Lucky to be alive?
Old January 5th 07, 02:54 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default Lucky to be alive?
Stefan wrote:
Matt Whiting schrieb:
Because it sounded like the descended through an area of less than
VFR visibility (maybe even through a cloud layer, I don't recall the
specifics) and crashed.
No, it clearly sonded that he tried to stay on top but was washed down
into the soup.
I think you are mixing two different accidents. The one that started this
thread was a guy who, with his family heard that there was 1000 ft ceilings
below the clouds and went through the clouds looking for it and it wasn't
there.
You are, I beleive thinking of the guy in the Bo that got hit by a down
draft.
  #42
Old January 5th 07, 06:15 PM posted to rec.aviation.piloting
Stefan
I'ce cancelled my post as soon as I got aware of this. Unfortunately,
not all servers do honour cancel messages.
  #43
Old January 5th 07, 07:47 PM posted to rec.aviation.piloting
Gig 601XL Builder
this
Done it myself many times. And from what I can tell none of the servers
honor cancel messages any more even the one I post to to that requires me to
login with a user name and password.
  #44
Old January 6th 07, 08:13 AM posted to rec.aviation.piloting
Roger[_4_]
On Thu, 4 Jan 2007 17:52:30 -0500, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote:
"Roger" wrote in message
On Tue, 2 Jan 2007 17:29:41 -0500, "Capt. Geoffrey Thorpe" The Sea
"601XL Builder" wrDOTgiacona@suddenlinkDOTnet wrote in message
He needs his ticket yanked and I'll bet his instructor has a meeting
with
the FSDO as well.
From the description, it sounds like he attempted VFR over the top of the
overcast - I assume he was counting on a hole somewhere near the
destination? Perhaps he had a favorable forcast for somewhere down the
way?
The funny thing is that I have heard others on this newsgroup (or perhaps,
r.a.student) talk about doing exactly the same thing with not much of a
reaction. I guess they got away with it.
VFR over the top here in the states is quite common.
So then, why is everyone trying to get on this guy's case. Because his luck
ran out?
I'd guess because he apparently descended through the clag with out a
rating instead of proceeding on to where he could let down VFR.
Although the one area reported 1000 foot ceilings it appears others
were reporting much less and some cases of fog.
VFR over the TOP is taking a calculated risk and should be done with
"known" good VFR below the ceiling.(at least 1500 and 5) You also need
to know what is below just in case the engine quits or you smell
something burning. Plus you need good VFR within reach plus some
reserve.
The problem as I see it (with what information I have), is not that
his luck ran out, but with lack of planning, he made some poor
decisions resulting in a dangerous situation where he needed that
luck..
www.rogerhalstead.com
  #45
Old January 6th 07, 02:36 PM posted to rec.aviation.piloting
luck
ran out?
So, apparently, he had enough fuel to go on however far it was to get to
VMC?
reserve.
And, at the time he started over the top, he didn't have good forcasts up
ahead?
And, if you have good VMC underneath, why in the world would one want to
take the chance on going over?
VMC underneath is nice to know about, but if you don't have the IMC skills
to get there, it ain't gonna do you no good.
luck..
I would say proceding over the top was poor decision #1 - Betting on a
forcast being right, nothing going wrong with the airplane, and no other
options (e.g. IFR)
Geoff
  #46
Old January 7th 07, 04:00 AM posted to rec.aviation.piloting
Roger[_4_]
On Sat, 6 Jan 2007 09:36:45 -0500, "Capt. Geoffrey Thorpe" The Sea
luck
ran out?
VMC?
To be legal he should have and he must have been legal. Not that I'd
take any bets though.
reserve.
ahead?
"I think" they said morning fog that was "expected" to clear. Not
something I'd even depend on for IFR without reserves to get me to
VMC.
Turbulence below when it's *usually* smooth above layers, unfavorable
winds below, favorable winds on top, I flew from NC Tennessee to
central Michigan on top and never saw the ground from about Kentucky
to a bit north of the Michigan/Ohio border. It was absolutely clear up
here. We left Gainesville GA in good weather. We cut over to the
West about as far as Chattanooga to miss some stuff in the Knoxville
area.
After crossing the mountains it started to get pretty rough. We tried
descending and it got worse. So, we climbed up to put us over the
cloud layer to the north. It was silk smooth from there home.
Agreed
Long before I had the rating I had the skills to let down, or even fly
in the stuff IF an emergency happened and I flew a fair amount under
the hood and in actual with an instructor. I had more time in actual
and doing approaches to minimums as an instrument student than I have
accumulated since. Which means I was a lot more proficient then than I
am now. At present I need to take an IPC before going back in the
clouds and I'd not go over the top unless it were a short trip with
good VMC on the other side.
luck..
options (e.g. IFR)
Pretty much sums it up. However I believe the forecasts were not good
enough to even qualify those areas as alternates for an IFR flight.
Remember the 1, 2, and 3 where 1 is one hour before to one hour after
the scheduled arrival time with a ceiling of 2000 AGL and 3 miles
visibility. So he should have been expecting marginal conditions or
divine intervention.
Lucky to be alive? john smith Piloting 0 January 1st 07 04:30 PM
Lucky folks David Lesher Owning 9 August 5th 05 02:11 PM
401TFW/614TFS Lucky Devils in the Gulf War MKopack Military Aviation 0 July 7th 05 06:35 PM
~ I WISH RONALD REAGAN WAS STILL ALIVE ~ ArtKramr Military Aviation 1 June 9th 04 12:49 AM
Let's keep BLIPMap alive Martin Hellman Soaring 0 September 7th 03 07:11 PM
