Confusion about when it's my navigation, and when it's ATC
Old January 5th 07, 09:37 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Confusion about when it's my navigation, and when it's ATC
Newps writes:
There is never a case where it doesn't change flight path.
Landing in a crosswind.
Old January 5th 07, 10:28 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Mxsmanic wrote:
Newps writes:
Steeeeeerike two.
Old January 6th 07, 06:50 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Newps writes:
Steeeeeerike two.
Why? The intended flight path is aligned with the centerline of the
runway, and in fact that is the flight path followed; there is no
deviation.
Old January 6th 07, 04:57 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Mxsmanic wrote:
Newps writes:
Steeeeeerike two.
deviation.
The rudder changed the flight path from what it would have been.
Old January 6th 07, 05:04 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Newps writes:
The flight path is where you want the aircraft to go, not where it
would have gone.
Old January 6th 07, 05:11 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
Mxsmanic wrote:
Newps writes:
would have gone.
Sorry, once again you are clueless. The flight path is the track over
the ground. Not the desired track, not the aircraft heading but the
actual track. That track can be controlled a number of ways.
Old January 6th 07, 05:29 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Newps wrote:
Mxsmanic wrote:
Newps writes:
would have gone.
That is correct. But, in most IFR operations desired track and actual
track must be virtually the same. If an engine is failed while actual
track is the same as desired track, and the proper application of rudder
(means no alieron cross-control input) results in continuing the actual
flight track to equal the desired flight track, then the flight path has
remained unchanged.
