Confusion about when it's my navigation, and when it's ATC
Old January 5th 07, 05:39 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Default Confusion about when it's my navigation, and when it's ATC
Mxsmanic wrote:
Uh, gee, Einstein, a real rudder DOES control flight path.
Sometimes it does, sometimes it doesn't.
There is never a case where it doesn't change flight path.
Old January 5th 07, 05:58 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Not so. When an engine fails on a multi, a lot of rudder is required.
Skillfully done, the application of a lot of rudder is mandatory to
maintain the desired flight path.
Old January 5th 07, 06:12 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mark Hansen
It is changing the flight path the aircraft would have taken had you
not applied the rudder.
Old January 5th 07, 07:00 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
That is like saying a localizer changes the flight path on an ILS.
Old January 5th 07, 09:37 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Mark Hansen writes:
It is also maintaining the flight path that you originally intended.
Old January 5th 07, 10:23 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Yep, thus changing the flight path from the centered position.
Old January 6th 07, 02:31 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
That is pure b.s. It keeps the flight path intended going, rather than
letting if follow the flight path at the centered position, which is
also known as a torgue roll into intverted flight, followed by a briefly
painful death for all aboard.
Old January 6th 07, 02:32 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Have a nice torque roll day.
Mxsmanic
Newps writes:
Landing in a crosswind.
Old January 5th 07, 10:28 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Mxsmanic wrote:
Newps writes:
Steeeeeerike two.
