Confusion about when it's my navigation, and when it's ATC
Old January 5th 07, 05:19 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Default Confusion about when it's my navigation, and when it's ATC
B A R R Y wrote:
Paul kgyy wrote:
If you want a better feel for what actually goes on than you will ever
get via newsgroup, take a couple of United flights and listen to the
ATC channel - it can be much more entertaining than the movie at times.
A cheaper way is check this out:
http://www.liveatc.net/
I'd add the caveat that the value of listening to tower or TRACON,
although, great, does not give the flavor of listening to center sectors
adjacent to busy terminal airspace. For instance, all the descent stuff
that might include PD clearances will occur on Los Angeles Center
frequenices, high and low sectors, not on SoCal frequencies.
Old January 5th 07, 05:43 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Peter R.
Not sure if you are assuming that LiveATC.net only carries tower or TRACON
frequencies or not, but in case you a LiveATC.net also carries many
centner frequencies.
As an example, LiveATC.net has many Boston and NY center frequencies.
Another point is that LiveATC is made up of volunteers providing scanned
frequencies. There are not a lot of western US frequencies on the site due
simply to the lack of volunteers offering them. If you know anyone...
Peter
A LiveATC volunteer feeding KSYR tower and approach.
Old January 5th 07, 05:56 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
I missed the center frequencies. To get a good flavor of the east high
and low LA frequenices you would need a volunteer in Barstow and one
somewhere in the Ontario area. ;-)
Old January 5th 07, 06:10 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Peter R.
Is that where their antenna farms or just the facilities are located?
Peter
Old January 5th 07, 06:59 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
It would be where the remote transmitter/receivers would be located.
(aka "RCO" remote communications outlet.)
I am approximating the location of these two RCOs. Stay tuned.
