaw the nose without any heading change. |
#93
When flying IFR with jet aircraft, the pilot has little discretion
unless specifically given by ATC. A usual transmission is, United xxx, descend to 15000, and that's what you do. On rare occasion, it may be a little looser, United xxx descent at pilot's discretion, cross intersection xyz at 15000. If you want a better feel for what actually goes on than you will ever get via newsgroup, take a couple of United flights and listen to the ATC channel - it can be much more entertaining than the movie at times. |
#94
Alexey,
You have no clue, have you? On human interaction and when shouting might be appropriate? No, he doesn't. -- Thomas Borchert (EDDH) |
#95
Paul kgyy wrote:
If you want a better feel for what actually goes on than you will ever get via newsgroup, take a couple of United flights and listen to the ATC channel - it can be much more entertaining than the movie at times. A cheaper way is check this out: http://www.liveatc.net/ |
#96
Mxsmanic wrote:
...and many of them [VATSIM] are pilots or controllers in real life. How do you actually know they are real controllers? Within any endeavor, there's room for a few who do odd things. But I have trouble believing the typical ATC would regularly spend off-hours directing nonpilots in a make-believe IFR environment. If there were many real controllers doing this, you wouldn't have so many misconceptions about IFR, the few rigid rules which are not to be violated, and the essential task of the controller. F-- |
#97
Mxsmanic wrote:
Pilots I know to be honest have agreed that MSFS is useful for training and a reasonable simulation of flight. Pilots I know to be insecure blowhards have insisted that it is neither. I seriously doubt you've ever talked in person to many real pilots. F-- |
#98
Mxsmanic wrote:
No, I think the main reasons are that some pilots depend excessively on physical sensations, and become disoriented without them. In visual flight conditions? You don't know what you're talking about. F-- |
#99
Mxsmanic wrote:
TxSrv writes: For starters, the program doesn't really understand air density. The program tries, but only in MSFS can one maintain a semblance of controllability in a 172 at FL 250. That would probably be a flaw in the specific model. All planes, and various propulsion systems, react in the same way to air density. The program itself could handle this, needing only some specifics from the model file and which it does supply for certain things. Whatever. Of the zillion FS planes out there for download, point me toward a normally-aspirated, piston aircraft, with certificated HP in the model file, and which isn't a real hoot when slewed up into the flight levels. Plus, the mixture control does not react as it should at even 7000. What does it do wrong? The red knobby thingy? Besides doing little but being an on/off switch? I dunno. Regarding rarefied air, I read somewhere on the net it's just the way carburetors work. F-- |
#100
Ross wrote:
It's not a Extra 300 but I had the opportunity years ago to "fly" the American Airlines Fokker F100 at their DFW training center at full motion. I thought that was pretty realistic for this general aviation pilot. Was that full motion simulator running MSFS? That was the software in question. |
