Implications of.....keeping the speed up
Old January 6th 07, 06:18 AM posted to rec.aviation.ifr
Mxsmanic
Default Implications of.....keeping the speed up
Sam Spade writes:
It would be better to do neither.
How would he know what speed to fly?
Old January 6th 07, 03:23 PM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
By reading and understanding a basic FAR, and or, by seeking remedial
training from his flight operations department.
Old January 6th 07, 04:12 PM posted to rec.aviation.ifr
On Sat, 06 Jan 2007 07:23:24 -0800, Sam Spade
Mxsmanic wrote:
Sam Spade writes:
Gentlemen, I was hoping for some input on what techniques are used to
ensure compliance with the FARs.
Stan
Old January 6th 07, 06:03 PM posted to rec.aviation.ifr
On Sat, 06 Jan 2007 08:21:47 -0800, Sam Spade
Pilots are routinely taken below the floor of Class B airspace when
exceeding 200 knots. Most airline pilots have no idea where the
boundaries or floors of Class B airspace are located. No one cares
except the occasional fed on the jump seat who has a thing about it.
This is what I've observed too. Pilots flying hi level do not bother
with low level charts nor class B charts. Only hi level charts and
sid/star charts. Not saying it is safe, legal or proper, just that
it's normal ops.
Sam, would it be true too for the 2500 AGL within 4 nm limitation too,
in your opinion?
Secondly, is there some atc requirement that if your destination is
the primary airport in a class B, then atc is required to keep you in
class B, and not vector you below?
Stan
Old January 6th 07, 08:08 PM posted to rec.aviation.ifr
Sam Spade
it's normal ops.
It is impossible to figure out Class B from a paper chart in a jet
transport with all the more important stuff that has to be done.
With boundaries and altitude limits display electronically, it is
possible but still a lot of distraction. Try it with a Garmin with all
the aural elerts set and it is a pain. With a Garmin, it works well to
avoid Class B when VFR, but to use it to assure containment when on a
clearance within Class B, it becomes overwhelming.
in your opinion?
No. It is far easier to figure out where the stand-alone Class D
airspace is located.
That is policy to the extent it can be done without creating some other
traffic problem. But, there is no "rule."
Old January 8th 07, 05:11 AM posted to rec.aviation.ifr
Robert M. Gary
Althought ATC can authorized it, there is a rule.
91.131
(2) Unless otherwise authorized by ATC, each person operating a large
turbine engine-powered airplane to or from a primary airport for which
a Class B airspace area is designated must operate at or above the
designated floors of the Class B airspace area while within the lateral
limits of that area.
Why do I get the feeling that none of you guys have ever flown anything
that does 250 knots?
-Robert, CFII
Old January 8th 07, 06:54 AM posted to rec.aviation.ifr
G. Sylvester
First off, I'm a (very) light a/c IFR pilot. But having listened to
Channel 9 on UA for 135000 miles this past year, it is my (again,
limited) understanding/guess that on the approach the IAS is per the
pilots discretion AND within the FAR's. If there will be a traffic
problem, then ATC will issue to the affected a/c either delay vectors or
speed restrictions. It is common to hear "maintain 180 IAS until 6 DME"
where the pilots slow the plane to landing speed while descending on
the ILS. I don't recall clearance of a IAS "at least 200" as I usually
mentally read back clearances but I personally don't have to worry about
the FAR's since I'm a lowly piece of luggage at seat 2A on a A320 rather
than being the busdriver. I only wish an Archer could go that fast. I
just wish I could rent an Airbus for 100k frequent flier miles per hour.
Gerald
Propeller thrust question xerj Piloting 11 November 25th 05 03:12 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
