On 01/05/07 09:58, Sam Spade wrote:
Newps wrote: Mxsmanic wrote: Uh, gee, Einstein, a real rudder DOES control flight path. Sometimes it does, sometimes it doesn't. There is never a case where it doesn't change flight path. Not so. When an engine fails on a multi, a lot of rudder is required. Skillfully done, the application of a lot of rudder is mandatory to maintain the desired flight path. It is changing the flight path the aircraft would have taken had you not applied the rudder. |
Mark Hansen wrote:
On 01/05/07 09:58, Sam Spade wrote: Newps wrote: Mxsmanic wrote: Uh, gee, Einstein, a real rudder DOES control flight path. Sometimes it does, sometimes it doesn't. There is never a case where it doesn't change flight path. Not so. When an engine fails on a multi, a lot of rudder is required. Skillfully done, the application of a lot of rudder is mandatory to maintain the desired flight path. It is changing the flight path the aircraft would have taken had you not applied the rudder. That is like saying a localizer changes the flight path on an ILS. |
Mark Hansen writes:
It is changing the flight path the aircraft would have taken had you not applied the rudder. It is also maintaining the flight path that you originally intended. -- Transpose mxsmanic and gmail to reach me by e-mail. |
